ecu swap cooling fan not working
johnceggleston replied to brama's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi'm pretty sure i know the answer to this but with only a few years of subaru experience i'll ask any way. when i swapped the 96 leg 4eat into the 95 leg i didn't swap the TCU, amy chance this is causing my TB on the 96 trans. or more importantly, whe ni make the repair, will it do it again? everything worked great for 3000 miles now duty c and TB. like i said i think i know the answer.
Starter cutout twice in 99OBW
johnceggleston replied to Shep2112's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe flickering , i don't know. what worries me is the low voltage at the solenoid when the car on but you are NOT trying to start it. 2 things come to mind, one you have a short sending power when it's not supposed to, and two, that continuous power is cooking your starter contacts. i don't really have enough experience to know if either of these are valid concerns, but they seem on target. maybe there is a short in the steering column or the ignition switch.
johnceggleston replied to Shep2112's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe solenoid on the starter (the clicking thing) has 2 terminals. one has the large hot wire direct from the positive battery terminal. this should have the same voltage as the battery. you might check continuity betwen this terminal and the battery + post. the other treminal on the solenoid is the power from the ignition switch. this terminal only has voltage when the key is turned to start. if this terminal isn't getting the voltage/amperage it needs, your car will never start, it may click. if the solenoid is clicking, it is getting some power but not enough. you can test this with a piece of wire and a 1/4" female tab connector. with the key switched to the on position, run the wire from the smaller solenoid connector (1/4" male tab) and run it to the battery + post. you only have to touch the wire to the positive post long enough to see if the starter turns the engine. BE VERY CAREFUL, THE CAR COULD START, make sure it is in park with the brake on. keep hands and tools clear. if it starts (or turns over), the problem may be your ignition relay or wiring. if it doesn't, it could be your starter contacts. you can search for directions for adding another starter relay under the hood. this worked great for me. also directions for replacing starter contacts. of course neither of these solutions takes in to consideration the flickering dash lights. if youhave question be sure to ask. good luck, john
Hub replacement question
johnceggleston replied to dssenne's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you are worried about used not lasting and time and nmaone are a majoer consideration try one of thses. buy a used hub / knuckle and a new bearing find a shop that will press it in, and install that on you car in about 2 hrs. buy the used hub/knuckle install it, and save the original one untill the used fails and then go get the new bearing and install it. 2hrs twice. i'll bet either of these is cheaper than new bearing/hub combination and both are quicker than replacing the bearing in the existing hub.
My OBW may be dead. PICS!
at least you got to drive home, imagine if you had flipped over and landed on your roof and hood ..... never mind.:lol:
power steering squeal
johnceggleston replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmy 95 had a 'little bit' of torque bind when i bought it . it was my first AWD 4WD car and thought it was standard. it ran that way a long time from 73k to 167k, amazing, until it blew out a rear main seal on the tranny, then reverse went when the seal replacing idiot didn't add any fluid. mine would only bind at full lock, back off just a little no problem. but i think, and this is just my opinion, that regular fluid changes will reduce the TB amount if not eliminate, lengthen the time you have before it fails and in the long run cost way less. change the fliud in the trans, check the fluid in the steering. ( i know ,you've already done this, but it always amazes me when i read that some light has come on and they ask for advice before they look at the car. i've done it, probably will again) did you say you had done some work on the steering?
Outside mirrors???
johnceggleston replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhe should ask for the switch too.
4EAT Locking solenoid Q's
johnceggleston replied to 86ruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdone let me ask this, doesn't down shifting into 2 or 1 also transfer power equally to front and rear, 50/50? isn't that the factory provided 'switch'?
Torque converter enable/disable?
i meant to ask this last month but i never got around to it. when the torque converter locks up and the rpms drop a couple of hundred , is this what is generally reffered to as 'over drive'. or is OD something else? i understand how the lock up works, and how it saves fuel etc., but i'm just now putting 2 and 2 together.
johnceggleston replied to 86ruguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlook out, here it comes... all those responses for and against. only a very few people have had success with this modification. it has caused ONE PERSON had trans damage, BECAUSE IT WAS LEFT ON ALL THE TIME, in the form of burned out AWD units = $850 - $950 repair, you have been warned. see below.
replace 5 speed in '99 LGT
johnceggleston replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi bought a used motor for my dad's explorer. the car was 11 years old and had 115k miles. ford wanted 4500$ for rebuild. i bought one from a nearby salavage yard for 850$, they deliverd it to the mechanic, (500$ or 600$ to install), and warrantied parts and LABOR, for some period, i don't remember how long. well the engine was good so we never had to find out if the warranty was good. apparently good used parts eliminates the need for a good warranty. we sold truck the next year, when my dad died. i wish i'd kept it.
