9
i'm not so familiar with the '00 - '08s, but the 97 - 98 gt had the outback 2.5L engine and trans with the legacy suspension (maybe a different sway bar and TCU) and legacy tire size (on 16" wheels, but the same diameter). around '01 they discontinued the 2.2L legacy engine so your only choice would be the 2.5L engine. there is no difference between the GT engine and the outback engines. there were some of these engines (2.5 L, SOHC, phase 2?) that suffered external head gasket leaks, coolant leaking down the back driver side? of the engine, i think. so that may be a concern. you can search here: www.car-part.com . generally, the software will include other years that also match, psobably '00 - '03 or 04. sort your search by distance. shipping will / could run $150 and up. what's wrong with your engine?
in 1999 it all depends on the transmission. some, a very few probably, 99s used the same trans as 98 TZ102Z2DBA. if you have this trans then you have 4 bolts. if they changed to the new engine and not the new trans, which i doubt, then they used 4 bolts on a 6 bolt engine. so just read the trans number on the id tag or at the starter, if it ends in ...JEBA or JEAA or JECA then its the new 6 bolt. if it ends in ...2DBA then it's the old 4 bolt trans. this is for 2.5L legacys/outbacks.
hgave you or your mechanioc check to make sure the final drive ratios are the same. there is an endwrench article describing how to check for matching front and rear diffs. something like: unplug the connector to the trans, jack up one side of the car, (both wheels) put the trans in neutral with hand brake off start the car now when you turn the rear tire by hand the front tire should match it turn for turn. this procedure locks the trans in 4WD so the wheels front and rear will turn exactly the same. it may not work on a limited slip differential. if this rules out the front and rear diffs being different, it has to be the clutch packs/ duty c problem. try the FWD fuse under the hood, pass. side between the fire wall and the strut tower. the duty c part online is less trhan 90$ (besure to get 2 gaskets) i'm not sure of the cost of the clutch discs. you are very close , don't give up now.!!!
yes, 96 - 99 2.5L A/T rear differentials are all 4.44 95 - 99 2.2L A/T rear differentials are all 4.11 96 - 99 2.5L M/T rear differentials are all 4.11 95 - 99 2.2L M/T rear differentials are all 3.9 there is an endwrench article describing how to check for matching front and rear diffs. something like: unplug the connector to the trans, jack up one side of the car, (both wheels) put the trans in neutral with hand brake off start the car now when you turn the rear tire by hand the front tire should match it turn for turn. this procedure locks the trans in 4WD so the wheels front and rear will turn exactly the same. it may not work on a limited slip differential.
i put a windshield in a 96 lego and the longer i spoke with the guy on the phone the lower the price got. he finally said if i could wait a few days he could do it for $99.00. the time delay allowed him to get the glass in from a distributor not a warehouse in the city. you might try saying " well bob over at bob's glass said he could do it for 125$" what are they going to do after the say no, raise the price. you probably should watch them do it, just ot make sure they don't leave any sealant on your carpet.
they are seperate. the ignition switch is about the size of 50 cent piece but 1/2'' tall. it is attached to the a$$ end of the ignition keyway by a little tiny screw about 1/4' long and thinner than a pencil lead. if you remove the plastic surrounding the steering column, it will be fairly obvious. at no time do you need to remove the "security bolts" that attacht everything to the steering column nor will you need to remove the ignitiopn keyway lock. although, with the key in the ignition and the plastic removed it is easy to do. what i don't know is what , if any, relays may be employed between the actual switch and the starter etc. the plastic on the steering column has 3 screws on the under side. there is also a fairly large 'phillips' type plug for acces to the ignition 'keyway/lock'. remove the 3 screws with a long thin screw driver and gently remove the plastic peices. you'll need to wiggle the steering wheel 'tilt' lever. i had an intermitten problem with my 91 nissan pickup ( notable only because nissan and subaru use the same igmition keyway and switch) and i had to run another wire to the starter. but my truck was a 5 speed, and i never took the time to track down the actual problem. my guess is that i had a bad clutch 'safety' switch. but i don't know, the new wire solved it. good luck.
