EA81 engine year?
I checked mine today.
JF2AT53B1DE503147--5/83 285017
JF2AT53B3DE503151--5/83 286318
(Have to check VIN on hatch) 4/84 532282
  • 4 weeks later...
  • Replies 104
  • Views 115.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • GeneralDisorder
    GeneralDisorder
    Nope.   We can narrow it down with more info tho:   1. Check for gold sticker on the valve covers. If it has these (they indicate hydro lifters), it came from an 83/84 automatic, or 85-89 Brat or
  • GeneralDisorder
    GeneralDisorder
    Ok - so to summarize (I'll update as people post):     Engine serials / build dates:   - EA81   799337 - 07/81 931272 - 01/82 009899 - 04/82 300305 - 05/83 460419 - 01/84 665918 - 11/84 8
  • We COULD post engine numbers from cars with a build date which would give us a range after a significant number of people posted.
Posted Images
hello all, i just joined and this'll be my first post... :headbang:
well, i have an 84 d/r 4wd 4speed hatchback with an obvious replacement motor. i understand that you're looking for serial #'s off original engines but i was hoping maybe someone could help me figure out what year my engine and carb are likely to be. the engine is stamped 625893, has no gold stickers on valve covers, has the two 10mm bolts on bottoms of heads, has hitachi dist, has 3 belt crank pulley and factory a/c. also, i'm used to the valve covers being the same blue as the air cleaner and mine are black, its obviously possible they were painted but it doesn't look like it - the paint is perfect (minus the effects here and there of heat and oil over 23 years!). my carb is a hitachi dcp306-12 104.
the reason i'm requesting this info is the fact that my carb needs to be replaced (upon dissasembly for rebuild i discovered parts missing inside and stripped threads throughout - damn the monkey that's responsible!) anyhow, i ordered a replacement for my year/options application and got a later model hitachi with no numbers but drasticly different vacuum fittings (no vac on the secondary diaphragm, 2 vac ports on choke pull off diaphragm, etc.). near as i can tell, i've got an earlier model engine. also, i was told that with a 5 as the 6th digit of my vin i should have a 1bbl carb.
somebody please show me where my steering wheel rolled off to!!!:confused:
  • 2 months later...
1987 Brat, DR 4WD, original engine. Bought in 1993 from original owner in Albany, GA.
  • Build Date - 06/1987
  • Engine number - 460949
  • 6 months later...
1983 GL Wagon 4WD/Auto/EA81 manufacturing date 05/83 engine serial number 285692
Edited by XT6 Magic
  • 2 months later...
I put in a newer motor a while back and was wondering what year a car it came out of. It's a EA81 and the ID says 583264. Is there any way of finding out what year it is from this number? Thanks!
Well the EA 81 was in production from 1980 to 1989. thats all i know haha somewhere in those 9 years
  • 5 weeks later...
85 Hatch build date 7/84
S/N where do you find this number i would love to contribute
original engine
  • 2 months later...
  • 4 weeks later...
EA81, Build date 4/84, #519607
Hydro lifter engine(verified by stickers nand the fact it's in an automatic trans car)
Automatic, 4wd, *high luxury* model sedan. Every reason to believe this is the original engine.
  • 4 months later...
My EA81 Hatchback was manufactured 03/86 and the engine number is 061979.
  • 2 weeks later...
EA81,
build date: 5/84
Engine #: 544606
4spd MT, d/r, original motor
Looking at Gloyale's " EA81, Build date 4/84, #519607"... in one month they pumped out 24,999 engines...
  • 2 weeks later...
83 GL 4WD D/R
Built 11/82
EA81 #399491
I just replaced that old rod knocking monster (had a bad rod knock for the past two years) with #536170.
  • 5 weeks later...
81 GL 2wd
Build date 02/81
ea81#611559
no idea if its the original engine or not
  • 2 months later...
thought i would post my numbers too. im in australia and not sure if the engine number would be any use to you guys, but anyway...
year: 5/84
VIN: JF2AM5ERO1G0290xx
engine:EA81 524347
im not sure if the engine is the original
  • 4 weeks later...
I have an 84 Brat by the registration. By the research here I think it is the original motor.
EA81 stamped on the block
SN- 451042
01/84 on the door jamb plaque
D
Edited by Big D
Found the door plaque
  • 4 months later...
84 GL Wagon 5spd 4WD D/R
EA-81 676332
Manufactured 10/83
Vin: JF2 AM53B8 EE415162
  • 3 weeks later...
is the hydro lifter engine any better than the solid lifter motor? what difference does it make?
the manufacture date sticker is gone, but my 82 is 709509 and im pretty sure its the original. which would make it a very early 82, prolly manufactured in 81
i recently replaced timing belts on my ea82. now the car runs on only two cylinders, 2 and 4. help?
  • 1 month later...
1981 GL Brat. Manufacture date 06/81, EA81 engine #762670. Original motor.
Edited by MaddCelt
  • 3 weeks later...
EA81 4WD S/R wagon, original engine, serial number 356080, delivered new in Germany, april 3rd 1984.
  • 4 months later...
Just went out in the cold and popped the hood on Clod Brown (my 85 BRAT) for a look see. Fuji build date of 02/1985, engine #739450. BRRRR!!!! I vote on doing this stuff in the spring or summer.
  • 5 months later...
My Bros 86 Brat that we got from the second owner who had it since '92 mfg. in 05/86 #125640
Ill get the wagon # next time im out there
  • 2 weeks later...
So I finally made the adventure to my 81 wagon today, I assume its the original engine.#574656. Mfg in 4/81
