pontoontodd Posted November 30 Author Share Posted November 30 B and I worked on the secondary fuel tank for the Impreza. I pressure tested it and flushed it out, seems like it doesn't have any leaks even at 30psi. I got the mounting flaps carved up so it fits and matched up the bumper mount holes. We had to do a little more hammering in the spare tire well. We came up with a plan on how we want to mount the fuel pumps and run the hoses. I need to get another pump, some hoses and fittings. Going to try to get wire connectors for the ABS wires so we can use those for the fuel pumps since they're already running front to back and will never be used for ABS again. B replaced the cabin air filter and cleaned out the airbox and blower fan, they were all loaded with debris. He also traced the brake lines under the hood and we came up with a plan on eliminating the ABS module and plumbing the left/right steering brake from the black Outback. 1 Link to comment Share on other sites More sharing options...
slammo Posted December 1 Share Posted December 1 You think those ABS signal wires are heavy enough to run a fuel pump, or are you just using them to trigger a relay? Good thing you have a cabin air filter. Link to comment Share on other sites More sharing options...
pontoontodd Posted December 1 Author Share Posted December 1 5 minutes ago, slammo said: You think those ABS signal wires are heavy enough to run a fuel pump, or are you just using them to trigger a relay? Good thing you have a cabin air filter. Good point I'll take a look at the gauge of those wires. Won't be under much pressure so according to the internet it'll draw 4-5 amps and even 22 gauge wire should be adequate. Definitely not getting any relays involved. Thanks again for the cabin air filter tip. We were discussing how full of junk the evaporator would be without it. Like the one on the black Outback was. Link to comment Share on other sites More sharing options...
slammo Posted December 1 Share Posted December 1 If you're planning on using a full-pressure fuel pump to deliver to the engine bay, the ABS wiring definitely won't be adequate. Plenty of people say the stock fuel pump wiring isn't adequate lol. But if you're just using a transfer pump to move from aux to main tank, maybe the current draw will be low enough. Link to comment Share on other sites More sharing options...
el_freddo Posted December 1 Share Posted December 1 I’d set it up as an aux Fawcett pump to transfer fuel from the aux tank to the main tank. Far simpler than trying to run a second high pressure pump and work out valves/relays to switch fuel lines to avoid back feeding and sort out the redirection of the returning fuel (unless you run a deadhead setup with zero fuel return). This sort of thing is something I want to do with my brumby under the tray behind the cab where there’s a decent cavity. Link to comment Share on other sites More sharing options...
Numbchux Posted December 1 Share Posted December 1 Personally, I don't think I would trust ABS wires. Small gauge, and twisted pairs. Maybe use all 4 rear ABS sensor wires as positives, and then ground to the body Using this calculator, default voltage drop and temperature, 14v, 5a, 12ft run, they recommend 14g. Alternatively, 22 g wire has about a 20% voltage drop. Link to comment Share on other sites More sharing options...
pontoontodd Posted December 1 Author Share Posted December 1 19 hours ago, slammo said: If you're planning on using a full-pressure fuel pump to deliver to the engine bay, the ABS wiring definitely won't be adequate. Plenty of people say the stock fuel pump wiring isn't adequate lol. But if you're just using a transfer pump to move from aux to main tank, maybe the current draw will be low enough. 12 hours ago, el_freddo said: I’d set it up as an aux Fawcett pump to transfer fuel from the aux tank to the main tank. Far simpler than trying to run a second high pressure pump and work out valves/relays to switch fuel lines to avoid back feeding and sort out the redirection of the returning fuel (unless you run a deadhead setup with zero fuel return). This sort of thing is something I want to do with my brumby under the tray behind the cab where there’s a decent cavity. 1 hour ago, Numbchux said: Personally, I don't think I would trust ABS wires. Small gauge, and twisted pairs. Maybe use all 4 rear ABS sensor wires as positives, and then ground to the body Using this calculator, default voltage drop and temperature, 14v, 5a, 12ft run, they recommend 14g. Alternatively, 22 g wire has about a 20% voltage drop. Thanks for all the advice on this. Good to have someone else looking over my shoulder making sure to at least warn me when I'm doing something I shouldn't. Yes, we're just using these as transfer pumps. One for each direction since they all seem to have a check valve built in, the only reversible ones I can find are pretty expensive. 14ga seems overkill for 5A. I use 16ga for almost everything. Will take a closer look at the ABS wires for sure, I like the idea of just using them for power and then grounding the other terminal of the pumps. Will probably see what other wires are running back there we're no longer using too. On the topic of wiring, any suggestions on a relay/fuse good for 80+ amps? Want to put both the pusher fans on the secondary fan circuit. Figure I'll switch the big relay I add with the stock wiring/relay. Those fans pull almost 30A each (over 30A when submerged in water apparently). Planning on putting both the puller fans on the primary fan circuit, they are small and don't draw as much so I should be good there. Currently have one of each on each circuit on 30A fuses. 2 Link to comment Share on other sites More sharing options...
