November 30, 200520 yr They will be TIG welded mild steel. I might try to sell them on my subaru_18 yahoo group too. I am a moderator on that site. I'll get some of these made up and put a photo of the engine with the GM alternator attached. You have a TIG machine?? I'am taking welding at the college right now, and i use a miller TIG machine, i've been thinking about getting one...its clean, its strong, and its easy.. Think i should get the tig, or go for MIG?? Sorry for getting off track guys, -Bill
November 30, 200520 yr Get both machines if you can afford it. The MIG is more practical for eveyday stuff but the TIG can do most any metal and have a stronger weld. Don't be afraid to buy used! They last a long long time. I have a Lincoln Precision TIG 185 that makes Xray quality welds and the whole thing was just $1800usd. It is pretty easy to setup and fun as hell. I might be sick but I sometimes dream about welding with it. The MIG is a must-have, you can do some pretty high quality welds real quick. Some aircraft makers even use MIG on their moly frames! When I say MIG I mean wire feed with sheilding gas, not the crappy flux core! That stuff will hate welding and take forever to develop your skills and you'll ony get a half-assed weld at best. I won't even get into regular arc welders, well, I will say that they are best used at the end of a chain to keep your fishing boat from drifting downstream. Oxy-Cet is nice to have around because you can braze with it, sometimes a brazing is stronger than a weld and it chrome plates very nicely. Be careful when buying a MIG welder, go with either an known brand like Miller, Lincoln, Hobart or Century, they use Miller parts. I have a little Century 150 amp and I have built many trailors and sandrails with it. It's the best bang for the buck that I can find. You have a TIG machine?? I'am taking welding at the college right now, and i use a miller TIG machine, i've been thinking about getting one...its clean, its strong, and its easy.. Think i should get the tig, or go for MIG?? Sorry for getting off track guys, -Bill
November 30, 200520 yr Im going to replace the alternator with another junkyard alt That too could be your problem in it's self. Junk yard parts, especially electronics are iffy at best. You don't know the history of that part, or how long it's been sitting out in the yard, exposed to the elements. I used a J/y alt once, that was it, it lasted about two weeks, then died on me. Took it off, copletely rebuilt it, then threw it on my Brat, it lived there, putting up with 2 sets of 90W halogens, plus quad 55w headlights for 2 years, then it moved to my 84 turbo when it got the XT-6 alt. Has been on the Turbo since (almost 3 years). And the turbo ain't light on electronics, digi dash, headlights/defrost/heater always on in winter, plus it's got a pretty good stereo in it. So the moral is, don't trust stuff you know nothing about.
November 30, 200520 yr I agree with Adam on the JY electronics..never have trusted them..At least with new ones there is some sort of warrentee so if it dies in a short period of time you can replace it for nothing. I am knocking on wood right now..But I only run about 300 watts in my Loyale and have never had an Alt problem..and I run my lights all the time ( I actually get upset if someone uses my car and turns them off),heater is going,stereo ( when it wants to work). I work in electronics and we purposely blow up caps just for the fun of it! Simple minds are easily amused.
November 30, 200520 yr Before you spend a small fortune on giant caps I would have the charging system checked out by a good shop. You stated that the system is overcharging now. How do you know that? Did you measure the voltage and see more than 14.8 volts at the battery? Having a good high capacity battery is important to have here also. Check the wiring between the alternator and the battery for any problems. There should be very little voltage drop between the alternator output and the positive battery post with a good load on the system. Agree with you....also double ceck ground contacts. Good luck.
November 30, 200520 yr Author I would go remanufactured and get a warrantee but im strapped for cash right now so a 25 dollar JY alt is going to have to do.
November 30, 200520 yr If the price of a rebuilt alternator sets you back, wait till you see the prices on the audio power caps.
November 30, 200520 yr I really dont want to read all 4 pages, i'm off to work, so I hope I dont repeat what someone eklse says...... have you checked the voltage regulator?
November 30, 200520 yr Author Voltage regulator is internal and thats whats fried. Yeah i know caps are expensive but i can live without my subs for awhile (though life is better with them ). Im just going to pull the fuse for the amp so i don't kill this alternator as well.
November 30, 200520 yr Get yourself an Ammeter gauge as well as a battery voltage gauge. See if you are drawing more then you can produce. What is killing your alenators is heat from too high a load. Time to put in a GM alt. nipper
November 30, 200520 yr Author I think the stock one should be fine as long as i have a capacitor for the amp. For now ill just disconect the amp so i don't burn this one out.
November 30, 200520 yr I have an XT6 alt you can have, just as soon as I get back to CT. (when I find it...)
December 1, 200520 yr Before you get too involved blaming your stereo, you might want to first check your battery. I,m taking care of a lot of subies, and a few alts go out starting with noise and feedback on the dash. Sometimes the main power cable from the alt needs to be replaced. The only chronic alt killers have all turned out to be broken and shorting plates in the batteries. This starts destroying your alt every time you hit a bump. They don't make an affordable rough service battery for a car, so about all you can do is make sure that your battery is securely fastened. If you do not, or haven't off-roaded, this is probably not your bother, but if you do, swap the battery and see what happens. It's hard to test for a broken plate because, as long as it is contacting, the voltage and load tests will read normal.
December 2, 200520 yr Author Ok here the update. Went to the junkyard today and put an alternator in. Didnt work..it was overcharging still. So went back in and got another (im not paying for any of the others by the way..just the 26 bucks for the first one) and put that in. No go. It was undercharging bad. SO...again went in and they were saying it was probably my car at this point but they still gave me yet another to try. BINGO..this one worked perfectly. They're really good guys over at Bills Auto Parts in Tolland CT. Just have too little faith in the power of subarus Also i will still be putting in a cap for the amp. For now im not using the amp just to save this alternator until i get the cap. And WagonsOnly has offered up an XT6 and Im going to take him up on it...That is when he gets back from Ohio or where ever he said he was stranded with his Vdub getting a window fixed. Good luck WagonsOnly and Thanks mucho!!
December 3, 200520 yr thanx for the update! some advice, NEVER LET YOUR BATTERY GO DEAD WITH A CAP IN LINE! it can crack and leak, or even explode.
