pontoontodd
Awesome pics and trip report as usual Todd. I reckon my favourite pic is the one you walked in for - with the two big rocky outcrops that made a saddle and the sunset in the background; the vegetation on either side of the pic give us a nice amount of colour to balance it out. Mint!
Cheers
Bennie
  • Like 1
Posted (edited)
B and I did some work on our cars.  Replaced a front CV axle in the Forester that's been making noise occasionally but for quite a while.  B changed his engine and trans oils.
Trying to figure out Impreza's potential cooling problems.  Seems better with the new thermostat but still crept up a couple times on our last trip out west in mild ambient temps.  Really need to get some temp senders calibrated to the Haltech and get them installed on top and bottom of radiator.  IIRC the middle of the coolant temp gauge is about 210F on the Haltech but I can't guarantee either is accurate.  Infrared temp gun near the coolant temp sensor indicates it's at least close.  Then 3/4 of the way up the gauge is 217F at the Haltech, probably still nothing to worry about but should confirm actual temps.  Also thermostat is at the bottom/inlet of engine while the temp sensor is at the top so I'm getting coolant temp readings from the opposite end of the system than where the temps are controlled.  One thing we did was a smoke test on three different Subarus.  The Impreza's fans seemed to suck in the smoke as well as my white Outback with the stock fans.  Could see at least some of it blowing out the back of the radiator, didn't seem to be blowing around the sides or out from between the condenser and radiator.  So I think the fans are at least decent but since the overheating is a low vehicle speed issue perhaps we could get better fans although these had the highest CFM rating of any fans I could find.  One idea I have is to add a large heater core above the ABS unit under the hood vent on the passenger side with an electric fan on it.  The one we added to the back of the black Outback dropped coolant temps by 20F so that should do the trick and would be fairly easy to add.
AC was discharged before our last trip so I added some refrigerant but now it will cycle on and off about once a minute.  The high side spikes up to about 250psi while the low side drops to 20psi, then they briefly start to converge before the compressor kicks off.  Wondering if I have a clogged orifice as this seems like a much larger pressure difference than the charts show.
One time out west the coolant temps went up the power steering pump stopped working at low RPMs.  After we got home I first tried installing a pump from an EZ30.  Bracket is slightly different, no big deal, I'll swap the bracket.  Nope, pulley is a different size too, not going to mess with trying to swap that over.  So much for Legos.  Got an EZ36 PS pump from a local junkyard and swapped it in this morning which solved that issue.
We decided to tack up a couple trailing arms for B's eventual billet rear knuckle swap.large.IMG_0740s.jpg.26e665c62ce8164e47b60b71d0e3fdf6.jpg
Also trying to figure out my gas tank filling issue on the Impreza.  I replaced the carbon canister which is usually the culprit.  Not much better, also the one I pulled out seems good (not dumping carbon pellets out like the bad ones usually do).  Pulled the hose off the canister that goes to the gas tank vent.  When we blow compressed air in the gas filler air comes out that tube (seemed maybe a little blocked at first) similar to the Forester's.  Last time I went to fill up with gas it shut off before the tank was full, I pulled that hose off the canister and then the tank filled as it should.  Next time I'll try to remember to pull the other large hose off the canister instead.
Edited by pontoontodd
  • Like 1
I agree, water temp sensors will tell you if it's an airflow problem. You could try removing the hood scoop and vent inserts in the hood, give all that air from the fans somewhere to go
  • 2 weeks later...
Posted (edited)
B and I got a few things done on my cars.
Our main focus was solving the axle issue in the 2002 Outback and I think we accomplished that.
The axle in place was definitely getting overextended and the worst case for that is slightly above ride height, so not surprising that it was more of a problem when the car was overloaded.
We measured a bunch of axles.  Unfortunately it took us a bit to realize/remember that the axles for the press in rear wheel bearings in the strut cars are a slightly different spline than the bolt in wheel bearings in the multilink cars.  Again, so much for Legos.  Of course most of the axles we have are for the strut cars.  The axle that had been in the right rear measures in between the pair I recently got from a junkyard.  So it might be slightly shorter than the one it had replaced which might have been the main problem.  Any of them would have probably been too short at the most extended position.  I added a 1/4" thick spacer between the axle and the wheel bearing.  With that in place there's a millimeter or two of plunge travel left at the most extended position but it will still go to full droop and be close to the limit of bottoming out the inner CV.  I vaguely recall making a thin spacer years ago but there wasn't one in place when we've taken it apart.  To still get a decent crimp on the axle nut with the spacer I modified it in the lathe.
