dfoyl Posted September 27, 2006 Share Posted September 27, 2006 We're heading into spring here down under, and the wet weather is finally arriving. My '89 Brat/Brumby doesn't have intermittent wipers, only slow & fast (I can't believe a 1989 _anything_ came without intermittent wipers!), but I've seen the wagons have a different controller with intermittent built in (along with rear wiper control, which would be handy as I'd like to put a wiper on my topper/canopy). My question is, what do I need to change to get the intermittant wipers working on my Brat - obviously the dash control, wiring, etc, but do I need to change the wiper motor and anything else ? Thanks. Dean. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 27, 2006 Share Posted September 27, 2006 Motor is the same - you need the intermittant control unit and you will probably have to custom wire most of it as you don't want to start unraveling the engine harness. GD Quote Link to comment Share on other sites More sharing options...
Durania Posted September 27, 2006 Share Posted September 27, 2006 Don't feel bad about the wipers, the retards at toyota didnt put them on my '97 Tacoma. So i am stuck wearing out the mist option about like you are. Quote Link to comment Share on other sites More sharing options...
dfoyl Posted September 27, 2006 Author Share Posted September 27, 2006 Thanks for the info GD, custom wiring is always fun Dean. Quote Link to comment Share on other sites More sharing options...
msteel Posted September 28, 2006 Share Posted September 28, 2006 Don't feel bad about the wipers, the retards at toyota didnt put them on my '97 Tacoma. So i am stuck wearing out the mist option about like you are. My '90 Prizm doesn't have them either. Not sure if I should blame GM or Toyota for that. Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted September 28, 2006 Share Posted September 28, 2006 My '90 Prizm doesn't have them either. Not sure if I should blame GM or Toyota for that. Its a prizm. Blame yourself for buying an econobox Its actually quite amazing what cars manufacturers decide get intermittent wipers. The only cars I've had them on is my Subarus (an XT6, XT Turbo, and my EA82 GL Wagon), and my 89 Ford Tempo (POS). Not the celebrity which was supposed to be 'luxury', or the sport compact toyota I had. The POS Tempo and the XT6 are the only ones though that I've actually been able to adjust the delay time. Quote Link to comment Share on other sites More sharing options...
redskin Posted September 28, 2006 Share Posted September 28, 2006 l am trying to do the same conversion to my 89 Brat using a coupe switch, l know it can be done as l've done it before, (20 yr ago), but for the life of me can't remember what l did! l'm kinda sure it involved fitting the switch and a timing relay under the dash, l think you'll find the wirings for it is already there, the motor is the same. Quote Link to comment Share on other sites More sharing options...
EJ22Ute Posted September 28, 2006 Share Posted September 28, 2006 yeah the plug for the intermittent relay is already in the brumby harness. it is up above the brake pedal on mine. then swap the switch over and it should work. Quote Link to comment Share on other sites More sharing options...
redskin Posted September 28, 2006 Share Posted September 28, 2006 Thanks for the confirmation EJ22Ute, thats how l remember it but couldn't be sure. Must be getting old. Quote Link to comment Share on other sites More sharing options...
BobBrumby Posted September 30, 2006 Share Posted September 30, 2006 The intermitent can wiring was already in my dl brumby, it is a 6 wire plug that has a plug conected to it with one 'yellow wire'? jumpered between two of the wires, near steering column. The switch wiring was plug and and play, dam site better than windows . Except the plastic int. shrowd didnot fit the job was a complete breeze. So happy intermitent wipering. Quote Link to comment Share on other sites More sharing options...
jonas Posted September 30, 2006 Share Posted September 30, 2006 We're heading into spring here down under, and the wet weather is finally arriving. My '89 Brat/Brumby doesn't have intermittent wipers, only slow & fast (I can't believe a 1989 _anything_ came without intermittent wipers!), but I've seen the wagons have a different controller with intermittent built in (along with rear wiper control, which would be handy as I'd like to put a wiper on my topper/canopy). My question is, what do I need to change to get the intermittant wipers working on my Brat - obviously the dash control, wiring, etc, but do I need to change the wiper motor and anything else ? Thanks. Dean. don't you mean slow and not quite as slow?? don't know about later years but the EA81's wipers pratically have no diff. between speeds. Quote Link to comment Share on other sites More sharing options...
