October 1, 20205 yr 1 hour ago, Ez30D-4.444 said: then (B56) pin 1 VVS signal line I have to study this a little bit, because what I see in the wiring diagram is B56 pin 1 is 12v from Fuse # 4.
October 1, 20205 yr Author You are more than likely correct. Thank you. Vehicle Speed Sensor VSS pardon my typo... *hehe* That forum was working on a 31pin plug, this one is 24 pin. After checking the schematic I'm seeing Green/Black in Pin 13 on B56, is the VSS on this 24 terminal EZ30D TCM plug. ground that one, and I should be "rolling"? Assuming others are good. ill know more tomorrow midday. Edited October 1, 20205 yr by Ez30D-4.444
October 1, 20205 yr Author not out of the woods yet. TBF I may have to put more effort into finding or recreate the Clutch peldal sensor harness he was talking about in that forum.
April 24, 20214 yr Author is there any Professionals in Oregon or near by, Washington/North California. Who Specialize in wiring Automatic to Manual ECU wiring harnesses? I know of one in Auburn Washington, about 500 miles away from me. Does anyone know of Professional automotive business closer to South Oregon, that can get that job done. for the record I came close.... no cigars.
April 24, 20214 yr 10 hours ago, Ez30D-4.444 said: is there any Professionals in Oregon or near by, Washington/North California. Who Specialize in wiring Automatic to Manual ECU wiring harnesses? I know of one in Auburn Washington, about 500 miles away from me. Does anyone know of Professional automotive business closer to South Oregon, that can get that job done. for the record I came close.... no cigars. 4.8 stars, this is who LT is referencing I’m not referencing this shop but in general repairing unfinished projects is not most friends of mine ideal work - often encounter numerous time sucking issues that the original owner doesn’t understand or like. What might be a simple vacuum hose or wire issue might take them 4 hours to find. Lose-lose situation for them. They charge $50 and loose money to keep customer happy or they charge hourly rate for a total of $500 and customer is POed and gives tons of negative publicity. one of my friends had a sign in his shop: ”Repair - $80/hour you offer advice - $100/hour you bring parts - $120/hour you want to watch - $140/hour you already worked on it - $160/hr” As it was he was an extremely generous guy but point still stands https://www.google.com/search?q=superior+portland+oregon+subaru&client=safari&channel=iphone_bm&source=hp&ei=-nWEYP3uN8Sl1QGQqJLgCg&oq=superior+portland+oregon+subaru&gs_lcp=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&sclient=mobile-gws-wiz-hp#trex=m_t:lcl_akp,rc_f:rln,rc_ludocids:9281476762617538388,ru_lqi:Ch9zdXBlcmlvciBwb3J0bGFuZCBvcmVnb24gc3ViYXJ1IgOIAQFIzZb0k-2AgIAIWjEKBnN1YmFydRADGAAYARgCIh9zdXBlcmlvciBwb3J0bGFuZCBvcmVnb24gc3ViYXJ1kgEQYXV0b19yZXBhaXJfc2hvcJoBI0NoWkRTVWhOTUc5blMwVkpRMEZuU1VOdmVtOWZlRTEzRUFFqgEOEAEqCiIGc3ViYXJ1KAA,trex_id:gl9nOe
April 24, 20214 yr near Portland - http://superiorsoobie.com/ I can only dream about having a shop like that nearby.
April 25, 20214 yr 22 hours ago, 1 Lucky Texan said: near Portland - http://superiorsoobie.com/ I can only dream about having a shop like that nearby. Thanks good grief my link was 10 miles long.
