Everything posted by fnlyfnd
Fender Bender Curse?
fnlyfnd replied to backwoodsboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXday 6 in my subie - dented front bumper, don't know when or where except that it was day 6 of ownership.
Tailgate wont open
fnlyfnd replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWouldn't you just need the plate and no actual moving parts?? Hope your back is good now, for good.
97 Outback LTD now has an EJ22 from 95 Legacy
fnlyfnd replied to doogymon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it is a fact that early (90 - 96) 2.2l are the strongest motors subuaru ever built. I'm not an old gen guy so maybe they had some strong everlasting engines also, but i dunno.
Overfilling tranny cause grind?
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyea mt90 and syncromesh....I think it might just be the cold weather causing this. Today it reached 40 and driving around all day it only grinded 3rd once. This was within the first minute of driving. After the car warmed up it was really smooth, so....
Advice on buying a Legacy
fnlyfnd replied to dug320's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX$3900 in USD or Canadian?? Autos are prone to more problems than stick. 95s have a 2.2L so you dont have to worry about HG
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI didn't try to tak any out since its been cold and wet. I only overfilled by maybe .1 or .2 of a qt. I am either going to try uncle scottys mix or this other stuff BG Syncro shift. 2 wrxers are using it and they love it, they dont have any grinds and can get into 1st now w/o coming to a complete stop. http://www.slowboyracing.com/shop.php?sid=PHPSESSID=fe9684c73e8a0b1df64fe9efd3f8e178&cat=883&PHPSESSID=fe9684c73e8a0b1df64fe9efd3f8e178
I saw on nasioc that overfilling your gear oil can cause grinding. I had a 2nd and 3rd grind. I used mt90 and 1qt syncromesh when I changed the oil about 1.5months ago. It seems that the gears are grinding more and more everyday, although the first week was pretty good (which was like spring warmth). I suppose it could be due to the cold weather, but I thought the new oil would be alright in cold weather. I did overfill the tranny a lil, so whats the verdict? I am sick of this grinding. My reverse grind went away for a lil while also, but that is back just like before.
Which synthetic oil is best for 5 speed
fnlyfnd replied to doktorbill's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am using redline mt90 ad 1qt of valvoline syncromesh.....I had 2nd and 3rd grind......I still have 2nd and 3rd grind.......I am going to use the cocktail on nosiac next (once it gets warm).....This is only if the warm weather of spring doesn't yield good results with my current oil.
Poor Gas Milage
fnlyfnd replied to bhelser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyea yea...i only get about 20 in town. I am waiting for spring/ summer to replace the plugs and wires though
synthetic oil question
Im a fan of castrol GTX...its dino oil and im sure that is what has been used in the life of the car before me. The front seals have been replaced, but dont forget about the valve covers and rear seals.
Pre Sales Question.
fnlyfnd replied to mrwilde's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAsking price is a definate need for us. Also engine and tranny specifics, and is it a leagcy or impreza, also any other details that should be considered when buying a car.
Undiagnoisable Noise @ 1750rpms
fnlyfnd replied to sira5012's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow bout the exhaust shields....the bolts holding them together tend to rust out.
Does an open intake give you more power?
fnlyfnd replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt really depends on where the intake is going to be placed. If near the engine or in the engine compartment exposed to all that hot air, it will prolly lose power. Now if you have a cold air induction (a real one) wether it be boxed off in the engine bay w/ a cone in it, or in the fenderwell it will provide gains. You will not feel these gains but it will make the engine sound cooler. I wouldn't really worry about making a few more hp with your 2.2l. If anything get a drop-in K&N. Now all this being said. Plugs, wires, and clean intake will maintain the power you should be making and increase your mpgs and smoothness of the engine. Your engine will be happy and so will you. If your thinking exhaust will help, it wont help all that much. In order to get true gains out of an exhaust sytem you have to be putting more air into the engine. Think: more air in = more air need to be pushed out. A simple intake will not fit that equation. Exhaust is expensive unless you go to a shop and have them bend some pipe. But, its prolly not mandrel bent and your not really doing anything but wasting $$
2.5 question
fnlyfnd replied to pBIIKS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^^^^^^^^ He meant phase II....I believe
Subaru...you Opinions Please
fnlyfnd replied to Rodney7286's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll AWD subie systems are full time awd. 4wd is where you get into the option of haveing 2wd or 4wd, and that is a completely different setup/system. The awd is great, all the time, it helps in handling on any road condition (including dry pavement) and of course the benefits are even greater in snow, rain, and mud.
Problem with a Clutch Repair - Please Advise
fnlyfnd replied to GenericMailID's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomeone makes a snout kit. This is a common problem, and there is a company that makes a snout kit to fix this forever. It's only like $120....i think it might be pdm or something. Just search for snout kit, also try nasioc while searching.
GRIME in GLASS
fnlyfnd replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou dont have to be slow, or all that careful with the razor blade. A whole window will take like 5 minutes, if that long.
fnlyfnd replied to Rodney7286's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDont get a 2000 or older 2.5L. 2.2 are not rare. I think it is a fact that the 2.2 is the best motor Subaru ever built. Outbacks (well at least my 96) handles very well. Im quite sure it cant hold up with a gt wagon, but I have had plenty of sport cars, and trust the outback handles pretty well for having so much ground clearance. I hear the automatic are more prone to problems.
front differential drain....
fnlyfnd replied to tominredbank's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou should just get new gaskets, and look in the owners manual for the drain plug locations
Tranny and Engine oil questions...not typical
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThnks for the info. I changed my oil today and all is good. I unscrewed the plug very very slow to make sure I knew what the first drop out was, sure enough it was oil!! Man what a scare. I am going to hop on the highway and burn some gas at least once a week over these winter months.
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just replaced the pcv valve not even 1,000 miles ago when I did a sea foam cleaning. I didn't use a oem pcv, rather a pep boys pcv valve. I had trouble clamping the hose clamp on one of the hoses around that area. Is it possibile that some moisture got into the system thru this unclamped hose, and caused this dilema? I know its possibile for moisture to get in, but would it cause the problem? I am going to check this tom. morning when I change my oil.
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI really dont think/hope its the HG. My coolant is fine, and I never hear bubbles. I haven't been keeping track of the coolant percisely, but it seems to be at the same level. The dipstick shows no abnormalities. I do take short 15min. trips everyday to work and back, I rarely go out after that. If i do its another very short trip - usually shorter. What would this have to do with it - ?not burning off the condensation? I talked to my mechnic and he said it most likely condensation from having very humid winters here. I am doing a oil change tomorrow morning, to see if any coolant show its face when I unscrew the drain plug. Mt90 and 1qt pennzoil Syncromesh - HUGE improvement.
Well it was sunny and 50 today :-\ so I decided to put my mt90 and syncromesh in. It call for 3.7qt...I put maybe 3.8/3.9 in - is this a problem? I checked my oil since I found that my left bank valve cover has a slight leak. It was down maybe half a quart. When I put more in I noticed a milky substance on the inside my oil cap. I was pretty light in color, almost like a off white/brownish. What is this nonsense? Its a 96 2.2 5spd
The ANTI-Gas mileage thread
fnlyfnd replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't go that far. "gaia" is a hypothesis, and it won'y be a theory for another couple of decades - if there is evidence to prove the hypothesis.
fnlyfnd replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou can get a kit, that does everything, for a couple grand. inital purchase is pricey but it will pay for itself within the first couple years