A contributing factor might be that we replaced the rear diff bushings the last time we replaced the axle so the diff can't move around as much now.
Also changed the oil and filter and tweaked the alignment a bit.
Haven't put a ton of miles on it but drove it around town quite a bit today and definitely used most of the travel, seems good so far.  Definitely would have popped out by now with the old assembly.
Next we worked on my green Impreza, changed oil and tweaked the alignment on that.
Main project there was the AC.  To recap, last summer it worked fine.  A couple months ago it had no (low?) charge so I charged it up.  Seemed to have much higher pressure differential than it should, would get up to about 20psi low 250psi high and shut off, pressures would converge, it would turn back on, and would continue doing that every minute or so.  Assumed the orifice was clogged.
Replaced the orifice and drier/filter too while we were at it.  Pulled a vacuum, got down to about 20"Hg and seemed to hold that with the vacuum pump off.  Put about half of a 12oz can of R134a in, runs at about 4psi on the low side and 90psi on the high side.  So it still seems like there is some kind of blockage.  Might try to backflush the condenser and evaporator, not sure what else to try at this point.
Got a couple temp sensors that should have good calibrations for the Haltech.  Plan to install those at both ends of the cooling system.  Also plan to find that large heater core and small electric fan we had in the back of the black Outback and install that under the hood of the green Impreza under the passenger side hood vent.  At the same time will probably add shutoff valves so we can bypass the in dash heater core to see if that helps cool down the cabin in the summer.
Posted (edited)
One of my friends said a good rule of thumb for R134a is that the pressure on both sides after the system has sat for a while should be about 5-10psi more than the ambient temp in Fahrenheit.  Seems weird but also seems to check out.  I added some with the AC off but it would only get up to about 65psi (both sides).  When I turned the AC back on the high and low pressures had gone up a bit.  After a minute or so of running it would shut off for a bit, pressures would start to equalize, then it would kick back in.  I slowly kept adding more (to the low side) with the AC on until it stopped cycling on and off.  Wound up adding most of a second can, probably has somewhere around the 19-23oz total it's supposed to have.  Low side is now about 30psi, high side about 150psi, blows cold.  Drove around town quite a bit today, never noticed the AC cycling on and off, cold the whole time.
The temp gauge did spike up to about 3/4 one time I started driving but then went back down slightly below the middle where it stayed for the rest of the time.  Definitely need to get some accurate temp sensors installed.
B replaced some bushings and ball joints on the front end of his white Forester.
He also blew some dust out of the air filter on my Impreza.  Messed with the rear seat belts too, they seem to just lock up sometimes.  He found that after pushing the belt back into the reel all the way they then work normally.  One problem is there's just more friction now with the belt rerouting.  Not a huge deal as the rear seat is rarely occupied.
The main thing I worked on was mounting the full size Dodge van heater core and 8" electric fan under the passenger side hood vent.  B also pointed out there is room for about a 10" puller fan behind the driver's side of the radiator.
Fan lines up nicely with the hood vent.
Need to paint those brackets.  I might get some valves so I can bypass either the heater core in the summer or this one in the winter before I bother plumbing it in.  If anyone knows of any good selectable tees with the right size barb fitting on them I'm looking for one.  The only tees I've found are fairly expensive and threaded so then I'd have to get barb fittings too.  I could get one or two of these:
https://www.oldairproducts.com/product/25-1018-bypass-heater-valve
https://www.rockauto.com/en/moreinfo.php?pk=10849736&cc=1028012&pt=6860&jsn=647&_nck=Hsaep13M915uuutk8%2Bf0wOeyqERYmFnnScHREpb2kaeQZMBwbsjIzbH8p6X7b8doV7ZhIKZrju0iMu8H6dXM7%2Brn6x%2B0jcKSODBkngSksRc8Zan%2B8zelEqDy3fSWbwfOPltq76G%2F%2BqudM5QnqkfncwVTbvl7WYgy%2FB5R5n7ZhrV7LBZsioiB3TmAKe3DAh41KLIKq6Sxllk%2FuLl9WzsOYRw%2BOcEcAfTSJlHRiVNIl1RPrA%2FNoewztrWsDKuoD6xe7CNXcLhVSC%2FH96c%2B3QTLRwUrVp4D8yNkgd0OuL1jSrQILgJitIgI5w%3D%3D
That is only true in a narrow range of ambient temperatures. For you to have read 65 PSI (assuming there was at least enough gas in the system to reach the saturation point) I'm guessing it was about 66F outside at the time you measured the inactive system pressure. You can find online gas/temp charts that show the relationship and values.
