Everything posted by Dylan86GL10
Nissan 280ZX Turbo Injector Swap *DONE PROOF*
Dylan86GL10 replied to Steveman09's topic in Subaru Retrofitting
Yes but you seem to forget that I am using MSnS'e, will add a adj FPR, and walbro fuel pump, and no injector that I ever used locked up before 90-100 psi. 55 static +15 boost = 70psi which is incredibly reasonable. I do not understand how basic EFI principles that apply to every other brand car do not apply in this case. Let me know what I am missing. Thanks! -
In VA, you can have 50% front and 35% rear (transmittance) if you have both side view mirrors attached. But then it states: G. Nothing in this section shall prohibit applying to the rear side windows or rear window of any multi-purpose passenger vehicle or pickup truck sun-shading or tinting films that reduce the total light transmittance of such window or windows below thirty-five percent. "multi-purpose passenger vehicle" means any motor vehicle that is (i) designed to carry no more than ten persons and (ii) constructed either on a truck chassis or with special features for occasional off-road use. Guess I need 5 jump seats in the wagon area.
High Flow Fuel Pump?
Dylan86GL10 replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's the same model I posted 255 high pressure. Just different PN but still a WALBRO. Its the same pump I've used on numerous cars intank and the one that will replace the GL10 pump when it craps out. http://www.autoperformanceengineering.com/ has install kits -
Thermo Vacuum Valve on an 87
Dylan86GL10 replied to IrocRacer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'll take a pic tonight -
Nice, that's about 274 cc/min. Until then, if one bumped up the fuel pressure on the stock injectors to 55 psi, they would flow 259 cc/min which is good for about 160 crank HP. -
http://www.autoperformanceengineering.com/html/ext_pump.html http://search.ebay.com/gsl392_W0QQfromZR8QQfsooZ1QQfsopZ3QQsbrsrtZd Russ, what's the flow on the SP183 and where did you get it from? -
Best bet is to find a low mile turbo for sale on here or Ebay. You can rebuild it at home for about $100 if you index the compressor and turbine wheels so they are installed in the exact same position.
Something like this (86 turbo diagram): I had to thread small brass barbs on mine after ALL the nipples broke off. -
Diagnostic connector location and shape 87+
Dylan86GL10 replied to Dylan86GL10's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wow that car looks nice! -
Many laborious hours at the library LOL If anyone needs quick access: http://dodgeneon.net/subaru/ -
Rats guys, I pulled the 87 wiring diagram and there is no connectors: See 86 Red connector (DIAG CONN 1) has direct TPS wiring: See 87 TPS wiring - no DIAG CONNECTOR: So what does this all mean to you? No easy Megasquirt plug and play harness for 87+ HAHAHAHAHAHAH Just kidding guys. I'll have 85-86 EA82T plug and play Megasquirt harnesses available soon if anyone needs one. 87+ is going to be trickier, it will take destroying ECUs for the plug unless someone has some fancy ideas. Thanks for the help 87+ guys!!! -
LOL!!! You caught me. As soon as the rustoleum paint job is done, that pedal is next -
Sounds like fun, a FT with the lock off will still spin one tire. Lock on spins two tires.
Sorry to be semi off topic, what's the difference between the viscious center and the differential lock on the full time? I haven't installed the full time RX trans yet but I assumed the lock switch kept the front and rear and the same speed. Is it for street friendlyness?
new engine in XT, won't start *SOLVED* Bad ECU
Dylan86GL10 replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://dodgeneon.net/subaru/87EA82TENGWIRING.pdf -
Yes, supposed to have higher clamping than the 4cyl clutch
Water injection you say: http://www.autoweek.com/apps/pbcs.dll/article?AID=/20060227/FREE/302270007/1023/THISWEEKSISSUE
Both of those cars have a sophisticated knock feedback circuit. Doesn't really compare to a EA82 at all. On my 85 Shelby Charger (turbo) I gained more mpg by using 93 than I lost by the extra money.
http://performance.thepartsbin.com/basket.php?makeid=31&modelid=504&year=1989&partid=137&brandid=843 $110 http://www.partsamerica.com/ProductDetail.aspx?mfrcode=FEN&mfrpartnumber=NU31144&parttype=244&ptset=A $149
I got ~21-22 with a carbed EA82, 4" lift, 28" tires, ATX in a wagon driving 60-70mph so I'd think you could pull at least 24 or so.
For EA82 WJM: " Re: Does XT6 pressure plate have same bolt pattern? both the clutch and flywheel setups are IDENTICAL. I have done it before. there are ZERO differences. " For EA81 archemitis: " Re: Does XT6 pressure plate have same bolt pattern? i have xt6 flywheel, and pp on my ea81,with an ea81 disc. with no machining. "
