All Activity
This stream auto-updates
  1. Today
  2. Hey i believe i found one nearby but if it doesnt work out ill get back with you thanks!
  3. I tried to post pics of the B58 connector with pin 5 grounded under the dash, but I kept getting a message that the picture was greater than the size/space allowed. I couldn't upload it.
  4. Update: I was able to clear the TCM codes by disconnecting battery and then discharging the electronics. I drove it around town and then retrieved the codes again. I still got codes 24 & 25, but now I also have code 12 (Duty B solenoid). Hopefully tomorrow I can find some time to start probing wires. Note: If anyone wants to know how to retrieve the codes on a 95 and earlier 4EAT Phase 1 transmissions, this is what worked for me: First ground out pin 5 in the B58 connector as mentioned above. Leave pin 5 grounded and then take the car for a ride. Bring the car to a stop and follow the steps for the handshake method, also mentioned above. Take the car for another drive and you will see the A/T temp light start flashing the codes while you're driving. Even if you stop and put the car in park, the codes will continue to flash as long as the car stays running. If you shut the car off, however, you will have to repeat these steps to get the codes to flash again. I took a picture of the connector and the ground wire pinned to terminal 5 for your reference. I will post it from my phone.....on the laptop right now. I hope this can save someone else a bunch of time trying to figure this out. The 95 and earlier Impreza's (possibly 96 too) must have the ground pin in terminal 5 of the B58 connector in order to retrieve TCM codes. There is no way around this unless you have the OEM Subaru Scan tool. Hope this helps. As of right now, my hunch is that with 3 TCM codes all appearing at the same time, the most likely the culprit is the TCM. I reached out to a company that specializes in Subaru ECU/TCM repairs. They quoted me 450.00 to fix the TCM if that's the problem. Before I do that, I will try one from a junkyard. I welcome your thoughts.
  5. Yesterday
  6. You could have them welded up and then retap as well but a good used is the way to go.
  7. www.car-part.com ebay.com I most likely have one in Colorado, but I'm in Hawaii. So it goes.
  8. Last week
  9. Thanks everyone. I just discovered the new iteration of the bracket involves a few different mounting screws that I need to get, along with the newer tensioner style. I tried to helicoil the stripped holes and did not execute it properly... so now im looking for the discontinued part (13086AA012). This engine is in pretty decent shape from what I can tell, has never overheated when ive had it. But I believe you are right, el_freddo that the threads had previously taken a beating. Its the 2 tensioner (not pulley) bolt holes that got stripped. Long story about the failed helicoils... ill spare you the details. Anyhow the dealership didnt seem to understand how to make the new bracket work for this car so I believe Im just going to pursue finding the discontinued part, if that doesn't work Ill look to "modernize". Thanks any tips on this part would be much appreciated.
  10. Hey Everyone I'm looking for the timing tensioner bracket with part code 13086AA012. The part is discontinued by subaru and proving hard to find. Was hoping someone on here may have one for sale. Thanks
  11. There is a market for these cars in the Midwest, it's small and niche so not exactly the easiest market to get into. You gotta know someone who's looking to buy and you gotta be selling what they're looking for. The reason you can get some decent scratch for a DL/GL/Loyale (especially a BRAT) is because a lot of the cars rusted to bits. They make great hunting rigs (they're small, quiet, and a D/R trans does well on logging roads), they're great winter cars, they're great farm vehicles. I'm not looking for a disagreement, just pointing out that if anyone is looking to sell, there are buyers up North willing to shell out for these little cars. :]
  12. Is it hard to polish up the headlight lens so it "sees" through better? Mine is pretty dim. Also the radio antenna has been out, I'll search online for solutions.
  13. Was the torque converter fully seated? Trans light flashing 16 times on start? If so the TCU has codes.
  14. Update, the engine is in and everything worked. .. for a while. Now there's torque converter of transmission issues.
  15. And, most of the old threads here on USMB lost all pics thru fotosuckit or changes in forum hosting service changes. PM Crazyeights to see if he still has some pics & such for 5 MT d/r transmissions.
  16. Hmmm, I can’t think of anyone off the top of my head that’s written up a tutorial. It’s one of those things that you just get into and forget to take picks etc as you go. Re: silicone. Just lever on the plate, the silicone will let go. The trick is not to damage the mounting face. Cheers Bennie
  17. I finally got an easy one! The 2002 was missing intermittently, bad enough to affect driveability. We got under the hood and tried spraying propane from an unlit torch along the vacuum hoses, for just in case it had a vacuum leak. No luck with that, but I did hear a tick each time it missed. I started paying attention, and was able to see a spark jumping from one of the coil end plug wire boots to a rubber hose! The boots had gotten dirty, and the medium voltage had made a track to ground. I pulled each boot and wiped the outside of the boot with a rag moistened in WD40, and wiped the dirt and carbon off the coil where the boot plugs on. FIXED! New plug wires are on the way. On a side note, we tried sticking the unlit torch into the air intake and opening it as wide as it would go. Couldn't hear any change in the motor noise. That trick might have worked with carbureted engines, but it doesn't seem to work with this engine.
  18. Thanks, moosens. We have a torque converter on the way, my son jumped the gun and ordered one. On to other projects for a bit until it arrives. We'll look up inside the trans when that gets here, and we drag the '95 back into the shop.
  19. Here's some reading for you before you dive in to that "spare". https://www.ultimatesubaru.org/forum/topic/121582-transmission-reseal-new-bearing-with-pics/ https://www.ultimatesubaru.org/forum/topic/95638-411-awd-dual-range-in-legacy/page/2/ https://www.ultimatesubaru.org/forum/topic/100318-ej-dr-tranny-s-from-nz-ive-read-many-recent-threads-want-newest-info/ Can't recall which long gone member had a complete tear down description, but I think el freddo might know. Gloyale did some, el freddo did some.
  20. Factory EA82 studs have about a 14.2mm knurl diameter (according to the Dorman listing), new gen Subarus are 14.38 (but the shoulder is too long for EA applications, as the rotor doesn't slip over the studs). Looks like I used a 35/64 drill bit (13.89mm). I also used Dorman 610378 studs, which have a 14.48mm knurl diameter, smaller head (easier to seat with the curved material on the back of the hub where they need to be), about 10mm longer overall, but short enough shoulder even for steelies (open lug nuts required, though).
  21. Now we’re talkin’ , thanks man. I’ll be doing that after my lunch.
  22. Most shops are willing to press a bearing into a knuckle for a nominal fee. This would be far cheaper than replacing all those parts. Same amount of labor. Only downside is having the car apart for a trip to a shop. Heck, probably would still be economical to buy a junkyard knuckle and have a shop press in bearings. We had a customer bring their car into the dealership where I work for a rear bearing. Turned out it had a complete aftermarket knuckle installed not long ago (not purchased from a retailer willing to help with the replacement cost). We tried to install an OEM bearing, and it didn't fit! We had to replace the hub with an OEM one as well. Just another story of the risks of cheap parts.
  23. I do not delete EGR on almost any of my vehicles. But I know they often have a temperature sensor as part of the circuit to verify the systems functionality. Good video, I suggest you watch it. Lots of good information about why it's supposed to be exhaust gasses. It's not "just air".
  1. Load more activity
