April 13, 20251 yr Awesome pics and trip report as usual Todd. I reckon my favourite pic is the one you walked in for - with the two big rocky outcrops that made a saddle and the sunset in the background; the vegetation on either side of the pic give us a nice amount of colour to balance it out. Mint! Cheers Bennie
April 20, 2025Apr 20 Author I made a walkaround video of the black Outback and recently revised it with some suggestions from slammo. Edited May 2, 2025May 2 by pontoontodd
April 27, 2025Apr 27 Author B and I did some work on our cars. Replaced a front CV axle in the Forester that's been making noise occasionally but for quite a while. B changed his engine and trans oils. Trying to figure out Impreza's potential cooling problems. Seems better with the new thermostat but still crept up a couple times on our last trip out west in mild ambient temps. Really need to get some temp senders calibrated to the Haltech and get them installed on top and bottom of radiator. IIRC the middle of the coolant temp gauge is about 210F on the Haltech but I can't guarantee either is accurate. Infrared temp gun near the coolant temp sensor indicates it's at least close. Then 3/4 of the way up the gauge is 217F at the Haltech, probably still nothing to worry about but should confirm actual temps. Also thermostat is at the bottom/inlet of engine while the temp sensor is at the top so I'm getting coolant temp readings from the opposite end of the system than where the temps are controlled. One thing we did was a smoke test on three different Subarus. The Impreza's fans seemed to suck in the smoke as well as my white Outback with the stock fans. Could see at least some of it blowing out the back of the radiator, didn't seem to be blowing around the sides or out from between the condenser and radiator. So I think the fans are at least decent but since the overheating is a low vehicle speed issue perhaps we could get better fans although these had the highest CFM rating of any fans I could find. One idea I have is to add a large heater core above the ABS unit under the hood vent on the passenger side with an electric fan on it. The one we added to the back of the black Outback dropped coolant temps by 20F so that should do the trick and would be fairly easy to add. AC was discharged before our last trip so I added some refrigerant but now it will cycle on and off about once a minute. The high side spikes up to about 250psi while the low side drops to 20psi, then they briefly start to converge before the compressor kicks off. Wondering if I have a clogged orifice as this seems like a much larger pressure difference than the charts show. One time out west the coolant temps went up the power steering pump stopped working at low RPMs. After we got home I first tried installing a pump from an EZ30. Bracket is slightly different, no big deal, I'll swap the bracket. Nope, pulley is a different size too, not going to mess with trying to swap that over. So much for Legos. Got an EZ36 PS pump from a local junkyard and swapped it in this morning which solved that issue. We decided to tack up a couple trailing arms for B's eventual billet rear knuckle swap. Also trying to figure out my gas tank filling issue on the Impreza. I replaced the carbon canister which is usually the culprit. Not much better, also the one I pulled out seems good (not dumping carbon pellets out like the bad ones usually do). Pulled the hose off the canister that goes to the gas tank vent. When we blow compressed air in the gas filler air comes out that tube (seemed maybe a little blocked at first) similar to the Forester's. Last time I went to fill up with gas it shut off before the tank was full, I pulled that hose off the canister and then the tank filled as it should. Next time I'll try to remember to pull the other large hose off the canister instead. Edited April 27, 2025Apr 27 by pontoontodd
April 27, 2025Apr 27 I agree, water temp sensors will tell you if it's an airflow problem. You could try removing the hood scoop and vent inserts in the hood, give all that air from the fans somewhere to go
May 6, 2025May 6 Author B and I got a few things done on my cars. Our main focus was solving the axle issue in the 2002 Outback and I think we accomplished that. The axle in place was definitely getting overextended and the worst case for that is slightly above ride height, so not surprising that it was more of a problem when the car was overloaded. We measured a bunch of axles. Unfortunately it took us a bit to realize/remember that the axles for the press in rear wheel bearings in the strut cars are a slightly different spline than the bolt in wheel bearings in the multilink cars. Again, so much for Legos. Of course most of the axles we have are for the strut cars. The axle that had been in the right rear measures in between the pair I recently got from a junkyard. So it might be slightly shorter than the one it had replaced which might have been the main problem. Any of them would have probably been too short at the most extended position. I added a 1/4" thick spacer between the axle and the wheel bearing. With that in place there's a millimeter or two of plunge travel left at the most extended position but it will still go to full droop and be close to the limit of bottoming out the inner CV. I vaguely recall making a thin spacer years ago but there wasn't one in place when we've taken it apart. To still get a decent crimp on the axle nut