2010 forester heater core replacement?
I've tried everything suggested in another thread to get my heater working and nothing helped, so the next step is to replace the heater core.  What will I be getting into with that project?  Can I do it without tearing the whole dashboard out?  Any tips or tricks to make it easier?  Thanks!
Never heard of one plugged to the point it would not produce heat.
Seems much more likely it is air in they system, standard burp is elevate the front of the car and leave it running with the radiator cap off, then top off.
Mallory,
I wouldn't think that a 2010 could be rusted/gunked-up enough to require pulling it out. As uniberp1 has stated, your first course of action is to follow his lead. These subie engines can be difficult to remove air in the coolant unless the front of the car is elevated to allow burping.
I have pulled the complete dashes out of cars in the past, and its not fun, is very time consuming, and there are too many places where one time assembly pieces can break off locking tabs, making reassembly more difficult, and in some cases, more than a little expensive to replace.
You should disconnect the heater hoses and back flush the heater with a hose and funnel.
I tried back flushing already and it didn't help.  I had another thread on this, but my problem is my heater is only producing heat on the driver's side.  I've tried bleeding the air out of the system too, but I didn't try it with the front of the car raised up.  That idea makes good sense, so I'll try that next.
I'm willing to try about anything if I can avoid pulling the heater core out!
If it's producing heat on one side of the car then the core isn't the problem. It's some type of flapper door actuator problem. And yes depending on the problem it may require substantial dissasembly of the dash.
Yup.  It's gotta be a problem with one of the step motors that controls the air doors that direct hot air.
you'd really need a good diagram of the system on your car.  then you could identify which door and motor would be responsible for directing air to the pass side.
Could be a disconnected linkage, or could be a dead stepper motor.
So glad my 98 Forester uses cables for all that.
