February 1, 200818 yr hey on wed nite i was moving some rather heavy boxes in my 85' GL and it did'nt bottom out all the way but it did level it out with the front which made it look very very nice. now that takes me to my question. what can i do to level it out without all the boxes in the back . in other words wat do i need to do to the springs??? i will appreciate your help. Buddy
February 1, 200818 yr is this 85 gl a 4x4 ? 4x4 s has a ajustable rear spring support, yours may be all the way up
February 1, 200818 yr is this 85 gl a 4x4 ?4x4 s has a ajustable rear spring support, yours may be all the way up Yup, check under the rear seat for a rubber grommet right in the middle. Pull it and you should see a bolt head, it's a 17mm or 19mm, that is your torsion adjustment. I think if you "loosen" it, it will lower the rear.
February 2, 200818 yr Johnson']Yup' date=' check under the rear seat for a rubber grommet right in the middle. Pull it and you should see a bolt head, it's a 17mm or 19mm, that is your torsion adjustment. I think if you "loosen" it, it will lower the rear.[/quote']No, thats for EA81 cars, on an 85 wagon the adjustment is on the coilovers
February 2, 200818 yr its an ajustable spring perch for the rear, the front struts are also ajustable
February 2, 200818 yr Does the 4X4 Loyale wagon have the same thing as the 85 GL? No. And not all 85's will still have it as often the coil-over's have been replaced. You can always change the springs. GD
February 2, 200818 yr on top of improving handling,you can change springs up fron to give you a llittle lift without stressing the system ,and others have done numerous different configurations on the rears. search around for references like ,ebay coilovers,honda rear springs,and such. i am sure you will find something satisfactory.cheers, brian
February 2, 200818 yr I Suggest the same Thing I`ve Done, it can Help: Rear: Swap the Springs with Honda Accord`s Front Springs, They`re almost the Same Size, just Thicker and can Handle more Weight. Front: Swap the Springs with Ford Tempo`s Front Springs, They`re almost the Same Size, just a Li`l bit Thickers and they got Two extra (More) Thinner Turns, to Increase Li`l Bumps Absortion. Good Luck!
February 3, 200818 yr No. And not all 85's will still have it as often the coil-over's have been replaced. You can always change the springs. GD Alright. Yeah that's true, Just curious. Thank's GD..
February 3, 200818 yr alright as long as people are posting interchangeable springs, does anyone know of springs for the front and rear that will give your car more lift? Like a couple inches?
February 4, 200818 yr Author actually i want to go lower since this is such a clean suby i want to lower it. i know that xt6 springs are used for the front but what is used for the back. mean while what i want to know is how can i level it out with touching the front. i dont want to touch the front.