with the spacer I modified it in the lathe. A contributing factor might be that we replaced the rear diff bushings the last time we replaced the axle so the diff can't move around as much now. Also changed the oil and filter and tweaked the alignment a bit. Haven't put a ton of miles on it but drove it around town quite a bit today and definitely used most of the travel, seems good so far. Definitely would have popped out by now with the old assembly. Next we worked on my green Impreza, changed oil and tweaked the alignment on that. Main project there was the AC. To recap, last summer it worked fine. A couple months ago it had no (low?) charge so I charged it up. Seemed to have much higher pressure differential than it should, would get up to about 20psi low 250psi high and shut off, pressures would converge, it would turn back on, and would continue doing that every minute or so. Assumed the orifice was clogged. Replaced the orifice and drier/filter too while we were at it. Pulled a vacuum, got down to about 20"Hg and seemed to hold that with the vacuum pump off. Put about half of a 12oz can of R134a in, runs at about 4psi on the low side and 90psi on the high side. So it still seems like there is some kind of blockage. Might try to backflush the condenser and evaporator, not sure what else to try at this point. Got a couple temp sensors that should have good calibrations for the Haltech. Plan to install those at both ends of the cooling system. Also plan to find that large heater core and small electric fan we had in the back of the black Outback and install that under the hood of the green Impreza under the passenger side hood vent. At the same time will probably add shutoff valves so we can bypass the in dash heater core to see if that helps cool down the cabin in the summer. Edited May 7, 2025May 7 by pontoontodd
May 7, 2025May 7 Author One of my friends said a good rule of thumb for R134a is that the pressure on both sides after the system has sat for a while should be about 5-10psi more than the ambient temp in Fahrenheit. Seems weird but also seems to check out. I added some with the AC off but it would only get up to about 65psi (both sides). When I turned the AC back on the high and low pressures had gone up a bit. After a minute or so of running it would shut off for a bit, pressures would start to equalize, then it would kick back in. I slowly kept adding more (to the low side) with the AC on until it stopped cycling on and off. Wound up adding most of a second can, probably has somewhere around the 19-23oz total it's supposed to have. Low side is now about 30psi, high side about 150psi, blows cold. Drove around town quite a bit today, never noticed the AC cycling on and off, cold the whole time. The temp gauge did spike up to about 3/4 one time I started driving but then went back down slightly below the middle where it stayed for the rest of the time. Definitely need to get some accurate temp sensors installed. Edited May 7, 2025May 7 by pontoontodd
May 11, 2025May 11 Author B replaced some bushings and ball joints on the front end of his white Forester. He also blew some dust out of the air filter on my Impreza. Messed with the rear seat belts too, they seem to just lock up sometimes. He found that after pushing the belt back into the reel all the way they then work normally. One problem is there's just more friction now with the belt rerouting. Not a huge deal as the rear seat is rarely occupied. The main thing I worked on was mounting the full size Dodge van heater core and 8" electric fan under the passenger side hood vent. B also pointed out there is room for about a 10" puller fan behind the driver's side of the radiator. Fan lines up nicely with the hood vent. Need to paint those brackets. I might get some valves so I can bypass either the heater core in the summer or this one in the winter before I bother plumbing it in. If anyone knows of any good selectable tees with the right size barb fitting on them I'm looking for one. The only tees I've found are fairly expensive and threaded so then I'd have to get barb fittings too. I could get one or two of these: https://www.oldairproducts.com/product/25-1018-bypass-heater-valve https://www.rockauto.com/en/moreinfo.php?pk=10849736&cc=1028012&pt=6860&jsn=647&_nck=Hsaep13M915uuutk8%2Bf0wOeyqERYmFnnScHREpb2kaeQZMBwbsjIzbH8p6X7b8doV7ZhIKZrju0iMu8H6dXM7%2Brn6x%2B0jcKSODBkngSksRc8Zan%2B8zelEqDy3fSWbwfOPltq76G%2F%2BqudM5QnqkfncwVTbvl7WYgy%2FB5R5n7ZhrV7LBZsioiB3TmAKe3DAh41KLIKq6Sxllk%2FuLl9WzsOYRw%2BOcEcAfTSJlHRiVNIl1RPrA%2FNoewztrWsDKuoD6xe7CNXcLhVSC%2FH96c%2B3QTLRwUrVp4D8yNkgd0OuL1jSrQILgJitIgI5w%3D%3D
May 12, 2025May 12 The VT commodore had a vacuum actuated tap from memory. That might work ok. https://www.ebay.com.au/itm/401549783595?_skw=corvette+heater+tap&itmmeta=01JV1WVEBGSPBTEP9B9113TB8G&hash=item5d7e3b722b:g:OnkAAeSwpRRoGwiv&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1eJINj5jgQt19ervaLpB6mTJVlbBUu4vglR9vmIgxvxhRqvEnQJ9doxy%2BZktYtxQqsZbJrKIht9otsWH84id9755%2BIn4cypkZl27%2FKDjPv%2BOsNEZ56AEsLRJhfG4c2ur2ajr7zjHFcU5JxN%2FWNrtoG2K1ptrcQU37fJiCbGw0K2Fo8C6CPpRgnrpt0Z5HDKMS%2FsRHx7x2D1HmCQYm5cwboEgRKEm%2FAyJisAIvLqnBIPF9%2FBi%2FMeZ4G5Ee8S1CnZI%2Bp21AmT9uMJ3RwDd4tUUigpFT6ya35g5u%2B4YLFI1ivSog%3D%3D|tkp%3ABFBM8uXtvNhl Or if you can find one from a Brat era EA81 they have a cable operated tap that’s a bypass setup rather than just a tap. There’s this one that popped up in my search for something else. It’s like the best setup but vacuum operated much like the VT unit, except it’s a bypass: https://www.ebay.com.au/itm/113243302295?_skw=corvette+heater+tap&itmmeta=01JV1WVEBGGHWS4HTZR14X1VKH&hash=item1a5dd3a997:g:WhcAAOSwDMNkGQe4&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1eL7rKl%2F2ljcIXVOOnL54JOwJ%2BUR2fbUufq%2FoaM9p7nLt85Zdd7srrSorj2BIUWgGYmb4Flk3R2uJRBAkQEtJbW%2FWyIGJoKk5hAQAJ15GBRPSVynDiwwJynUYCg83YGr%2BVPLXw3%2B7y1dsD%2BgxvfWL1RMtnFO9t0ly%2BeOt6vf2XdZjwrywR65%2BQRM6AVvBIzW6CMz8caCR3ZoI%2BBQFqFxb%2BFGy%2BT5X7AQDUVNFYSSZWq%2FU9FNhnNNkFfbK1C0qWh7oYEypRNfLV%2F2X8DJCDQK7jboTUHKNl1yQIRfpYTUXyJCQ%3D%3D|tkp%3ABFBM8uXtvNhl Damn I hate these eBay link addresses! Cheers Bennie