Numbchux Posted December 1 Share Posted December 1 The reason for 14g was the distance more than the amperage. I used 12 ft, it's erring on the side of caution, but probably a good idea. If 5A is peak, not continuous, 16g is probably fine. But you'll start seeing voltage drop, which can be hard on motor contacts/brushes. The cleanest and shortest path from the alternator would help that. I looked up the stuff I used on my 4Runner. I'm using these in different Amperage ratings, but they're available in many variations. Maxi Relay + connector and terminals, here's an 80a version of the relay https://www.waytekwire.com/catalog/relays/mechanical-relays-and-connectors/cit-relay-and-switch-a3k1ccq12vdc1-6-maxi-relay-spdt-80a-12vdc-max-145vdc- Surface mount manual reset breaker https://www.waytekwire.com/catalog/circuit-breakers/high-amp-circuit-breakers/eaton-s-bussmann-series-184080f-01-1-surface-mount I buy a lot from Waytek, or Mouser. Link to comment Share on other sites More sharing options...
el_freddo Posted December 2 Share Posted December 2 Transfer pumpS? Why plural? Only need one. Link to comment Share on other sites More sharing options...
Numbchux Posted December 2 Share Posted December 2 8 hours ago, el_freddo said: Transfer pumpS? Why plural? Only need one. "One for each direction" I remember him saying he doesn't want to have to separately fill the aux tank. He'd like to flip a switch while filling the main tank to transfer it up to the aux tank. And then activate the second pump to transfer it in the other direction when needed. 1 Link to comment Share on other sites More sharing options...
el_freddo Posted December 3 Share Posted December 3 Yeah righto. That’s against our Australian Design Rules (ADRs) over here. Can’t pump fuel between tanks when refilling. Not saying it isn’t done, just that if you’re found out or cause a fire somehow you’ll be raked over the coals for it. And a Fawcett pump would be bloody slow - about 2L per minute transfer rate. Would be better off plumbing in a fill tube between the main tank and auxiliary tank with a one way valve towards the aux tank. There would need to be a vent line to the filler neck to help with the transfer. Or just have a secondary fill pipe off the filler neck to the aux tank so it fills after the main tank is full. Many ways to do it without over complicating things. Our Pajero (Shogun/Montero) sports a dual filler neck behind the filler cap so we can choose to fill the main tank or the auxiliary tank. This secondary filler pipe follows the main tank until it needs to head to the aux tank. Its pretty awesome the first few times being empty on the fuel gauge, then hitting the aux pump switch and watching (from time to time) the main tank gauge go from empty to full without pulling over 1 Link to comment Share on other sites More sharing options...
pontoontodd Posted December 3 Author Share Posted December 3 In case you hadn't noticed we have a lot more options for vehicle modifications than Australia. These pumps are 255lph. Assuming this extra tank is 10 gallons that would take about nine minutes. Could have it going before you even start filling the main tank. Worst case you fill up the main tank, pull off to the side for ten minutes, then go back to the pump. Guess I'll find out. I think this will be the simplest way. One hose connecting the tops of the tanks for venting. One hose connecting the bottom of the secondary tank going down through one of the access panels and down to the bottom of the main tank. Have two fuel pumps side by side teed into that bottom hose one pointing each direction. One of those pumps could run the engine in a pinch. Definitely looking forward to the magically increased range. 1 Link to comment Share on other sites More sharing options...
el_freddo Posted December 4 Share Posted December 4 19 hours ago, pontoontodd said: In case you hadn't noticed we have a lot more options for vehicle modifications than Australia Yeah I’m well aware of this. In some ways I’m jealous. And in other ways, seeing what dipsh!ts have made regardless of our modification laws, part of me is glad we’re not a free for all! Sounds like you have it licked, should be good once it’s all setup! Link to comment Share on other sites More sharing options...
