knock sensor
I have a 98 Legacy Outback, the check engine light code said I need a new knock sensor, so I bought one. The Haynes Subaru manual says that I need to remove the intake manifold on passanger side of engine to gain access to install the new sensor. Is this true? Man that is a lot of work for such a small sensor with an electrical pig tail. Is their an easier way to install? Any advise will be appreciated. Thanks!
Do a search here, its really quite simple to replace.
nipper
I just want to remind you fellows
that at the bottom of this page
you will find
"Similar Threads"
They can take the pain out of searching.
Hope this helps
It's pretty easy. Socket and extension gets it out.
Buy a low range torque wrench to put the new one in. Cheap at places like Harbor Freight Tools. Then you won't crack the new one in 6 months.:burnout:
You can deffinately go straight down the drivers side rear of the intake manifold with a long extension and a 12mm socket
you will find
"Similar Threads"
Hope this helps
Well you learn something Everyday!
Fat Tony - Olde Dogg