they should. check an online parts house and see if they list a different part number for manual vs. auto. if the do it's the first i've ever heard about it. they should be the same for the same year. at some point they moved the abs tone ring onto the axle ('00 '01 ?) but that can be removed and it will work. there is a recent post about this.
any suggestions on boots, types, sources, etc. what should boots cost? a recent post commented on the axles for the newer outbacks ('01?) and the boots having more convolutions and maybe being more durable. any thoughts? it sounds like replacing boot is a real mess, but with so many BAD reman axles out there i'd much rather do that than replace the axle if it isn't bad. thanks, john
the 205/55/16 will fit and clear fine as long as it is a subaru wheel or has the same offset. this is the same size wheel and tire they run on the 97 GT which has the same wheel clearnce as the legacy L. the circumfrence of the 16" tire is about 2" larger than the 15" tire. larger tires should give you better gas mileage but slightly less power. if you are now getting 25 mpg, in theroy you should improve to 25.68 mpg with a size change of 2.7%. this assumes the reduced power doesn't greatly affect your 'around town' mileage. making the change for economy reason may be misplaced, which wheels look better on the car?
the guys who are good at head gaskets just shake their heads when we start talking 2.2 engine swaps. they're all about fixing the engine you have. on the other hand when you buy an outback with bad head gaskets and you don't know how badly it was abused or overheated it could be smarter to do the swap. i've heard head gasket prices (you have to do this to do the vavle work) from 900$ to 1500$, 1200 to 1500 more common. and engine swap prices from 500$ to 1200$ depending on the price of the 2.2 engine. the labor to swap should be a day or less. ball park numbers. since you know your engine hasn't overheated, it would seem a good candate for doing the valve / gasket work. if you had a good 2,2 sitting in the backyard that maght be a better solution.
check your brake pads for wear, the caliper slide pins may not slide well, your brakes could be draging. and maybe, but not likely, the tire repair guy bumped it or something. this shouldn't be the problem since you did the pads last year, but i do pads all the time and can only remember one time relubing the slide pins. dumb, i know.
merchants did this to my truck. but since it drives and tracks strait and i drive only once a month, i don't much care. but when i took my outback in i threatened them, and they gave it back right. the idiots who did yours, may know how to operate the alignment equipment, but they don't know $hit about how to align a car. tell the manager if they can't get it right you want your money back, or that you'll take it to a speciallty shop and get it done right and he can pay the bill. when he says no, call the better business bureau.
sorry for all the trouble you're having with your dealer. i guess some are better than others. BUT, it is always a joy to find a locksmith who can work magic. i lost my tool box key to my truck one time. went to the locksmith. he picked out a key that would fit into the lock and then proceeded to file it down while standing at the truck until he got it to fit. presto, a new key. another time, 25 years ago, i locked my car keys in my datsun while it was running. called the locksmith, he used a pick, stuck it in the lock, wiggled it around and presto, it was open. he charged me 21$ (1982). he said it was 1$ to unlock the door, and 20$ for stupidity. locksmiths are great.
i remember from the repair manual that there is a ring/spring clip inside the cup on the trans end of the axle. this is the one you have to remove to re-do the boots. the outer joint doesn't have to come apart to do the boots so i did'nt read up on it, but i'm sure you are right, it can be done as long as you have enough room to get the axle off the diff stub, or disassemble the inner joint. there is a diagram in the haynes manual i think. suggestion, go to the DIY car wash, cut off the outer boot and spray it off with hot water and degreaser. drive it home and disassemble. if there isn't enough room to get the axle off without taking the hub apart..... drive the car till the axle fails. then take them apart. or cut it in the middle zzzand then disassemble the thing.