May 12, 2025May 12 On 5/7/2025 at 12:51 PM, pontoontodd said: One of my friends said a good rule of thumb for R134a is that the pressure on both sides after the system has sat for a while should be about 5-10psi more than the ambient temp in Fahrenheit. That is only true in a narrow range of ambient temperatures. For you to have read 65 PSI (assuming there was at least enough gas in the system to reach the saturation point) I'm guessing it was about 66F outside at the time you measured the inactive system pressure. You can find online gas/temp charts that show the relationship and values. Adding gas the way you did is a great way to sneak up on the proper fill if you don't know how much was in the system to begin with but don't be temped to "add just a little more". The compressor will cycle on and off for three reasons. Low gas charge, evaporator coil too cold or system overcharge. A compressor cycling because the evap coil temp is too low is the only time it is acceptable to routinely cycle. Cycling due to a low charge is not good because the refrigerant also carries the lubrication oil that the pump needs and an overcharge will wear out your pump and blow hoses. I fill my systems by monitoring the evap coil return line temperature too. When I know I am close to the proper fill, I watch the temp of the fat line leaving the evap coil. You put in a little gas and watch to see if the outlet line drops a few degrees accordingly. You do that a few times as long as the temps keep dropping a little each time. Once you add a little gas and the temp stops dropping, you know you have reached the point that the evap coil cannot boil off any further addition of refrigerant. It's a more nerdy way to do it but I'm in the SW desert and I need my cooling when it is 110 outside. I daily drive my 87 to work each day and driving home in the afternoon on the freeway really loads the system. Your low 30, high 150 readings sound about right for a properly charged system on a day that was in the 70's but you don't mention the ambient temps on the day you did the work. Sounds like you have it dialed in pretty well. Speaking of R134a, a local farm store had 16oz cans of R134 for $5 a can this weekend. I stocked up for sure.
May 13, 2025May 13 Author 16 hours ago, el_freddo said: The VT commodore had a vacuum actuated tap from memory. That might work ok. https://www.ebay.com.au/itm/401549783595?_skw=corvette+heater+tap&itmmeta=01JV1WVEBGSPBTEP9B9113TB8G&hash=item5d7e3b722b:g:OnkAAeSwpRRoGwiv&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1eJINj5jgQt19ervaLpB6mTJVlbBUu4vglR9vmIgxvxhRqvEnQJ9doxy%2BZktYtxQqsZbJrKIht9otsWH84id9755%2BIn4cypkZl27%2FKDjPv%2BOsNEZ56AEsLRJhfG4c2ur2ajr7zjHFcU5JxN%2FWNrtoG2K1ptrcQU37fJiCbGw0K2Fo8C6CPpRgnrpt0Z5HDKMS%2FsRHx7x2D1HmCQYm5cwboEgRKEm%2FAyJisAIvLqnBIPF9%2FBi%2FMeZ4G5Ee8S1CnZI%2Bp21AmT9uMJ3RwDd4tUUigpFT6ya35g5u%2B4YLFI1ivSog%3D%3D|tkp%3ABFBM8uXtvNhl Or if you can find one from a Brat era EA81 they have a cable operated tap that’s a bypass setup rather than just a tap. There’s this one that popped up in my search for something else. It’s like the best setup but vacuum operated much like the VT unit, except it’s a bypass: https://www.ebay.com.au/itm/113243302295?_skw=corvette+heater+tap&itmmeta=01JV1WVEBGGHWS4HTZR14X1VKH&hash=item1a5dd3a997:g:WhcAAOSwDMNkGQe4&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1eL7rKl%2F2ljcIXVOOnL54JOwJ%2BUR2fbUufq%2FoaM9p7nLt85Zdd7srrSorj2BIUWgGYmb4Flk3R2uJRBAkQEtJbW%2FWyIGJoKk5hAQAJ15GBRPSVynDiwwJynUYCg83YGr%2BVPLXw3%2B7y1dsD%2BgxvfWL1RMtnFO9t0ly%2BeOt6vf2XdZjwrywR65%2BQRM6AVvBIzW6CMz8caCR3ZoI%2BBQFqFxb%2BFGy%2BT5X7AQDUVNFYSSZWq%2FU9FNhnNNkFfbK1C0qWh7oYEypRNfLV%2F2X8DJCDQK7jboTUHKNl1yQIRfpYTUXyJCQ%3D%3D|tkp%3ABFBM8uXtvNhl Damn I hate these eBay link addresses! Cheers Bennie Thanks for the links. For the ebay addresses, you can just cut off everything after the item number (starting with and including the question mark). Slammo found at least one other one similar to that Holden one you posted but after discussing it with him a bit more I probably won't bother with the bypass valves for now. Make sure the extra heater core does its job and on cool mornings esp up north I still might want the heat from the stock heater core. Plus it will just be simpler and fewer potential leaks. It was 83F out today and while running the AC the temp gauge was up in the 3/4 range most of the time. Would drop down with the AC off. When I got home and it was at 3/4 on the temp gauge, I left the engine running and popped the hood and didn't see any boiling in the overflow. I pointed the IR temp gun at a few things. Upper water neck (where the sensor is located) was about 210F. Radiator was around 200F top and bottom. So probably nothing to really worry about. Gotta get some accurate temp readings going.