pontoontodd Posted December 14 Author Share Posted December 14 (edited) Last weekend we did some work on B's Forester. His carpeting has been getting wet on the driver's side so he pulled off the fender, wipers, carpeting, etc to investigate. Eventually noticed part of the floor had some small cracks in it. After a little tar removal and poking he discovered about a 2-3" square section was basically rusted to nothing. So he cleaned up the sheet metal around that and welded in a fresh piece. Meanwhile I went through his front struts. Main task was replacing the bushings in the strut bodies. This pair of struts may have been on the black Outback, regardless they have seen a lot of abuse and the bushings were badly worn. Replaced the shock oil in one and replaced a few shims that were maybe slightly cracked. Verified our notes on the valving were accurate. Replaced some other boots/seals, repacked steering bearings with grease, etc. He says it's noticeably more solid now. Yesterday we worked on my Impreza. Still seemed like the radiator and condenser were pretty dirty so I got a long nozzle air gun and tried a few different modifications, this seemed to work the best. Plugged the end (M6x1) and drilled a .15" hole in the side. Then you can get that between the radiator and condenser and blast out one or the other. We got quite a bit more debris out. Replaced the steering rack. It was leaking badly from the driver's side. This would then quickly degrade the boot which would split open. I was refilling the reservoir about once a week by the end of the summer. Fortunately M had put a rebuilt rack in his (my old) blue Impreza a couple years before we parted it out so that one is (hopefully) still pretty fresh. We pulled the skidplate and replaced the rack. In the course of swapping that out I discovered that the bottom U joint on the steering shaft is nearly locked up in one direction. After putting everything back together, you can feel the tight spots in the U joint when turning the steering wheel with the front end off the ground. So I'll have to replace that. A bit disappointed, it's only been in there a couple years, new from Subaru (and extended by me). We had a bit more time and the front end was already off the ground and wheels and tires were off so we decided to go through my front struts. Didn't take too long, verified the valving mainly, added a bit of oil, replaced a wiper, regreased the steering bearings. We intend to go through our rear struts sometime this winter too. Still working on getting material for all the 6MT low range parts so we have a couple complete assemblies (including one for B). We should really tear down the one that was in the black Outback sometime and confirm the failure mode there. I think I have all the plumbing bits I need for the extra fuel tank. Need to get some electrical bits for that and the fan rewiring. We did take a peek at the ABS sensor wires and they're not super small, maybe 20 gauge, we think two of those will be adequate to power a fuel pump. Edited December 14 by pontoontodd 2 Link to comment Share on other sites More sharing options...
slammo Posted December 15 Share Posted December 15 Does a first gen Forester steering u-joint fit without being lengthened? Link to comment Share on other sites More sharing options...
pontoontodd Posted December 15 Author Share Posted December 15 53 minutes ago, slammo said: Does a first gen Forester steering u-joint fit without being lengthened? I think it was too long but I should check. Link to comment Share on other sites More sharing options...
pontoontodd Posted 18 hours ago Author Share Posted 18 hours ago One of the two main projects I wanted to do this winter on the Impreza (other being the gas tank) is installing the cutting brake from the black Outback. I made this bracket to bolt it next to the parking brake. B replaced the ABS unit with a couple of tee fittings. The one for the fronts is our solution for those lines. B rerouted the braided stainless line we had in the black Outback from the master to the cutting brake, it was still in good shape. Bolted to the cutting brake. Bolts down using two stock fasteners on the top of the driveshaft tunnel. It backed right up to the storage compartment in the center console so I plugged the normal feed location and plumbed the line from the master to the top (former bleeder location). This lines the handle up with the coin holder in the center console (haven't cut that out yet). Handle will be bent too. I made and ran new braided stainless lines from the cutting brake to the bulkhead fitting under the back seat that feeds the stock rear brake lines. We spent quite a bit of time and brake fluid trying to bleed it. I eventually got it to the point that it was driveable and I could lock up the left rear tire but the brake pedal and cutting brake are definitely spongy. Related to this mod was adding another heater core under the one I've been using. Hoping it will give me a little more insurance against overheating. Plan is still to put the two small puller fans on the main circuit in hopes that the pusher fans don't have to run much. They seem to shred plant matter and jam it into the condenser and radiator. B and I did some mockup and made a couple brackets to bolt the second one on underneath the original. That hose linking the two is definitely not ideal but I don't think it's closed off and will probably open up under pressure. I do plan to put a barbed elbow in there to help though. Should make sure the one closer to the fan is getting coolant first too. Still gathering a few connectors for rewiring the fans and extra fuel pumps. Link to comment Share on other sites More sharing options...
el_freddo Posted 9 hours ago Share Posted 9 hours ago (edited) The cutting brake? Not heard that term before. I’m assuming it’s a device to lock up one wheel at a time on the rear? Eg: push forward to lock the right rear, backwards to lock the left rear, have I got this correct? Poor man’s locker 😎 Edited 9 hours ago by el_freddo Link to comment Share on other sites More sharing options...
pontoontodd Posted 3 hours ago Author Share Posted 3 hours ago 5 hours ago, el_freddo said: The cutting brake? Not heard that term before. I’m assuming it’s a device to lock up one wheel at a time on the rear? Eg: push forward to lock the right rear, backwards to lock the left rear, have I got this correct? Poor man’s locker 😎 Yes except I have mine plumbed the opposite from your example. It sort of works as a locker but mainly it's used as a steering brake. It's my favorite kind of steering brake. This shows how we ran the lines and how close the brake is to the center console compartment. Center console reinstalled, handle lines up perfectly with one of the coin holders. Mirror adjustment switch doesn't go all the way back in. Ran the lines under the carpet and through the stock grommet under the back seat. Connected them to the bulkhead under the seat. I tried a different bleeding procedure which ultimately didn't seem to be an improvement. Link to comment Share on other sites More sharing options...