Adding gas the way you did is a great way to sneak up on the proper fill if you don't know how much was in the system to begin with but don't be temped to "add just a little more". The compressor will cycle on and off for three reasons. Low gas charge, evaporator coil  too cold or system overcharge. A compressor cycling because the evap coil temp is too low is the only time it is acceptable to routinely cycle. Cycling due to a low charge is not good because the refrigerant also carries the lubrication oil that the pump needs and an overcharge will wear out your pump and blow hoses.
I fill my systems by monitoring the evap coil return line temperature too. When I know I am close to the proper fill, I watch the temp of the fat line leaving the evap coil. You put in a little gas and watch to see if the outlet line drops a few degrees accordingly. You do that a few times as long as the temps keep dropping a  little each time. Once you add a little gas and the temp stops dropping, you know you have reached the point that the evap coil cannot boil off any further addition of refrigerant. It's a more nerdy way to do it but I'm in the SW desert and I need my cooling when it is 110 outside. I daily drive my 87 to work each day and driving home in the afternoon on the freeway really loads the system.
Your low 30, high 150 readings sound about right for a properly charged system on a day that was in the 70's but you don't mention the ambient temps on the day you did the work. Sounds like you have it dialed in pretty well.
Speaking of R134a, a local farm store had 16oz cans of R134 for $5 a can this weekend. I stocked up for sure.
16 hours ago, el_freddo said:
Thanks for the links.  For the ebay addresses, you can just cut off everything after the item number (starting with and including the question mark).
Slammo found at least one other one similar to that Holden one you posted but after discussing it with him a bit more I probably won't bother with the bypass valves for now.  Make sure the extra heater core does its job and on cool mornings esp up north I still might want the heat from the stock heater core.  Plus it will just be simpler and fewer potential leaks.
It was 83F out today and while running the AC the temp gauge was up in the 3/4 range most of the time.  Would drop down with the AC off.  When I got home and it was at 3/4 on the temp gauge, I left the engine running and popped the hood and didn't see any boiling in the overflow.  I pointed the IR temp gun at a few things.  Upper water neck (where the sensor is located) was about 210F.  Radiator was around 200F top and bottom.  So probably nothing to really worry about.  Gotta get some accurate temp readings going.
Yeah, I think it's good now, been working well and not cycling on and off.  It was probably in the 70s when I finished charging it.  And not overcharged, I know as you say that can be hard on AC components.  Your AC definitely has to be top notch to be comfortable in AZ.  I like your technique of monitoring the AC line temp and stop filling when it stops dropping.  How do you measure that temp?
Dang $5/can is a killer deal.
I have a 4-channel temp reader with a handful of 6' long thermocouples. I put the thermocouple touching the fitting and hold it in place with a One-Wrap style Velcro tie. If doing a driving test, I can temporarily route the wire into the interior past the door weatherstrip and monitor the temps while driving. I also have a set of those wireless A/C pressure gauges so I can watch the high and low side pressures while driving. Too much data probably, huh?
Definitely not too much data, I love it.  We've discussed sending high and low pressures to the Haltech.  And again, in AZ, seems fully justified.
1 hour ago, Numbchux said:
Make sure you actually bypass the heater core. Circulation through that circuit is what warms up (and therefore opens) the thermostat.
For sure.  In the short run (tomorrow?) I plan on just plumbing the added cooler inline with the heater core with no valves.
  • Like 1
Won't adding that additional cooler in line with the heater core cause cooler water to flow to the thermostat, therefore keeping the thermostat closed and keeping your engine warmer?
