Front diff interchangeability: The true answer
Sorry to drag up this old post. And apologies if it has been answered elsewhere. I just want clarification on something - coz I saw it mentioned. Can a Full Time 4WD D/R RX Box be made to take one of these LSDs?
If so, this would affect the ratio? yes? I had heard you cannot change the ratio of these boxes from 3.7..?
  • Replies 184
  • Views 41.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • As promised, an EJ diff compaired to a 4-speed diff:     Did any other manufacturers use the 4-speed front differential? Honda/Toyota/etc.? Maybe one of them did and someone made an aftermarket
  • No the lsd is the carrier and they interchange between any of the five speeds mentioned,so all you need is the lsd carrier assembly. Unfortunately some have glossed over setting up a differential cor
it technically doesnt change the ratio, it just is an "implant" to make your front diff have a helical or clutch type engagement when wheel slip is created.....correct? and you can change the front diff ratio, right? by swithing to the 3.90 or 4.11 front diff, since they are apparently ALL interchangeable.
~Josh~
Did you guys even READ the thread??????????????????????????
No, it cannot be MADE to take one. ZERO modification nessisary. Direct drop in. You cannot modify the box to 'take' one...you dont have to, it drops right in.
Would not change ratio. Yes, you can change ratios. 3.700, 3.900, 4.111, 4.444 are avalible.
Yes, you can change front diff ratio, but you better change the rear accordingly. The diffs are the same, there are no 3.700, 3.900, 4.111, 4.444 front diffs. Ring-Pinion set defines ratios.
Oh I read the thread alright. As you can see in my post I was after clarification - coz I have been told otherwise. I have been told, from various sources, it is impossible to fit any other ratio than the 3.7 into a Full Time 4WD Box. It can be done, however (apparently), in the Part Time Boxes
I have had no personal experience in doing this - and I am certainly not going to say you are wrong. I just want to find out why I have been told differently.
I guess this is really a separate issue to the Front LSD though!
Thanks for your reply WJM :)
OBX-R Helical for me.
so you are running the OBX we were talking about in the other thread... where the honda ricers said it got shredded real fast?
OBX makes good stuff.
I do not have it installed yet.
welll.... I'mma wait until you put it in and run it for a bit :lol: being innovative is one thing but blowing $450 sucks... it seems to be either $450 or $1k... I'm not gonna pay $450... just to blow it up and have to fix it.. so if it works out for you I'll go OBX, otherwise it'll take me a while to get $1k to drop into a car I've never driven over a quarter mile???
so that means get on da ball Will...
I've got a spare RX FT tranny and I'm waiting... waiting for a good day to tear it down and put one in;)
my tranny is out.. for now I'm being stubborn and refusing to reinstall until I can get a limited slip... story will change if the legacy breaks though
I dont get it??? So does this mean i can use a front LSD in my RX?? :rolleyes:
-Brian
p.s.
Im just kidding, i read the thread :-p
*WJM smacks TSJ really hard on the back of the head*
IDIOT! /Nepolean
  • 8 months later...
i wana put a lsd in my gl-10... not that it would do much since its not in 4wd all of the time..... but hey... why not!!!
This thread is about a FRONT LSD. So yeah, it'd do quite a bit, even if not in 4WD mode.
I wana do both!!! But the rears easiest for me to get-to!.... Or im just 2 lazy to go to the front!!! and if i did do an only front lsd it would understeer more than a fwd car does anyway!!! are you guys using this for street or for off-road!
I saw the picture of tranny aprt in other thread. Could the final drive gears be swapped cleanly to a 2wd shaft from an 88 gl-10 with the 3.454 final 4wd? I am assuming that is the final gear in referenced on the manual.the ring and pinion, or front lsd, or other name for it. It looks like it can be taken out via a key? or set threaded pin?
So the front diff assy is the same P/N from 1985 to 2004... check.
So as I gather, a 5spd D/R could be swapped to a legacy front LSD with no issue. (note to self: swap from 4spd D/R to 5spd) I guess the next question, pardon me for asking as I dont recall reading about it in the thread, is of the various gearsets.. will the 4.11 and 4.44 also pop into the case without modification? I ask this as I've read in various other threads that those two sets, 4.44 in particular, uses a larger diameter ring gear.
And, as a logical extension of the above question, what sort of options exist for the rear end? Or is dropping the R160 in favor of an R180/200 the only option to fit those extended gearsets? *prepares to cut up a 280ZX for its 4.11 R200 lsd* :grin:
no, you can make a 4.11 r160. you have to drill out the holes which secure the ring gear to the chunk, as the bolts are larger.
legacy's didn't have front LSD. they had center, which is a whole different can of worms
the only factory 5-speeds with front LSD were JDM STis. but, there are more than a few aftermarket options for WRX etc. cheapest I've been able to find was about $300 for an OBX helical-type LSD.
this has nothing to do with the final drive. while the carrier is the same, and therefore the ring gears are the same (or similar enough to work), the pinion is different for the 4WD. I'm quite certain that the only way to change your final drive, is to use a legacy viscous center diff. but then you wouldn't have true 4WD.
as for the rear, only STis use an r180 rear end, so r160s in various gear ratios and LSD configs are out there. but if you go r200....you might as well get a locker!
R160 FTW.
Many different LSD types avalible for it:
Kazz, Cusco, PG, and more for clutch type.
ATB-Quaife/Torsen/Helical for it as well.
SureTrac makes one, but its hard to find.
And more.
Gearing? everytihng from 3.545 to 4.444 was made with the R160.
R180: Maybe 4 LSDs avalible, and only 3.90 ratio could I find.
Hi all.
I read allmost all the tread from the begining and I still don't understand how to swap my 1990 DL 1.8L 4WD 5 Spd. D/R 3.9 ratio front diff from regular to a lsd one...?
What parts do I have to change? From what Subaru can I take those parts?
In those pictures at the first massage, How can I see the difference between a lsd diff and non lsd diff? to me it looks the same, so where is lsd thing hiding?
Thanks, Gal.
its just the front diff its self...the actuall differential.
No parts other than the diff its self need to be swapped.
You can order aftermarket, or get an OE STi 5spd front LSD from SUBARU-STi.
From what year the STi have front LSD?
The STi have different ratio from my 3.9 4WD 5 Spd. D/R DL. Does it metter? Its not a source for a problems?
And from what year the front LSD STi diff will fit to my EA82 D/R 5 Spd. diff?
