fnlyfnd
Everything posted by fnlyfnd
Crazy....I justed noticed a (small) coolant leak on the pass. side where the timing cover and engine come together. Turns out it was the upper radiator hose leaking...Had to feel it with my hand - that's how small it was. You might want to check the hose out. BTW - the water pump is on the driver side, so thats out of the question Don't know what to tell you about the oil. Maybe, check inside the timing cover from underneath. You should also inspect the oil pan gasket...the front of mine has a small leak too, which I also found while doing a oil change
A company makes some sort of hardened sleve that helps the juddering. Subaru specific and only, just cant think of who makes it or even what it is called. XXXXXX Sleeve...I dunno. I have an exedy clutch, I would do clutch master if I could do it all over again...Hopefully the car will last thru another clutch I didn't think that the 2.5L parts would work. I would've ordered the 2.5l clutch kit from an online retailer if this were the case. I researched it, and am almost certain you cant use the 2.5 on the 2.2. This was a while ago tho, so I am not sure.
heat shield!
fnlyfnd replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I had some type of foam stuff in my original heat sheilds (factory??). I just removed them a few weeks back and it all kinda fell/crumbled out. Boy am I a happier person. I tried some fixes but they never lasted. -
Water De-carb
fnlyfnd replied to fnlyfnd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Right. But If I have carbon buildup then a knock sensor running 87 will jst pull timming, buck and stumble (and also save my engine). Running 93 with a knock sensor wouldn't pull timming, buck or stumble...I found out by re-locating my sensor, that I am pinging. Hence the reason I wanted to do a water Decarbonization. I didn't do it when I was surrouned with all my tools (at home last weekend). I am not going to do it. The car is running beautifully with 93 and a re-located knock sensor. Hopefully running this for a couple months will clear it up. -
The limited OBW got a gold package in like ~99 I think. Other than that, the gray is the same across the boards. I thought the SUS had the OBW type of bumper, you know the big black section. I have definately seen a couple with it personally, and I like em. Nevermind: I see what you're saying. But the colors are definitely the same as long as no gold pckg