May 13, 2025May 13 Author 12 hours ago, azdave said: That is only true in a narrow range of ambient temperatures. For you to have read 65 PSI (assuming there was at least enough gas in the system to reach the saturation point) I'm guessing it was about 66F outside at the time you measured the inactive system pressure. You can find online gas/temp charts that show the relationship and values. Adding gas the way you did is a great way to sneak up on the proper fill if you don't know how much was in the system to begin with but don't be temped to "add just a little more". The compressor will cycle on and off for three reasons. Low gas charge, evaporator coil too cold or system overcharge. A compressor cycling because the evap coil temp is too low is the only time it is acceptable to routinely cycle. Cycling due to a low charge is not good because the refrigerant also carries the lubrication oil that the pump needs and an overcharge will wear out your pump and blow hoses. I fill my systems by monitoring the evap coil return line temperature too. When I know I am close to the proper fill, I watch the temp of the fat line leaving the evap coil. You put in a little gas and watch to see if the outlet line drops a few degrees accordingly. You do that a few times as long as the temps keep dropping a little each time. Once you add a little gas and the temp stops dropping, you know you have reached the point that the evap coil cannot boil off any further addition of refrigerant. It's a more nerdy way to do it but I'm in the SW desert and I need my cooling when it is 110 outside. I daily drive my 87 to work each day and driving home in the afternoon on the freeway really loads the system. Your low 30, high 150 readings sound about right for a properly charged system on a day that was in the 70's but you don't mention the ambient temps on the day you did the work. Sounds like you have it dialed in pretty well. Speaking of R134a, a local farm store had 16oz cans of R134 for $5 a can this weekend. I stocked up for sure. Yeah, I think it's good now, been working well and not cycling on and off. It was probably in the 70s when I finished charging it. And not overcharged, I know as you say that can be hard on AC components. Your AC definitely has to be top notch to be comfortable in AZ. I like your technique of monitoring the AC line temp and stop filling when it stops dropping. How do you measure that temp? Dang $5/can is a killer deal.
May 13, 2025May 13 13 hours ago, pontoontodd said: I like your technique of monitoring the AC line temp and stop filling when it stops dropping. How do you measure that temp? I have a 4-channel temp reader with a handful of 6' long thermocouples. I put the thermocouple touching the fitting and hold it in place with a One-Wrap style Velcro tie. If doing a driving test, I can temporarily route the wire into the interior past the door weatherstrip and monitor the temps while driving. I also have a set of those wireless A/C pressure gauges so I can watch the high and low side pressures while driving. Too much data probably, huh?
May 13, 2025May 13 Make sure you actually bypass the heater core. Circulation through that circuit is what warms up (and therefore opens) the thermostat.
May 13, 2025May 13 Author 8 hours ago, azdave said: I have a 4-channel temp reader with a handful of 6' long thermocouples. I put the thermocouple touching the fitting and hold it in place with a One-Wrap style Velcro tie. If doing a driving test, I can temporarily route the wire into the interior past the door weatherstrip and monitor the temps while driving. I also have a set of those wireless A/C pressure gauges so I can watch the high and low side pressures while driving. Too much data probably, huh? Definitely not too much data, I love it. We've discussed sending high and low pressures to the Haltech. And again, in AZ, seems fully justified. 1 hour ago, Numbchux said: Make sure you actually bypass the heater core. Circulation through that circuit is what warms up (and therefore opens) the thermostat. For sure. In the short run (tomorrow?) I plan on just plumbing the added cooler inline with the heater core with no valves.
May 13, 2025May 13 Won't adding that additional cooler in line with the heater core cause cooler water to flow to the thermostat, therefore keeping the thermostat closed and keeping your engine warmer? Speaking of which, it might be worth seeing how it does with no thermostat at all (with or without the aux cooler), just to remove that variable from the equation.
May 13, 2025May 13 Author 7 minutes ago, slammo said: Won't adding that additional cooler in line with the heater core cause cooler water to flow to the thermostat, therefore keeping the thermostat closed and keeping your engine warmer? Speaking of which, it might be worth seeing how it does with no thermostat at all (with or without the aux cooler), just to remove that variable from the equation. I suppose maybe it would close the thermostat but in practice, running the heat always seems to drop the coolant temps and this setup worked in the 99 Outback. When it's running hot I assume the thermostat is all the way open no matter what. Have considered no thermostat, if it didn't require draining all the coolant I probably would have tried that by now.