Speaking of which, it might be worth seeing how it does with no thermostat at all (with or without the aux cooler), just to remove that variable from the equation.
I suppose maybe it would close the thermostat but in practice, running the heat always seems to drop the coolant temps and this setup worked in the 99 Outback.  When it's running hot I assume the thermostat is all the way open no matter what.
Have considered no thermostat, if it didn't require draining all the coolant I probably would have tried that by now.
If the coolant bypassing the radiator (through the heater core[s] in this case) is adequately removing the heat, than the thermostat doesn't need to open. As long as there's adequate circulation, the thermostat will open when it's needed.
In theory, removing the thermostat entirely can be counterproductive, as increasing the coolant flow means it doesn't spend enough time in the radiator to actually dissipate the heat.
  • Like 1
  • 3 weeks later...
B and I worked on our white rust free California Subarus my brother bought for us.
I replaced all the auto trans hoses on my Outback and replaced all the stock clamps with worm style hose clamps.  One of them had sprung a pinhole leak earlier and enough leaked out on my way to work that the car stopped driving.  Some of them are 23 years old.  Rear axle has been staying put, not that I've driven the car a lot.
B replaced the timing belt, tensioner, idlers, some of the plastic, and a cam seal on his Forester.  Unfortunately the new cam seal seems to be leaking more than the old one if anything.
Painted the brackets and installed the extra cooler and fan in the Impreza.  Spliced a couple spades into the wiring for the passenger side fan (which kicks on second) for the small fan.
Here you can see it lines up with the hood vent fairly well.
Stepped up to a 12" tablet for navigation.  Fit in the old mount after cutting down the springs.  So far so good, glad I did it.
It's summer here so we've been doing some kayaking.  Have seen a lot of wildlife.  This past weekend we went to the UP and did more off pavement driving than I expected.  Mostly just gravel roads but some dirt trails too.  One was rutted but seemed dry until I got off to the wrong side and sunk in on the passenger side.  Some high lift jacking and shoveling and putting some chunks of found wood under the tires allowed me to drive out.  At that time I noticed all the fans were running and I could indeed feel hot air blowing out the hood vent.  At no time did the temps ever go above the middle on the gauge.  It wasn't extremely hot and we weren't pushing the car too hard but definitely an improvement.  We drove up some long steep grades with the AC on (also seems to be working great now) and drove a fair amount off pavement in 70-80F temps.  Have a couple temp sensors that have calibration for the Haltech and the tap I need to make bungs for them, still plan on installing those in the top and bottom of the cooling system.  Still waiting on fab guy to make my extra fuel tank.  Even with a new carbon canister the Impreza still fills with fuel slowly/incompletely.  Taking the vent hose to the carbon canister off seems to solve the problem.  Might tee a long vent hose into that one or something.  I drive the car enough I'm not worried about losing a lot of fuel to evaporation.
  • 3 weeks later...
Posted (edited)
A friend of ours from Houston drove up to my house a couple weeks ago and we headed up to the UP.  Once we got there we stopped for pasties and ate them at a park along Lake Michigan on the edge of town. A younger guy stopped on his motorcycle and asked about the Impreza, we talked Subarus for a bit. He had just imported a 99 STI from Japan.  It's funny to me, ever since I got this Impreza I've gotten a lot more questions and had a lot more people taking pictures of the car than with the other Subarus.  Not sure how much of that is people's love of first gen Imprezas and how much is the fact that you don't see many turn of the century Subarus driving around anymore. We drove up to the campground along the reservoir in the southern UP. M and B showed up later.
Friday we went to the rapids and then hit the mini banked oval. There was a snapping turtle at the edge of the oval. Then we wandered up to the Baraga pipeline grade. We were all entertained as usual. Hit some of the sandy stunt areas nearby and a few of the side trails. Before we got to Houghton we were on a trail in the woods where we decided to turn around. I could not get the Forester out of the ruts so we eventually put a bunch of branches and sticks in the ruts and I was eventually able to get out. Then going back down the trail I was crabbing the Forester sideways for hundreds of feet before I finally got straightened out. Headed north to Houghton and then to Gay beach. M declared it the mother of all stunt areas. Drove much farther south than we had before after crossing a narrow spit of tailings along the lake.
