Updated oddcomp's MS n' EDIS fuel/DIS
Thanks for keeping us posted...I am very interested in your project. But I am also probably a long way from actually spending time and money to try it myself.
Scott
  • Replies 148
  • Views 19.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • GeneralDisorder
    GeneralDisorder
    I only know that I've done fuel injection every way you can imagine with pretty much every stand alone option out there and the LINK stuff saves a lot of time and frustration. Adding trigger wheels an
  • Someone rang?
Posted Images
well for a parts cost count
the controller be it a full megasquirt is about 150 i think but tats fuel and ignition after modified
or just the ignition controller i think thats about 50 ish or a bit more maybe after its all done and built
junk yard parts
sensor
ignition module
trigger wheel
usually runs me around 25-35 ish a set depending ont he mood of the guy behind the counter
coil pack... well new is better in my opinion
the machined crank pulley.. well thats someone elses department so i can't
actually suggest a finished price
if you do it pice by pice
its easy to afford
if you try and do it all at once.. well i never could have done it then :)
Dude, that is SO what we EA82T guys need. GREAT work in keeping us posted!
Variable timing is what will make our engines come alive. Good work oddcomp. I look forward to meeting you at WCSS... I assume you will be in attendance.
providing all goes well
mind you this is not variable valve timing
just straight up ignition timing that is totally adjustable
and totally accurate no gear/belt slop and way less wear ont he drivers side timing belt
i am sure i mentioned it
but here goes again
on msn
oddballcomp@hotmail.com
on aim or yahoo
just plain oddcomp
got a question? got a suggestion ? wanna tell me to give up? :) go ahead :)
well this figures....
went to remove the ring from my crank pulley
got almost all of it off... in pieces.. not a problem
and then the dam crank pulley itself breaks apart ..
so dam close.....
now i gotta get a new pulley made somehow this time so i don't have to weld it
this... really sucks get so close to saying yay !!!! and poof....
so maybe i won't have it done by wcss.... oh well the ground work is laid for anyone who wants to pick it up
you know you coulda just removed the roll pin from the pulley and the outer belt drive sprocket and rotated the crank pulley to the correct position..to match your timing specs.. 70 ftlb of torque is MUCH Much more than is needed to keep the pulley from spinning..or am I missing something..?
well it only took 3 tries....
lots of swearing when i thought i tottaly screwed up the pulley
but at work i fixed itlast night
did what i should have done in the first place
and was suggested to do by more than one person... to dam stubborn i guess
4 pretty close to evenly spaced counter sunk screws with a dolop of locktight
and after actually getting the trigger ring set correctly .. well close enough
the target for the running base timing at least by the info was for 10 deg before tdc...
i ended up with 10.5... maybe 11...
it starts quick
idles well has little to no miss .. what miss there is i think is caused by incorrect injection timing since its still fired off the disty and not the edis system
i now have a nice trickle of water vapor out of the exhaust pipe.. in this case thats a good thing since its a byproduct of proper combustion..
did not have that on the stock subie ignition
now to go pull out my megasquirt modify it upload the new code to it
and hook it up i figure in the next day or 2 i will start running the dis system full time
but leaving the stock disty in palce for at least.. a few weeks just in case i screw something up again :)
but the end result ... is
it does work now
you can now send your reasearch contributions to my paypal account at..
lol :)
now to go fix someones truck
come home have a beer and go to bed in celebration !
may the dis be with you!
hey shadow... get ahold of me ...
  • 2 weeks later...
well as of about 9:00 am i just finisehd putting about 10-15 miles on the subaru
with out using the distributor for ignition !
it still runs teh fuel injection timing but it seems close enough that i can
work on tuning the timing before i switch over the injection
i have alot of timing mapping to do
even with just using the base timing values in the ms it idles starts and runs alot smoother
if i go over 5 psi of boost under heavy load it complains and detonates..
but under 5 psi and it pulls almost as much at 10 psi did on the stock ignition woot
someone built a knock sensor interface i will have to work on that next
as well as retune the timing map so under most normal running it does not ping
its alot mroe responsive ohh and that anoyying surge we turbo owners hate...
its gone
well time finish my beer and head to bed i will be driving to work on the edis setup
but if something stops working its jsut a few wires away from stock ignition to get me home again
now i need to make some mounts for the coil pack and edis module.. they are kina just "floating "around under the hood right now hehe
but i win... it works... it runs
it drives. its better !