May 13, 2025May 13 You'll have to bleed the system after plumbing in the aux cooler, that's as good of a time as ever
May 14, 2025May 14 15 hours ago, slammo said: Won't adding that additional cooler in line with the heater core cause cooler water to flow to the thermostat, therefore keeping the thermostat closed and keeping your engine warmer? Speaking of which, it might be worth seeing how it does with no thermostat at all (with or without the aux cooler), just to remove that variable from the equation. If the coolant bypassing the radiator (through the heater core[s] in this case) is adequately removing the heat, than the thermostat doesn't need to open. As long as there's adequate circulation, the thermostat will open when it's needed. In theory, removing the thermostat entirely can be counterproductive, as increasing the coolant flow means it doesn't spend enough time in the radiator to actually dissipate the heat.
June 4, 2025Jun 4 Author B and I worked on our white rust free California Subarus my brother bought for us. I replaced all the auto trans hoses on my Outback and replaced all the stock clamps with worm style hose clamps. One of them had sprung a pinhole leak earlier and enough leaked out on my way to work that the car stopped driving. Some of them are 23 years old. Rear axle has been staying put, not that I've driven the car a lot. B replaced the timing belt, tensioner, idlers, some of the plastic, and a cam seal on his Forester. Unfortunately the new cam seal seems to be leaking more than the old one if anything. Painted the brackets and installed the extra cooler and fan in the Impreza. Spliced a couple spades into the wiring for the passenger side fan (which kicks on second) for the small fan. Here you can see it lines up with the hood vent fairly well. Stepped up to a 12" tablet for navigation. Fit in the old mount after cutting down the springs. So far so good, glad I did it. It's summer here so we've been doing some kayaking. Have seen a lot of wildlife. This past weekend we went to the UP and did more off pavement driving than I expected. Mostly just gravel roads but some dirt trails too. One was rutted but seemed dry until I got off to the wrong side and sunk in on the passenger side. Some high lift jacking and shoveling and putting some chunks of found wood under the tires allowed me to drive out. At that time I noticed all the fans were running and I could indeed feel hot air blowing out the hood vent. At no time did the temps ever go above the middle on the gauge. It wasn't extremely hot and we weren't pushing the car too hard but definitely an improvement. We drove up some long steep grades with the AC on (also seems to be working great now) and drove a fair amount off pavement in 70-80F temps. Have a couple temp sensors that have calibration for the Haltech and the tap I need to make bungs for them, still plan on installing those in the top and bottom of the cooling system. Still waiting on fab guy to make my extra fuel tank. Even with a new carbon canister the Impreza still fills with fuel slowly/incompletely. Taking the vent hose to the carbon canister off seems to solve the problem. Might tee a long vent hose into that one or something. I drive the car enough I'm not worried about losing a lot of fuel to evaporation.
June 25, 2025Jun 25 Author A friend of ours from Houston drove up to my house a couple weeks ago and we headed up to the UP. Once we got there we stopped for pasties and ate them at a park along Lake Michigan on the edge of town. A younger guy stopped on his motorcycle and asked about the Impreza, we talked Subarus for a bit. He had just imported a 99 STI from Japan. It's funny to me, ever since I got this Impreza I've gotten a lot more questions and had a lot more people taking pictures of the car than with the other Subarus. Not sure how much of that is people's love of first gen Imprezas and how much is the fact that you don't see many turn of the century Subarus driving around anymore. We drove up to the campground along the reservoir in the southern UP. M and B showed up later. Friday we went to the rapids and then hit the mini banked oval. There was a snapping turtle at the edge of the oval. Then we wandered up to the Baraga pipeline grade. We were all entertained as usual. Hit some of the sandy stunt areas nearby and a few of the side trails. Before we got to Houghton we were on a trail in the woods where we decided to turn around. I could not get the Forester out of the ruts so we eventually put a bunch of branches and sticks in the ruts and I was eventually able to get out. Then going back down the trail I was crabbing the Forester sideways for hundreds of feet before I finally got straightened out. Headed north to Houghton and then to Gay beach. M declared it the mother of all stunt areas. Drove much farther south than we had before after crossing a narrow spit of tailings along the lake. Did some side by side uphill jumps and then decided maybe we should leave while we still could. Checked out the mine building ruins, some good post apocalyptic flavor there. Temps were solid while driving on Gay beach which is a good test of high duty cycle and low speeds. Then they crept up in the woods and we discovered one of the fan fuses was blown. The passenger side fan would turn most of the way pretty easily but there was one spot in the rotation it would get stuck. We eventually figured out there was a tiny pebble(?) stuck to the outer ring of the fan blades. We were eventually able to get it off and replaced the fuse. Later we noticed it had a slight coolant leak. We tracked this down to the small welds on the underhood heater core that attach the mounting flange to the end tanks. Rerouted the heater hoses to the stock configuration. Got up to the top of the cliff along Cliff drive. I had parked a few hundred feet back from the first overlook and when I was walking back to my car a UTV was coming up. I heard the driver blurt out “what the f--k?” when he saw the Impreza. He told me he knows people who won't take their Jeeps up the rocky climb we took to get to the top. I then walked back