Everything posted by bheinen74
Wisconsin for the day
got back to iowa. with one more subaru to habe to find a place for
yeah, nice but never saw the sun today. overcast all day it was looking dark about 2pm. dont you get sun up here? headed home in the AM, going to stop at Subaru Heaven as well to see wth that is about/
back south to green bay now.
way up there and back, and i mean WAY.
where was that again, it might be on the way to where i am going?
Will be in wisconsin Friday and likely staying in a motel Fri night somewhere around Oshkosh/Appleton. If i have any troubles I will try to post on this boards and hope someone is around to give a hand, and meet up or what not. Anybody around those areas......? Are the roads as terrible as i am told? cheers. brent
1994 Legacy Won't Start
bheinen74 replied to Subie86GL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour Timing belt is LIKELY not on the marks right check your timing sir. cheers.
SVX Power mode problem
bheinen74 replied to NWSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXflashing power mode light indicates a code is stored, meaning for a code something has failed. could be a switch, could be a solenoid. SVX has problematic transmission from the get go, they all do, not a single one escaped a trans problem. - it can be fixed. prepare for some shock about the price to fix.....BIG TIME SHOCK
timing belt fixed and now whines
bheinen74 replied to paulo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthere are guides that might have come out of place and rubbing on the belt
EJ22 alternator upgrade?
bheinen74 replied to SoobieDoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX89-94 is round 95+ is square. but yeah just splice whatevr connector is needed, its just 2 wires to splice. SVX is square, but they have different mount system.
big trouble
bheinen74 replied to ellets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtook this album of pics today all are from the front of car. hope this is a start, if all else fails, i am serious interest in your car if you want out. cheers http://s405.photobucket.com/albums/pp132/bheinen74/legsshoses/
big trouble
bheinen74 replied to ellets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can put up pictures of the 94 turbo under the hood, and help, i could even come get it so you dont scrap it. this is that silver wagon from st loius with b;pwn hg right hopefully the car didnt give him a stroke.
Wheel lug nut question
bheinen74 replied to mattdni's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXaluminum oem wheels use lug nuts that are chromed, and the end is covered. These are not the correct nuts for oem aluminum wheels. I doubt it has anything to do with the studs, but EVERYTHING to do with the style of nut you chose to use. Get the right nuts and be done. like this
00 Sub Forest, Scanners, Codes, ABS, Valves
bheinen74 replied to Buick350X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXprobably better plan for more than few hours.
Would like some opinions on whats wrong with my OBS
bheinen74 replied to vincentmoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1500 sounds about right for the dealer near me. Over on nasioc we rip that dealer but still no coupons. we just dont got there for service anymore lol ramsey.
oil/filter change for winter on my BRAT done today, pretty sure the last outing bashed my skidplate in enough as the 17mm socket was useless ib drain plug. usd my 17mm box end to put plug back.
bheinen74 replied to vincentmoy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXprobably also a BHG
question on lsd conversion
i can fit any chunk in any case, without ring gear attached. Its the part of when the ring gear is attached that the ears need ground off.
somebody got lucky with a 555
http://www.rightdrive.ca/inventory_cars/view/201 all i can say is someone is very very lucky i didn't see this before they got to it. a tru 95 STi 555
ring gears need to stay with the case they came from, put the ring gear back into its original with the pinion gear as it matches. LSD cases have the "ears" ground off on the 4 insides so it will fit in. Non lsd diff still have the "ears", so you need to grind those ears off the case for it to fit. I lke to use a high speed air grinder with diamond bit for my grinding. you will grind down just to the side cover bolt holds are starting to show up. Compare to a original lsd case you will see the bolt holes. make sure to stuff a rag over the pinion when grinding, and to use air compressor to blow it out and make sure its totally free of any debris.
Pawn Shopping
I dont live anywhere near a pawn shop. about 30 miles to the nearest one. I use Ebay for most my shopping.
New Guy from North Idaho
needs roof rack yours is really nice.
Pionreer TS-162 works in most cars. they are just a dual cone but sound much better than a factory dual cone. the tweeter does not stick outward on this model and is a BEST choice. end of //
JDM Engines - do you trust the advertised miles?
bheinen74 replied to revox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou could junk your car due to blown headgasket,
I bought a 92 Legacy sport
91 and 94 are the most desireable 91 cause it had vlsd rear and oll cooler for he ej22t 94 cause it was last year and had better headlighting and better interior ammenities. i owned a 92ss and it was awesome also owned a 93ss, 94TW, and a current 94ss liked the 94's most but would DIE for a 91 just could not find any.
