Everything posted by capn_r
One more A/C question (charging)
capn_r replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt may tell you in your FSM, the only one I have atm is for an older vehicle with a R-12 system but the low and high side switch pressures are listed in section 4-7 under "specifications" in the manual I have. My guess would be that the low pressure switch should be closed at 40 psi though. Have you tried feeding it some vapor in low side with the dash controls calling for cooling?
capn_r replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt sounds like it's possible that your expansion valve is stuck shut. If that is the case if you charged the remainder of your can into the low side (with the vehicle running, if a low pressure control will allow the clutch to operate with the valve on the can at the top to feed vapor) it will probably drop the low side pressure until the low pressure control opens and stay off on low pressure. It seems like the expansion valve should feed enough to bring the low side pressure up fairly quickly and with yours staying in a vacuum on the low side to me that points to that valve not functioning.
Performance Headers: EJ22 N/A.
capn_r replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe cat is after the y pipe.
capn_r replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a duel port EJ22 in my GL10 wagon that has a 95 y pipe on it with 2 1/4 in pipe with a glass pack resonator mid pipe and a magnaflow muffler that sounds nice now but I think it is going to get one of the UEL headers. Boxer rumble, butt dyno increase and more MPG, I'm not seeing a downside.
capn_r replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think something like in this thread is what he means. http://www.energeticforum.com/renewable-energy/1387-o2-sensor-modification-using-spark-plug-non-foulers.html
1999 Sebring Coupe (Mitsubishi) - ignition failure
If it had failed on the road the numbers would have added up to a lot more, so in a twisted way he is lucky. That issue shouldn't re appear for a long time if ever and hopefully the owner will understand your thoroughness and not want to give you credit for the manufacturers defect.
Flywheel question
The 4WD uses a 225mm 24 spline clutch and the non turbo FWD units use a 200mm 21 spline.
Northwest folks.
Morton Washington
EA81 SPFI conversion or ea82 swap?
Do you have to split the cases to change pistons?
GEN I Brat owner
http://www.ultimatesubaru.org/forum/showthread.php?t=111505
Ej22 swap 86 gl blue maf wire?
It appears that is correct. The other four from the maf connector go to three locations on the B48 (a) connector and a ground.
Dash Swap Wiring 83 dash into an 81
I don't have 81 or 83 FSM's (I do have 82 and 84) but I do have a Bently manual that shows some schematics from those years. (I believe they are FSM copy's but I'm not sure) If they would help I could attempt to scan them and see if I could get them to you.
SVX AC R134a conversion / recharge problem
capn_r replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1. use vacuum pump to hold vacuum at -23 for 10 minutes (in a subiemech85 post) I'm confused, what units are used in a -23 vacuum? Are you referring to 23in HG?
EJ swap, hard start after sitting
Do you have the wire from the B56 connector from the ecu (plug C terminal 10) connected to the start circuit?
New Toy, 88 RX
I'm pretty sure that the RX is 3.70 and the XT6 is 3.90 on the final drive ratio. I think I would grab it anyway.
So. California EA82 Wheeler
The line code and part number for the "mickey mouse" o-ring from Napa is ATM LA650. It is listed as "Oil Pump Mounting Gasket". My search showed over 100 of them in the various Napa distribution centers around the country and that particular supplier has over 400 more so they should be able to get one. The seal number from Napa should be NOS 7205 and the o-ring should be available like Yo'J mentioned above. Beck Arnley 039-6320 Oil Pump Install Kit should be available also, but a dealer would still probably be your best bet.
OBD II EJ swap HELP/ Speed Sensor
Here is a link for a product that should work for you http://www.enginewiring.com/catalog.htm and a thread that may shed some light. http://www.ultimatesubaru.org/forum/showthread.php?p=852061
Help me out here, what should I be looking at?
One last vac hose to track down
I've got an 86 FSM if anything from it would help. I don't know if the vacuum diagrams are the same as under the hood but I guess even if they are if I scanned them they would be larger so possibly a little clearer.
HiPo EA81 build questions....domed pistons?
On my EA81 wagon I machined the step to the XT6 spec and am running an XT6 clutch assembly. I put in a 5 speed but I can't see why the 4 speed 225mm disc and the Nissan release bearing wouldn't work just fine with the four speeed.
service manual section 1-1988
The factory service manuals that I have are broke down this way, (1) General Section (2) Engine Section (3) Transmission and Differential Section (4) Mechanical Components Section (5) Body Section (6) Electrical Section I hope that helps some. I have a 1986 manual that includes all EA82's including XT's and my later EA82 manual (!989) doesn't include the XT's (they are separate, but also include the XT6's)
Head swap
How does the chamber volume change the swept volume? (i.e. displacement)
new cluch for EA81 with d/r 5 spd
I believe with the EA 82 4wd you want the 8 7/8 diameter unit (24 spline) if I'm not mistaken the 7 7/8 is 21 spline and used on the front wheel drive transaxles.
Water pump question
check this out, http://subaruxt.com/forum/viewtopic.php?f=1&t=11405
Congratulations! I'll check in next time I am in the neighborhood to see if your ready for some seat time.