to the overlook and he said the same thing to the other guys. We drove to the next overlook and hard parked on the edge for some pictures. The yoopers showed up again and we talked to them for a while. “This isn't what most people from Illinois do when they come up here” one of them says while holding out his pinky finger. They had both seen different UFOs and had some story about a cave nearby that no one could find with a wall of silver and a bag of gold coins. I believed the UFO stories more. We camped at the overlook. Saturday morning we headed up to Brockway Mountain. As we pulled on to the long road going there we were proceeded by three extremely slow drivers. We pulled off on a side trail rather than test our patience following them the whole way there. This trail eventually led to a very sketchy bridge but we managed to cross it. I think it was in this area I checked one muddy stretch on foot and it didn't seem too bad so I drove through it, but I was barely able to do so and then the ruts were deeper and softer. So I told B he shouldn't come through and I didn't want to go back through so worst case we come back to that spot in a half hour. Fortunately we were able to maintain radio contact and I was able to drive around the block so to speak and meet back up with them. We eventually found a different way out of the area. At one point the temps had started to creep up in the Impreza again and a fan fuse was blown. This one was probably from the fans running while driving in deep water, we replaced it and never had the problem again. We eventually got up to Brockway Mountain from the other side. After we'd been on trails for quite a while and got back to pavement B said the Forester was shaking quite a bit. Turned out all the LR lugnuts on his Forester were loose and one was missing. We tightened down the ones we could and continued. From there we did a little more trail riding and buzzed up to the beach to camp for the night. At camp B swapped out his wheel studs on the LR hub as most of them were somewhat damaged or packed full of aluminum. Sunday we started heading back on various trails. One of them eventually became deeply rutted and I didn't think I could get through without taking off a mirror so we turned around. We came to a fairly long and deep water crossing where beavers had flooded a road. There was a muskrat swimming in it when we pulled up. I walked it and it was just below knee deep for a couple hundred feet. I drove through it in the Impreza after we removed the fan fuses. There was water over the front of the hood for a good portion of the crossing and we realized we should have stuck the gopro on. B crossed it in the Forester and then we put the gopro on the Impreza and I crossed it back the way we came and then back again to proceed. At the top of the hill right next to the stream was a cool old furnace of some kind. Later we found the beaver dam that was flooding that road. The highlight of the day was probably discovering and climbing Mt Houghton. Probably the most intimidating rocky climb we accomplished that weekend (ever in the UP?) and one of the best views in the UP once we made it to the top. Got gas and water at the Lac La Belle resort. Cashier was using binoculars to read the mechanical gas pumps. Found a silly hillclimb along the border of a wildlife sanctuary that M almost convinced me to try but ultimately we decided it should wait for a different weekend. Buzzed down to Lake Linden to camp that night so J could take a shower and we'd be closer to the portage. Monday morning we took the Bill Nichols trail basically all the way from South Range to Adventure Mountain with a few detours and stops for some stunt areas and mines along the way. M and J enjoyed the Firesteel trestles and the lookout near the top of Adventure mountain and we headed back from there. The trail west out from the Adventure mountain climb was rough and narrow but we made it through with some extra dents in the rockers and floorboards. Stopped near the end of that trail to air up and eat PB&Js. We drove down to Watersmeet together and the Impreza seemed to have some high frequency vibration that didn't go away when I put the clutch in. Cleaned some dirt out of the wheels when we stopped for gas but that didn't help. Stopped again and discovered two of the driveshaft bolts were missing from the pinion flange. I had looked before but those two must have been up. Installed some bolts and tightened them all down and had a smooth ride home. Could only run the AC intermittently on the way home or the coolant temp would creep up. Overall a good weekend, cooling issues with the Impreza are still frustrating but we all had a good time. J and M were impressed with the Impreza, especially the EZ36. J definitely enjoyed the UP and quickly got in the groove of following overgrown trails (with a surprisingly high success rate of connecting to other trails this weekend). M said it was probably his favorite off road trip we've taken, no major malfunctions, lots of stunt areas, lots of overgrown trails (which he likes). Removed the radiator after we got home and it seemed clean. I had sprayed it off at the car wash but that's usually not too effective. So I'm still a bit surprised the car was running hot on the highway. We did check the overflow at least once when it was hot and still have never seen air bubbles. After spraying the condenser out from the back with a hose wand it did become clear that a lot of the fins on it are bent over. We did go through a lot of brush so it's probably from the fan blades spinning leaves and twigs against the condenser. Should be getting a replacement today, hopefully that brings the temps back under control. Also got a pair of 80s Ford Econoline heater cores I plan on putting where the extra heater core is now for more cooling capacity. Edited June 25, 2025Jun 25 by pontoontodd
July 1, 2025Jul 1 So awesome. I love exploring that area! The time required to get my Outback or 4Runner into a condition to confidently do that is just not on my priority list right now. So I'm living vicariously through you!
