Everything posted by subyfreak
Wobbly OBW
subyfreak replied to jarl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Also check the cross-member to body mounting area. I have had a 1st gen legacy that had 3 out of the 4 bolt holes rusted away even though the body was not really rusty at all. It had a very floaty feeling. Swapped out the cross-member and put another 100,000 on it. -
The more I look at this the more amazed by it. Even the plastic bits look new. I would love to see some interior and under hood pics. Thanks for showing such a great example.
I have noticed some oil in the intake box by the throttle body and figure it could be caused by a plugged pcv valve. I have no idea where and how many valves there are on this engine. Any body have a picture of where they are? Thanks in advance. Oh and another thing not related. I need a TPS for a 01 Outback Beener edition if any one knows where I can score a used one.
I hear you. Only I have the other problem of plenty of time and no money. It is enough to drive a man crazy. Wish me luck as this 32yr old man heads down to Burger King for an application.
Those wheels do look great. Are they toyota wheels? I also like the body colored mirrors and spoiler.
Pulling the pump assembly was cake work. I was at first a little intimidated with the idea at first from past non subaru fuel pump jobs but after digging into it I was surprised with how easy the whole thing comes out. As for the problem it looked like some one was in there before and was a little rough with putting the cap on and caused a hairline crack that over time got bigger until the cap partially came off. I still am unsure what the part is for but it was obvious some thing was not right.
Well after pulling the pump assembly I noticed a round metal cap about 2.5 in dia. with a rubber o-ring not seated properly. One of the metal tabs had a crack in it and kept it from sealing. After brazing the crack and putting it all back together it fired right up. Total cost was a $60 tow. Took it for a bit of a drive and it performed perfectly. Thanks again to everyone that helped me trouble shoot this otherwise expensive problem.
again nipper thanks for your 2 cents. you seem to have been around the Subaru block a few times and give good advice. All I want is to get it running long enough to make it home. Like I said earlier I have limited funds until next Tuesday when if needed I can go all out and get a complete genuine gold plated fuel pump assembly:grin:. Bonus is when I pull the assembly from the donor car I can get a feel in what is involved and I have been itching to go visit that last chance parking lot better known as a scrap yard all winter. I will be back to let you guys know how it all works out.
I have a couple of salvage yards at my disposal with plenty of 00-04 outbacks/legacys. Unlikely I will find another H6 but plenty of 4cyl models. The pump assembly should be the same right? You guys know what I am getting at. Well what would you do in this situation? Remember that I have about $250 to fix the car and get me and the wife home. Every opinion will be looked over and appreciated. You guys are like my online AAA Ok looks like the part number for the H6 and 2.5 of the same year have different part numbers from autozone. : ( Anyone know different? I sure could save some money if they are compatible.
Grossgary, The car has been daily driven since purchased last August. Filled the gas tank about 120 miles ago yesterday. So the gas has not been sitting for a long time. Nipper, I figured I will not be able to run it very long with that line pinched off but will deffinetly help me buy the right parts.
Thanks guys for the advice. I will pull the fuel assembly tomorrow morning and check the sock for crud. The only pump I could find is at Autozone for a little over one hundred dollars but it is only the pump not the complete assembly. I can get the whole assembly shipped in about 3 days for over $300. I am limited on money until next Tuesday so the $100 pump looks like my only option right now. Feel free to chime in about anything else to check.
