Lowering springs with KYB gr2 for Ea81?
My question here is can you use kyb struts for stock replacement but use a shorter spring to get even just an inch lower? if so is there a spring I can get or would it be alright to just cut the stock springs? This is a 82'    4WD GL. also what about the back? I know I can adjust the torsion bar but idk where its sitting at the moment and if it will get low enough to match the front.
Try using 2wd front struts.  If that isnt enough you can custom order from anyone or cut springs if your on a budget..  I have 4wd springs with 2wd struts it dod lower the front.. Also is much stiffer but the car is 2wd for now anyway.
well I already ordered the gr2s for 4WD. just wondering if I can cut the stock springs an inch or two. or if I can even run shorter springs with these struts. Thankyou!
you might check the for sale section a board member has ea81 turbo springs in the Vancouver area they will be lower than the stockers. It would be a drive but much cheaper than ordering and you may not need to cut.
So if I use FWD front struts I can use the stock 4WD springs and they will compress and be lower? And what about the rear? Thanks yall!
Does anyone know the part number for KYB front struts for FWD??
I used these when lowering my Brat, I kept the stock springs: KYB 233024
Edited by epix
  • 3 months later...
Still looking for springs that I can cut to be shorter and possibly have a stiffer rate. What springs are the same as the stockers? Do ea82 springs sit on the strut and in the top hat the same?
Gitt's spring company in auburn will make you any coil spring you want
Thank you. Makes sense really.. I just didn't think. I'm gonna experiment and see how some stock springs feel
If you do end up chopping up springs, don't cut off more than 0.5-1.0 full coils. Your spring rate would be too high for our weak struts.