July 2, 2025Jul 2 Awesome trip Tod! Not knowing the area at all, I can only imagine the distance and terrain covered. I love the comments from those that saw you up the top where ppl with jeeps wouldn’t consider going. Nothing unusual with that, it’s the same over here - more prissy 4wd owners than those that use them for what they’re designed to do. Cheers Bennie
July 11, 2025Jul 11 Author Best picture I have of the condenser fins (well OK this is one of the worst areas). Replaced the condenser, slightly different (a little shorter) but it fit alright. Made some brackets and put the worst paint job I've ever applied on them for a puller fan on the driver's side of the radiator, wired that in with the driver's side pusher fan. Also turned up some bungs for temp sensors and had someone weld them on top and bottom of radiator. Hard to see in these pictures but the puller fan has some clearance to the engine. I glued a couple pieces of sheet metal on the fins where the center of the fans had been rubbing a bit. Have had that problem in the past and this seems to solve it. Sealed the sides between the radiator and condenser so hopefully less air can go around the radiator. B did most of the fab work/fitting for a fan/heater core bracket to fit a 1980's Ford Econoline heater core (slightly bigger than the Dodge one that started leaking). Set this up so we can add a second one underneath after we remove the ABS unit. So far though, even without the extra heater core, temps seem stable even driving in stop and go traffic in 90+F weather with the AC on. And the AC works well. Cruise has not worked a few times I've driven the car in the last month or so, but then will work the next time I drive it, and usually works. One time I drove the car the clutch engagement was near the end/bottom of the travel, it's normally (before and since then) closer to the middle or top/start of the pedal travel. All other times the clutch has felt normal. After the last off road trip and I washed the car the rack had leaked some power steering fluid out of the slightly torn driver's side rack boot. Power steering was not always self centering with poor assist at low speeds for a while and the reseroir was very low but seems to be back to normal now and hasn't noticeably leaked in a while. Epoxied a couple of the studs on the hood scoop. Used a screw in the one broken off clip and clearanced the steel baffle plate so I can get at another one of the hood scoop nuts with the steel plate installed. Car has pulled to the right slightly for a long time, we've checked the alignment a few times and it always seems good. The right rear brake seems to drag more than the others. I was going to replace the caliper and then discovered one of the bolts was starting to rub on the strut housing due to brake pad wear. I unbolted both the calipers and ground clearance on the strut housings where those bolts were hitting (or going to hit). So far this doesn't seem to have solved the problem but I might drive it a bit more first.
July 12, 2025Jul 12 Oh wow, didn't foresee that issue with brake-to-strut clearance! Would be interested to see another angle of that.
August 4, 2025Aug 4 Author B and I worked on all three of my Subarus and his blue Forester a few weeks ago. Bunch of relatively minor stuff but I went through the front struts on the white Outback. They've been making some clunking/spring shifting noises when turning tight at low speeds so I suspected the steering bearings needed a cleanup. I replaced one and regreased the other, haven't noticed those noises since. While I had them apart I noticed the bump stops were split. Haven't seen this on our other cars but this is the only set where we made the bottom of the body bigger to allow the bumpstop to expand to give it more travel. Perhaps now they can expand too much. Regardless, I replaced them. We got the Ford van heater core and electric fan installed on the Impreza. Tried to figure out which front wheel bearing (I assume) on my 2001 H6 OB is making noise but even using B's multi microphone noise identifying system we still can't tell. Neither side is loose or seems to get hot but at least one of them is making a lot of noise. Definitely louder or quieter when cornering so I assume wheel bearing. We replaced one of the rotors we thought was pulsating figuring it'd be an easy try and it maybe pulsates less but did nothing for the noise. The next weekend we went to the UP with some in laws/friends and went trail riding one day in the Impreza and Outback. Stopped at a gas station after some trail riding and I noticed the temps on the Impreza were creeping up so we pulled over, fuse and relay seemed good but driver's side fans were not running. Without the AC on temps didn't creep up too much even in the sand. I made the mistake of letting a novice drive the white Outback without me in it. Then I noticed the Outback was pulled over with steam coming out of the front end. Driver claims the brakes weren't working. It has some serious lower front end damage after going off the trail a bit and hitting a log. Lower radiator support and skid plate and bottom of engine very smashed. I think the front fenders, lights, crossmember, and possibly hood are still all in the right spots. In the long run probably the biggest downside is I’ll have to replace the head gaskets on my spare ez30. As we were pulling the car back on to the trail, I realized that we’d lost the rear bumper cover somewhere. Hooked the tow bar, lights, and safety chains up and started towing it north on the trail. Not too far down the trail we got to a big steep drop but it didn't look terrible so we went down that. Kept it under 20mph, looked it up later and that's apparently the safe flat towing threshhold for the 4EAT for a max of 30 miles. Still curious what exactly fails if you flat tow it too fast for too long. The rest of the trails weren't much of a problem and we eventually got back to pavement and aired back up the tires on the Impreza to 40psi. Flat towed white Outback to the closest town and asked the guy at the grocery store if it'd be OK to park it there overnight. He said one night would be fine. I couldn't convince others to retrace our steps and retrieve the rear bumper cover mainly since it was going to be dark soon. Most of the rental, almost all Uhaul, places were only open a few hours on Saturday so I either had to wait for them to open or by the time they were open I wouldn't have been able to get to them before they closed, had to talk to one guy for a bit to figure out how to get them to rent me a tow dolly. I did a test drive of my dad’s 1987 full size 3/4 ton Dodge van, seemed to be running rough but not terrible. None of my primitive engine tuning skills seemed to help. After a lot of calling around I drove the van an hour to U haul