No crank EZ30D + entire Wire harness Swap into 1997 2.2L coupe.
1 hour ago, Ez30D-4.444 said:
then (B56) pin 1 VVS signal line
I have to study this a little bit, because what I see in the wiring diagram is B56 pin 1 is 12v from Fuse # 4.
  • Replies 60
  • Views 10.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • jonathan909
    jonathan909
    You omitted the "you want to help" rate.
  • If you unplug the security module the starter will not work. That disables the Interrupt Relay. There are two pins that have to be connected to bypass the Interrupt Relay contacts. See the wiring diag
  • Connector B59 Pin 2 is WB and Pin 6 is WG. Both should be large gauge.
Posted Images
Page not responding.
Edited by Rampage
Edited by Rampage
You are more than likely correct. Thank you.
Vehicle Speed Sensor VSS
pardon my typo... *hehe*
That forum was working on a 31pin plug, this one is 24 pin.
After checking  the schematic I'm seeing Green/Black in Pin 13 on B56, is the VSS on this 24 terminal EZ30D TCM plug.
ground that one, and I should be "rolling"? Assuming others are good.
ill know more tomorrow midday.
Edited by Ez30D-4.444
not out of the woods yet.
TBF
I may have to put more effort into finding or recreate the Clutch peldal sensor harness he was talking about in that forum.
  • 6 months later...
is there any Professionals in Oregon or near by, Washington/North California. Who Specialize in wiring Automatic to Manual ECU wiring harnesses?
I know of one in Auburn Washington, about 500 miles away from me. Does anyone know of Professional automotive business closer to South Oregon, that can get that job done.
for the record I came close.... no cigars.
4.8 stars, this is who LT is referencing
I’m not referencing this shop but in general repairing unfinished projects is not most friends of mine ideal work - often encounter numerous time sucking issues that the original owner doesn’t understand or like. What might be a simple vacuum hose or wire issue might take them 4 hours to find.  Lose-lose situation for them. They charge $50 and loose money to keep customer happy or they charge hourly rate for a total of $500 and customer is POed and gives tons of negative publicity.
one of my friends had a sign in his shop:
”Repair - $80/hour
you offer advice - $100/hour
you bring parts - $120/hour
you want to watch - $140/hour
you already worked on it - $160/hr”
As it was he was an extremely generous guy but point still stands
https://www.google.com/search?q=superior+portland+oregon+subaru&client=safari&channel=iphone_bm&source=hp&ei=-nWEYP3uN8Sl1QGQqJLgCg&oq=superior+portland+oregon+subaru&gs_lcp=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&sclient=mobile-gws-wiz-hp#trex=m_t:lcl_akp,rc_f:rln,rc_ludocids:9281476762617538388,ru_lqi:Ch9zdXBlcmlvciBwb3J0bGFuZCBvcmVnb24gc3ViYXJ1IgOIAQFIzZb0k-2AgIAIWjEKBnN1YmFydRADGAAYARgCIh9zdXBlcmlvciBwb3J0bGFuZCBvcmVnb24gc3ViYXJ1kgEQYXV0b19yZXBhaXJfc2hvcJoBI0NoWkRTVWhOTUc5blMwVkpRMEZuU1VOdmVtOWZlRTEzRUFFqgEOEAEqCiIGc3ViYXJ1KAA,trex_id:gl9nOe