Timing belt failure and head removal
this is the guy nipper warn about the OWOWOWOWOW factor when checking spark. http://www.ultimatesubaru.org/forum/showpost.php?p=560385&postcount=31
Electric AWD on older Legacy, how does it work?
there are 2 speed sensors on the trans. one on the front differentils and one one the rear output to drive shaft/rear differential. the TCU or ECU detects the speed difference it sends more power to the rear wheels. the flow of A/T fluid is metered by the 'duty c' solenoid. when the duty c fails the trans goes to locked 50/50 slpit which gives you torgue bind. when the FWD fuse is installed, under the hood, the duty c is 'always' on and you get power to front wheels only (FWD). i don't know the crv or rav4, but this is all wheel drive all the time not part time. if you install the FWD fuse and drive the car you can feel a distinctive differenc in the way the car handles and drives. therefore even with a 90/10 split it makse a huge difference in how the car drives. the few times i have tried this it makes the car feel 'squirrely' or 'lose'. but this is only because it's then FWD only and how great it drives with AWD.
Forester wheels on a 92 Legacy?
yhese new wheels /tires will be about 3/4" wider and 1" bigger radius, thats 2" taller. i bet not. i might lose the bet, but i bet against then fitting.
Timing Belt HELP!
johnceggleston replied to Olnick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis great information. thanks!! question: it doesn't matter what part of the cycle cylinder 1 is on? if the crank puley is on the mark, belt is on the crank mark and the cam pulleys are on the belt marks, then it's all ok? that is simple. i think i can do that. now about the DOHC's ....... thanks, john
That pesky ol' Speedo Head
johnceggleston replied to deyoungc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif this is a manual trans, isn't the AWD unit different than the auto. i thought it was a viscous something and not controled by the computer.??? i 'm suprised that you got 2 speedos that have the same problem. i would guess that it is something else. i'd try the sending unit before i tried another speedo. i'm not familiar with manual trannys, but on a/t it's the VSS#2 or the front one that sends to the speedo. good luck.
what size are they? are the tires on them?
johnceggleston replied to MDW25gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you have any doubts about the honesty of the seller, get the vin# and run a carfax. it may not tell you any thing but if it says last reported mileage 215,000, well then you'll know. at least some of the trannys have the vin etched on to the driver side. john
part # needed
johnceggleston replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes it can be changed in the car. the id plate mounted on the strut tower driver side under the hood will give you the tranny number, TZ102ZAAAA or ...ABAA are both AWD. or just look under the car to see if it has a rear drive shaft. you can got to ganuine subaru parts < https://www.subarugenuineparts.com/oe_parts_cat.html > and put in your car info, then under keyword type in speedomerte sensor or vss. it might take a bit , but if it returns a part description and price , it will also list the years that part is good for. like this SPEEDOMETER SENSOR, Legacy, Manual Trans 95-99 $95.62 $69.99 SPEEDOMETER SENSOR, Legacy, Auto Trans 95-99 $89.78 $65.72 if you order from there ask for jamie, she's a board member here. john
disable awd
johnceggleston replied to spider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmatbe spider is hard of hearing!!!
flood car H6 3l
for the 95 -99 legacy / outbacks there are only 3 to pick from. 3.9, 4.11, 4.44. i think the 3.9 was only in manual trans (?). the 4.11 was 2.2L, and the 4.44 was in 2.5L. but ive said this beforew and been corrected. so this is my best guess, not 100%. but i haven't seen any thing else to say different except some saying his 2.5L had the 4.11 differential. if you have the tranny number, you can got to carpart.com and search for different years and model trannys and eventually come across a tranny number. some will be listed before you get search results. it's tedious, but it works. what car and year are you working on.
part # needed
johnceggleston replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtje i don't think the 95 has a speedo cable. i know the 96 didn't. the VSS#2 is mounted on the right front of the trans and sends , by wire, the speed info to the instrument cluster. i don't know the part number, but it is called the Varible Speed Sensor #2. (VSS#1 is on the rear extention housing where the AWD ius located.) it's about 3 inches long, threads in to the housing, and has a wire connector on top.
Timing belt mileage records?
johnceggleston replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcome on nipper , tell me you don't enjoy watching someone dance around and hollering when checking for spark.
AT filter on 96 OBW
johnceggleston replied to lyonsnet's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgood advice!!