to pick up a tow dolly. On the way there the engine starting making noise and I looked at the oil pressure gauge (blocked by my hand in a normal 10-2 driving position) and it was reading nothing. Pulled over, after a bit of looking around figured out one of the oil pressure sensors had started leaking badly. We've had this happen on a different full size Dodge van probably 20 years ago. Fortunately there are two sensors on this one going into a tee so I was able to take that apart and just put in one sensor. Dumped some engine oil in and proceeded. At the rental place the lights on the tow dolly didn't work. Wasn't getting power at the four pin connector but had power at the six pin connector (both on van). They of course had just run out of adapters. So I drove to the local Ace and picked one up, drove back, plugged it in, right side light on tow dolly not working. Hooked up to another tow dolly with functional lights. Drove about two hours back up to where we'd left the Outback. During this driving I'd realized I didn't have the keys to the white Outback. But I did have a coat hanger and a screwdriver so I was able to get in. Fortunately for whatever reason in that car you can shift it into neutral without turning the ignition on. Lined the tow dolly up with the car and backed the van up to it. Pulled the car onto the tow dolly with a come along (hand winch). Strapped it down, looped safety chains around the control arms. Then I realized I should have unbolted the rear driveshaft sooner but I was able to just get all four bolts. Was able to strap the driveshaft away from the rear diff so it didn't rub (I assume). Towed it about 1.5 hours back to the cabin. Chocked the rear wheels with some chunks of 4x4 and set the parking brake and drove the tow dolly out from under the car. Sunday morning I drove the tow dolly back and left it at the rental place, a two hour round trip. We drove the van back in addition to the two other cars we drove up there that still ran. Impreza temp gauge was right in the middle even with AC on in 95F weather on the highway. After returning home and tracing the fan wires from the fuse box to the fan I found that one of the pins for the main driver's side fan had pulled out and the connector looked melted. It would still occasionally run when I was pushing or pulling on the wires so I think it was just loose in the connector. Replaced the stock connector with spade terminals and heat shrunk/taped/zip tied everything back up, they all seem to run now. Drove Impreza to the cabin the following Friday morning. Strapped RF of bumper to engine. Removed front CV axles and replaced with loose OB Cvs I found in the basement. Unloaded flat towing equipment and put in Outback. Saturday morning I drove to the end point of our trail riding, filled up with gas, and retraced our steps backwards in search of the rear bumper cover. I figured I now had most of the rest of the day to kill so I'd do some mild trail riding/exploration on the way back. Impreza seems to spin the tires with less forward traction with the tires at 45psi as I had them that day than the 25psi I'd normally drop them to if I'd known I'd be trail riding as long as I did that day. I tried to do a big loop south of where I found the bumper cover. At the start it seemed a bit narrow/overgrown but there was a Forest Service trail open sign so I decided to go for it. Parts of it were very overgrown. Eventually there was a large tree that had fallen blocking it. I drove around the other half of the loop and got back to the fallen tree. There was no way I was going to do anything about it without a chainsaw, which I did not have. Checked out a stunt area I'd found on the satellite that had one big hillclimb and drove a side trail near the top of it. No intention of trying something like that solo so I moved on. Went to the end of a road on the map, figuring I might as well see where it went, turned out it kept going for miles with various side trails, none of them on my map at all. Went by a few old cabins along a river that looked like they hadn't been used in years but in decent shape. Drove down some roads that definitely seemed like they were just for logging, some of the steeper ones were even pretty nicely graveled. Eventually I was heading south on a nice wide dirt/gravel road and getting closer to a paved road we've been on many times. There were a couple of large boulders in the road but they could easily be driven around. Didn't see any signs on either side but decided not to drive past them. Also I think where this road comes out to pavement there might be a large berm. There was also a wide smooth road heading north from the “blocked” road but it had tall grass growing in it so I decided to skip that for the day and head back the way I came. On the way back north as I was heading by the old cabins I caught up to some locals driving UTVs. Each one had a guy in his 70s and one in his 20s. The younger guys were pretty entertained by the Subaru and they all kept asking how it did. I told them the trails around there were no problem for it. I asked about the cabins and they said the one we just passed by used to be theirs, they had a year by year lease with the forest service. Then it was declared a scenic river and hundreds of people lost the use of their cabins. Where we stopped was another one with a similar story. I asked about the logging roads and the big rocks and they said the logging company that has the contract for that section of forest tries to keep people out from tearing up their gravel(!) logging roads. They pulled over to let me by and I kept driving north until I eventually found a different way out. I got back on the highway and found a waterfall I'd seen on a 40 year old Michigan county map. The “trailhead” is a gravel spot big enough for one car along a gravel road with a rope tied around a few trees heading into the woods. No sign or anything. Hiked into the woods, trail was easy to follow, found the waterfall, pretty cool. Near there I went down a dead end forest road and encountered this turtle. When I got back to the cabin I set up the flat towing hardware and did a test drive. Seemed to do OK but tire was still rubbing on the tape I'd put on the end of the front bumper so I cut that off with the recip saw. Had some dinner and went to bed. Got up Sunday morning, packed up the car, checked fluids, aired up the tires in the Outback, and headed south. Flat towing went as smoothly as possible. Impreza has good power and bigger brakes than stock which helps. Temp gauge was right in the middle all weekend, even when towing, climbing sandy hills, AC on, etc. Left tow bar connected, drove Impreza in garage, disconnected tow bar, slid rear of Impreza sideways with a floor jack, drove Impreza out, pushed Outback in garage with Impreza.
