My '94 Loyale: Subaru Utility Wagon
The Closest Screen to fit i found is the Sony PSP Slim (480x272 LCD)
but how would i use that to display video ?
  • Replies 131
  • Views 22.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I do harnesses and have ej adapter plates nice wagon! Looks clean!
  • Jawn, I'm located pretty close to you and I have a pair of Mill Supply rocker panels NIB for a Loyale that I have no use for currently. It looks like you could use them and I could definitely be persu
  • here are some new higher quality pictures of my loyale with bigger wheels. i forked over some dough forthis new Camera.   and some good News, my 2" lift Kit is on the way ! from Anderson Design &am
Posted Images
Jawn, I'm located pretty close to you and I have a pair of Mill Supply rocker panels NIB for a Loyale that I have no use for currently. It looks like you could use them and I could definitely be persuaded to give them up pretty cheap. If you want them let me know.
Either way, we should do a subie meet up. I'd love to see your xt6 since I've never actually seen one in person, and I can bring the Ski Wagon or BRAT to share.
yeah we are close, about 2 hrs. i would like to do a meet-up.
rocker panels i really cant use now, i have patched my loyale for inspection.
My Xt6 is currently off the road for winter, he wont be on the road for a long while.
Nah, your only about 45 minutes away. I find myself in Franklin fairly often.
Off the road already? You're even more paranoid about rust than I am! No snow or salt yet, so I'm not putting the Ski Wagon or BRAT away for a few weeks probably.
If I head up to Franklin any time soon, I'll let you know ahead of time and maybe we can do a quick meet. Otherwise we should meet up in the spring when all the cars are out!
yeah that would be good. 45 min not bad. i could show you my XT6 which is out in the boonies at my aunts in her garage.
Come to Jersey! =P lol
I'll be sure to keep you guys in mind the next time I'm out that way.
(Sorry to just jump in here, but yous guys locations are in PA, now WA or OR so I got excited)
LED upgrades.
Front clearance lights and marker lights are now LED.
Very Very Bright !
LED upgrades.
Very Very Bright !
Those are the only lamps in my car that aren't LED (well, minus dash, interior, and headlights)
You guys got snow?!
You guys got snow?!
i am upgrading to LED at very slow rate. (step 1 of modernizing)
yeah we got snow not a lot but its snow.
It's not a bad idea to be honest. Just be sure you use bulbs that don't have the circuit boards exposed, as they get moisture in them and corrode easily. Just as well, for the turn signals, be forewarned that the relays in the car do not support these bulbs; the result is the blinkers flashing at a faster rate (as if you had a light out). Find some ballasts to correct it or simply ignore it.
yeah use less electricity and are brighter, i get my LED from SuperBrightLEDs.com and the other 2 at walmart.
i am aware of the Turn signals they have an L.E.D Flasher for my Loyale and i must make sure the bulbs are the same color as the lens. amber for turnsignals and red for brake lights.
is there anything i could use to replace it ? another clock ? something else ?
i removed the clock and those wires were already cut, i have no idea if it hold the time, it doesnt light up to well.
Times like these, I'm thoroughly impressed by Subaru's bare bones digital clock in the speedometer cluster (for the 90's impreza's).
:D Go get yourself a nice Kmart Special Seiko, or some other fancy looking analog watch. Take the straps off, and mount in the dash.
Infiniti mod FTW haha
Also, I second Bratman18's recommendation of user Gloyale
http://www.ultimatesubaru.org/forum/user/17152-gloyale/
He got me out of a tough bind, when no one else would step up. Could not have asked for better help, awesome guy!
Edited by SnatchedHatch
Customize my Grill..
so i had an extra grill laying around ( from subie actually)
i thought about customizing it. so far the plan is to cut the center out and install Mesh.
Not done yet..
Installed some LED Bulbs (not yet done)
Left is LED(RED Bulb) Right is Stock
has anyone ever made a monitor for MPG's work for the Loyale ?
thought it would be great to have a monitor in the clock display
I am working on this now using a factory trip computer. I am not sure how far I will make it, but the basic system is running on the bench including outside temp ;)
Got some Rims for my Loyale.
slowly yet surely getting hem to fit, sucks when you can only do work on the weekends.
Preview:
Looking great man! Itll be so much easier to find tires for them with thous!
Patrick
Bought a new Stereo..
a Digital Media Receiver ( does not play CDs)
it is much shorter than the Previous Cd player, fits in as if it was stock.
so worth the $40 !
  • 1 month later...
  • 4 weeks later...
question, is it possible to install EJ221(135hp) heads onto an EJ222 (142hp) and would the EJ222 still have 142hp ?.
Yes they'll bolt on no problem. But if you go from phase 1 to phase 2, then you'll need the intake manifold to match the heads. Not sure on the power. I'm sure it would be barely noticeable if at all.
good to know they bolt the same.. if i can get the EJ222's power with the older EJ221 heads i'd go that route for my EJ swap..
i noticed how much better the EJ222 feels over the EJ221 when i had my 99 obs, i thought it was an EJ25 ! lol....
Update
Scubie is now sitting on all 4 14"s
6 lug nearly complete, stud need welded (out of gas in welder) :(
missing 2 studs
