Everything posted by mattocs
You have a larger engine than me (2.5l...I have a 2.2 in my Outback) and i've had mine to almost 110. Anything over 100 gets kinda scary in it... It really depends on when it will redline and how flat of the surface. I think 115 - 120 might be the realistic top speed that you could get to without miles and miles of flat road. It might take a while to get to that speed, though. Take a look here: http://ultimatesubaru.org/forum/showthread.php?t=25754 Someone might have have listed a similar vehicle.
Engine lag
mattocs replied to Jason1976's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Mine stopped when I let it redline at 6,000 RPMs for like 15 seconds...might want to try that. -
1) You need to pull the dash apart. http://www.ultimatesubaru.org/forum/showthread.php?t=2498&page=1&pp=10&highlight=Climate+Control+Backlights has some info on doing it. 2) I've learned to deal with it. Maybe you could glue it in place? I dunno... 3) OBD2 scanner will do it. Auto Zone pulls them for free...so this might save you money, unless you are always getting a code. 4) It comes from the one the front does.
The RS 2.5 is naturally-aspirated. The WRX is turbocharged and the STi is turbocharged...but a bigger engine and bigger turbo. You need premium gas because your engine will knock. Higher octane = higher compression ratio. I don't know if any damnage will be caused...but you're engine will knock and you might have a decrese in performance.
1. The cars are good...except some of the 2.5l engines 2. Any of the 2.2l and the 2.5l from MY2000 and later. 3. 2.2l can go a long long time...250k+ if you take care of it...I don't know much about the 2.5l engines. 4. Timing belt costs about $300 to replace...and then you'll have oil leaks here and there...but it can all be done at the same time to save on labor. Avoid the 2.5L from 1996 - 1999. Unless you can get a really good deal, because then spending $1500 on head gaskets might make it worth it.
Should I Buy...?
mattocs replied to a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Just think of it as a Toyota or a Honda...except with a more reliable engine. If you'd concider something like that, then this car would be great. I love AWD...but if the right price came around for a FWD Subaru...I might jump on it.