well i give up
in short yes it does work.. err did work
but i don't have teh resources to finalize it i was battleing a small problem with the timing changing after i set it
and it was caused by my own stupidty i believe by initially welding the timing ring to the crank pulley i damaged the bonded rubber vibration damper junk
so everytime i reset the initial timing ring position to where it should work
and then tighten up the power steering and alt belt the outer hub would slip a little bit at a time and since the trigger ring is on the outer hub it throws the timing off
and since i have no way to make a solid crank pulley or afford one to be made
i pretty much give up on it anyone who wants the info i have to continue pm me
a good idea killed by stupidity
Hey!!
No giving up now! I'm getting ready to gather all the necessary parts for the EDIS and MS setup....
Of course...if you do want to give up, shoot me a PM and maybe I'll buy your stuff :grin:
well it was a bad day yesterday
but i may have a temp solution till i can scrape up a new pulley
i think if i drill about 3 1/8 inch holes into the pulley that run from the centersection up past the rubber crap and into the outer shell that the belts ride on..
i "may" be able to then make up some 1/8 inch pins coat them in some nifty gear locking stuff and drive them into the holes i drilled
hopefully that will stop the slipping problem enough to get everything tuned in i hope it works
cause it sure was a hell of a change driving it for the short time i did on the edis system even with out the timing maps sets correctly
it had lots more power until the pulley started slipping :(
i will try my pinning trick tonight at work..
hopefully it stops raining tomorrow .. dam i need a drill press so i can do stuff at home
hmm good thing i am not as "slow" as my typing would indicate :)
hey Oddcomp either leave me a message on YM or PM me on here if you want me to do a pulley for you so you have a permanent way of making it work
well got the pulley pinned timing light shows the edis running at base timing of 12-14 deg good enough for me as i can tune it to where it should be now
and its close enough to the recommended 10 deg setting
gonna go put the alt/powersteering pump belt on now and try and adjust the timing with the computer
and go for a short joy ride
i hope some of you appriciate this as i am currently working under a leaky tarp in the rain ! :) since all the sunshine has vanished.. of course i had sun when things where not going right... go figure..
i hope 4 1/8th inch pins are enough to combat the slipping at least until i can get a new pulley "thanks baja"
well
back with i hope good news
i hope it works well enough to get to the mini mart.. outta beer :)
well since i finally hooked up the correct wire.. don't ask..
the megasquirt can now control the timing off for a joy ride woot
hmm i had a long thing typed
but due to more stupidity
oops
but short version
it works
it works well
its adjustable
and it works
and the pins held under alot of beating i intentionally inflicted on it
so
it works
yay
now to tune
well to and from work a few times and to and from wcss6
welllll over 300 miles on it now no problems out side of getting the timing maps tuned :)
on to the fuel side!
Seeing it in person and hearing it makes a big difference. That thing didn't miss a beat, great job!!!
:) thanks.. lots of beating my head into my computer desk went into just what little i had to show
small encouragements like that help alot :)
Well done Oddcomp!
Fanatastic stubborn attitude wins again over mere steel, sparks and those pesky 0s and 1s.
Please give us an update after hardcore testing.
I bet the General is trying to figure how to put this all on an EA81.
Fuel delivery...hmmm
Best of luck with it.
i think i have already done alot of hardcore testing
but i figure after around 1k miles or so then i will call it good
i played witht he ignition maps on the way home last night ..
btw... who did i pass...twice... in the motor home draggin the white rx?
on i5
as far as the fuel side goes
just a few wires
and findin someone close enough who is crazy enough to ride with me
who can use a computer
its do able
but not wise or easy to program things at 55-60+ mph....
oddcomp, first i'd like to say i was very impressed with the setup. Congratulations on getting it working.
I've always assumed i'd do most of my tuning using the data logging feature. Make a couple runs. Analyze, change, run again.
fuel wise yeah thats the way to go
but ignition wise..
its pretty much 0 feedback except for listening for knock and then seat of the pants feeling
wel i mean if it starts to run warmer than usuall.. your to retarted.. on the ignition
i have a vague idea of what all this does, but it certainly sounds badass. im thinking you would use this to add more fuel, so you can add more boost, and reduce detonation by adjusting when the spark fires. thats certainly up my road :brow:
