All Activity
This stream auto-updates
  1. Today
  2. Timing belts were put on by the book. Driver side, rotate 180, passenger side. Check at 0 BDC if the pulley markings are facing "outwards" and dizzy is set to #1. It is. Plug wires are in the proper firing order to the proper cylinders. Belts were torqued with a homemade version of the factory tool and a beam torque wrench. Granted the belts were used for about 2-3k miles so I had to tighten to 18ftlb rather than 2ftlb if the belts were new. But I followed the chart in the FSM. If I had to guess it to be anything it'd either be a timing issue or a compression issue, somehow, but I'm more inclined to believe the former rather than the latter. Could also be bad gas, but it doesn't run off ether which is why I think it's a timing/spark issue. Even though I have spark. I seriously doubt a coil or dizzy issue. :]
  3. I had a “problem” with my first and last EA82 rebuild - turns out we missed the bit where you fit one cam belt then rotate the crank one revolution and fit the second cam belt. When the crank is lined up one cam will be at 12 o’clock and the other will be at 6 o’clock. This is the key to EA82 timing belt alignment - don’t miss that crank rotation between fitting belts!
  4. If you have fuel and you have spark, that means you might have a timing problem, either ignition or valve, or a compression problem. Check both timing belts are installed correctly. Check for top dead center compression stroke on #1 (feel for compression in the spark plug hole, then probe it to find the top of the stroke) and verify the rotor in the dist is pointing at your #1 spark plug wire at that time. Check compression, which will also find valve problems, like being adjusted too tight, not seating, etc.
  5. Yesterday
  6. Prepare your thinking caps. I've recently done a full rebuild (minus bottom end) of an SPFI EA82 and full reconditioning of the engine bay. The engine and manifold are a bit of a Frankenstein but both the engine ran, and all of the electronics (dizzy, throttle body, ECU, maf sensor, etc) came from a running engine. Air: I just redid the head gaskets (that's why I'm trying to start this thing up and clearly failing) the heads were fully reconditioned (valves and seats ground, new valve seals, new guides, new lifters, head resurfaced). Deck was meticulously cleaned. All new seals on the throttle body. All new hoses everywhere of the proper metric sizes. It definitely has compression. Fuel: Pump is noisy but it ran the engine previously. Injector is firing and spray pattern from what I can tell looks okay. I did have an issue of coolant leaking from the throttle body into the intake but I removed the plugs and cranked it over for a few seconds a couple of times to hopefully blow all that into the exhaust or out the spark plug holes. Coolant leak looks to be resolved (looking past the throttle plate with WOT and injector disconnect while cranking). Fuel has been sitting for about 10 months with a stabilizer added while I've been gathering parts and meticulously working on this thing by the book. But even when I spray ether into the intake, it doesn't fire. It sounds more promising with the ether. I let it air out with spark plugs removed, disconnected the injector and tried to run it off ether. It sounded like it really wanted to kick over (*faint* whomp-whomp-whomp-whomp). TPS is set up properly and tests okay. Spark: It has spark on all 4 plugs, proper gaps, tested body & engine grounds for resistance (0.3-0.4 ohm from the ground to the battery). No codes from ECU. Dizzy is properly phased with the cams, it should be in a good enough range to at least kick over, maybe not run perfectly but it's in the proper range to run. I'm at a bit of a loss here, anything stand out to anyone or any thoughts or opinions? I have an FSM and I can go through everything in the troubleshooting diagram. I'm just confused, I have all the ingredients for fire but success evades me currently. Thanks :]
  7. Enjoy the venture! Many of us, the few still left here after the great FB saturation, have turned the pages on the EA82 era. Lucky for you i think there’s a current active member with a wealth of EA82 experience. I sure had mine, but i’m pretty much a user and abuser a backyard mechanic. Don’t be afraid to attack that heater unit. Pretty sure i did a write up on removing the dashboard and heater or accessing it for the core swap. That will also allow duct cleaning, flapper door re-foaming, general bleach n water wipedown, let it sit and do it a second time some would say.
  8. Ended up putting in the extreme articulation axles this weekend and got her out on the highway for a test drive! Definitely needs an alignment but feels smooth and no clicks!
  9. @bushytails You could try running a few tanks of premium (no ethanol) through it. My gauge wasn't working and slowly over about 2 months of driving the gauge came back. My guess is the premium dissolved the varnish that was gumming up the sender float mechanism.
  10. ^ driving to the trip meter, that’s always fun!
  11. Went to parts.subaru.com and clicked around. Got this part # 84930AE020 Not sure if it's the exact one, but click around. It's under the electrical section, headlamp. https://parts.subaru.com/a/Subaru_2002_Legacy-25L-AT-Limited-Sedan/_52016_6025843/HEAD-LAMP/B12-840-01.html
  12. Hi USMB members. I'm Almostborncanadian and new to the USM Board. I have a stock '94 Loyale 4WD wagon 85,000 miles. I mounting up some snow tires in 4x140 13" (165/80R13) for the approaching northern Minnesota winter. Thank you to members who were helping me look for used wheels. Seems like shipping makes used wheels pretty spendy. I also have a horrible dead turd smell emanating from my heat blower. REALLY nasty. I'll be looking for a dead mouse "up there", The car has been driven 45 mph max by two old school teachers. I think the muffler sounds constricted like it is full of rust. And one of the rubber boots covering the joint attached to the front transmission is torn wide open, Otherwise we are in pretty good condition. I look forward to learning from the group and fighting off the urge to spend big bucks on this old car. I tried to attach photos but they exceed the 2 MB limit. Wave Browser.exe
  13. My '84's fuel gauge got increasingly erratic and now hasn't worked over 1/3rd tank for about a year... old car problems!
  14. Friday night, I finally got a chance to tackle the shifter bushings from DRW. Thanks to @SuspiciousPizza for telling me they were an option. https://drwbushings.myshopify.com/products/subaru-2wd-5-speed-shift-linkage-bushing-set First time working on the shifter of an EA series car but I got them knocked out. Having a lift spoils you on something like this. I took a before and after video but can't link to it but it was a definite improvement. I also replaced the pitch stop rod bushings but I've not driven it to see if there was an effect.
  15. Drove the GL to work for the first time Wednesday and have some initial impressions. 1. I need an alignment. 2.The heater is fantastic. 3. Driver side axle started knocking like my brat did back in 07 with a janky parts store axles. 4. I need a cupholder. 5. Hard left turn, my fuel gauge went to zero and then came back up. This was before I filled up with 100% gas so I assume it was sticking float. Once it came back up, it registered half-a-tank. I got a few thumbs up in it. Definitely gets more attention than my WRX does.
  16. Last week
  17. Hey all, Just doing a teardown and reseal of my '08 forester manual and figured I would do the clutch at the same time. When it comes to the throwout bearing and clutch I'm not sure if I have this setup right. The single retaining clip on the throwout bearing doesn't really seem like it holds it at all to the clutch fork. From videos I see online it looks like most people have two clips to hold the throwout bearing mine just has the one big one. I've attached pictures so you can see what I'm talking about. Am I missing something? IMG_2019.HEIC
  18. Site won't let me post pics cus they files are too large but I got a blue WRX im trying mod and need some help and advice. Parts I'm trying to get are aFe Takeda intake, aFe header, aFe exhaust, Cobb tuner, Cobb top intercooler
  19. Site won't let me post pics cus they files are too large but I got a blue WRX im trying mod and need some help and advice. Parts I'm trying to get are aFe Takeda intake, aFe header, aFe exhaust, Cobb tuner, Cobb top intercooler
  20. Im a new Subie owner and looking for advice or help to mod it.
  21. Older, pre Legacy Subarus were never numerous in the borderland. They petered out in the pick a parts, over a decade ago. Suspect the pacific NW might be different. While they were here, though, the metal parts were excellent.
  1. Load more activity