Did some side by side uphill jumps and then decided maybe we should leave while we still could.
large.1053921691_screenshotmikesidebysidejump2s.jpg.80886cd94f7f785a7902862e90632b9c.jpg
Checked out the mine building ruins, some good post apocalyptic flavor there.
Temps were solid while driving on Gay beach which is a good test of high duty cycle and low speeds. Then they crept up in the woods and we discovered one of the fan fuses was blown. The passenger side fan would turn most of the way pretty easily but there was one spot in the rotation it would get stuck. We eventually figured out there was a tiny pebble(?) stuck to the outer ring of the fan blades. We were eventually able to get it off and replaced the fuse. Later we noticed it had a slight coolant leak. We tracked this down to the small welds on the underhood heater core that attach the mounting flange to the end tanks. Rerouted the heater hoses to the stock configuration. Got up to the top of the cliff along Cliff drive. I had parked a few hundred feet back from the first overlook and when I was walking back to my car a UTV was coming up. I heard the driver blurt out “what the f--k?” when he saw the Impreza. He told me he knows people who won't take their Jeeps up the rocky climb we took to get to the top. I then walked back to the overlook and he said the same thing to the other guys. We drove to the next overlook and hard parked on the edge for some pictures. The yoopers showed up again and we talked to them for a while. “This isn't what most people from Illinois do when they come up here” one of them says while holding out his pinky finger. They had both seen different UFOs and had some story about a cave nearby that no one could find with a wall of silver and a bag of gold coins. I believed the UFO stories more. We camped at the overlook.
Saturday morning we headed up to Brockway Mountain. As we pulled on to the long road going there we were proceeded by three extremely slow drivers. We pulled off on a side trail rather than test our patience following them the whole way there. This trail eventually led to a very sketchy bridge but we managed to cross it. I think it was in this area I checked one muddy stretch on foot and it didn't seem too bad so I drove through it, but I was barely able to do so and then the ruts were deeper and softer. So I told B he shouldn't come through and I didn't want to go back through so worst case we come back to that spot in a half hour. Fortunately we were able to maintain radio contact and I was able to drive around the block so to speak and meet back up with them. We eventually found a different way out of the area. At one point the temps had started to creep up in the Impreza again and a fan fuse was blown. This one was probably from the fans running while driving in deep water, we replaced it and never had the problem again. We eventually got up to Brockway Mountain from the other side. After we'd been on trails for quite a while and got back to pavement B said the Forester was shaking quite a bit. Turned out all the LR lugnuts on his Forester were loose and one was missing. We tightened down the ones we could and continued. From there we did a little more trail riding and buzzed up to the beach to camp for the night. At camp B swapped out his wheel studs on the LR hub as most of them were somewhat damaged or packed full of aluminum.
Sunday we started heading back on various trails. One of them eventually became deeply rutted and I didn't think I could get through without taking off a mirror so we turned around.
We came to a fairly long and deep water crossing where beavers had flooded a road. There was a muskrat swimming in it when we pulled up. I walked it and it was just below knee deep for a couple hundred feet. I drove through it in the Impreza after we removed the fan fuses. There was water over the front of the hood for a good portion of the crossing and we realized we should have stuck the gopro on. B crossed it in the Forester and then we put the gopro on the Impreza and I crossed it back the way we came and then back again to proceed. At the top of the hill right next to the stream was a cool old furnace of some kind.
Later we found the beaver dam that was flooding that road. The highlight of the day was probably discovering and climbing Mt Houghton. Probably the most intimidating rocky climb we accomplished that weekend (ever in the UP?) and one of the best views in the UP once we made it to the top.
Got gas and water at the Lac La Belle resort. Cashier was using binoculars to read the mechanical gas pumps. Found a silly hillclimb along the border of a wildlife sanctuary that M almost convinced me to try but ultimately we decided it should wait for a different weekend. Buzzed down to Lake Linden to camp that night so J could take a shower and we'd be closer to the portage.
Monday morning we took the Bill Nichols trail basically all the way from South Range to Adventure Mountain with a few detours and stops for some stunt areas and mines along the way. M and J enjoyed the Firesteel trestles and the lookout near the top of Adventure mountain and we headed back from there. The trail west out from the Adventure mountain climb was rough and narrow but we made it through with some extra dents in the rockers and floorboards. Stopped near the end of that trail to air up and eat PB&Js. We drove down to Watersmeet together and the Impreza seemed to have some high frequency vibration that didn't go away when I put the clutch in. Cleaned some dirt out of the wheels when we stopped for gas but that didn't help. Stopped again and discovered two of the driveshaft bolts were missing from the pinion flange.
I had looked before but those two must have been up. Installed some bolts and tightened them all down and had a smooth ride home. Could only run the AC intermittently on the way home or the coolant temp would creep up.
Overall a good weekend, cooling issues with the Impreza are still frustrating but we all had a good time. J and M were impressed with the Impreza, especially the EZ36. J definitely enjoyed the UP and quickly got in the groove of following overgrown trails (with a surprisingly high success rate of connecting to other trails this weekend). M said it was probably his favorite off road trip we've taken, no major malfunctions, lots of stunt areas, lots of overgrown trails (which he likes).
Removed the radiator after we got home and it seemed clean. I had sprayed it off at the car wash but that's usually not too effective. So I'm still a bit surprised the car was running hot on the highway. We did check the overflow at least once when it was hot and still have never seen air bubbles. After spraying the condenser out from the back with a hose wand it did become clear that a lot of the fins on it are bent over. We did go through a lot of brush so it's probably from the fan blades spinning leaves and twigs against the condenser.  Should be getting a replacement today, hopefully that brings the temps back under control.  Also got a pair of 80s Ford Econoline heater cores I plan on putting where the extra heater core is now for more cooling capacity.
  • Like 3
So awesome. I love exploring that area! The time required to get my Outback or 4Runner into a condition to confidently do that is just not on my priority list right now. So I'm living vicariously through you!
  • Like 1
  • Haha 1
Awesome trip Tod!
Not knowing the area at all, I can only imagine the distance and terrain covered.
I love the comments from those that saw you up the top where ppl with jeeps wouldn’t consider going. Nothing unusual with that, it’s the same over here - more prissy 4wd owners than those that use them for what they’re designed to do.
Cheers
Bennie
  • 2 weeks later...
Best picture I have of the condenser fins (well OK this is one of the worst areas).
Replaced the condenser, slightly different (a little shorter) but it fit alright. Made some brackets and put the worst paint job I've ever applied on them for a puller fan on the driver's side of the radiator, wired that in with the driver's side pusher fan.
Also turned up some bungs for temp sensors and had someone weld them on top and bottom of radiator.
Hard to see in these pictures but the puller fan has some clearance to the engine.
I glued a couple pieces of sheet metal on the fins where the center of the fans had been rubbing a bit.  Have had that problem in the past and this seems to solve it.
Sealed the sides between the radiator and condenser so hopefully less air can go around the radiator.
B did most of the fab work/fitting for a fan/heater core bracket to fit a 1980's Ford Econoline heater core (slightly bigger than the Dodge one that started leaking). Set this up so we can add a second one underneath after we remove the ABS unit. So far though, even without the extra heater core, temps seem stable even driving in stop and go traffic in 90+F weather with the AC on. And the AC works well. Cruise has not worked a few times I've driven the car in the last month or so, but then will work the next time I drive it, and usually works. One time I drove the car the clutch engagement was near the end/bottom of the travel, it's normally (before and since then) closer to the middle or top/start of the pedal travel.  All other times the clutch has felt normal.  After the last off road trip and I washed the car the rack had leaked some power steering fluid out of the slightly torn driver's side rack boot. Power steering was not always self centering with poor assist at low speeds for a while and the reseroir was very low but seems to be back to normal now and hasn't noticeably leaked in a while. Epoxied a couple of the studs on the hood scoop. Used a screw in the one broken off clip and clearanced the steel baffle plate so I can get at another one of the hood scoop nuts with the steel plate installed.
Car has pulled to the right slightly for a long time, we've checked the alignment a few times and it always seems good.  The right rear brake seems to drag more than the others.  I was going to replace the caliper and then discovered one of the bolts was starting to rub on the strut housing due to brake pad wear.
I unbolted both the calipers and ground clearance on the strut housings where those bolts were hitting (or going to hit).  So far this doesn't seem to have solved the problem but I might drive it a bit more first.
