Everything posted by dmanaenk
Shift Knob
dmanaenk replied to XSKI712's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I think you need part number 92070AC011 It's a front half of console cover with a leather boot. There might be separate part number just for the boot, but I do not know it. Changing it takes 2 minutes - unscrew shifter knob, unscrew two bolts holding console cover over ebrake lever, replace front part of console with the one you buy, put it back and screw in a new shifter knob. -
Ok, another AC question to nipper With engine warm or cold my compressor clutch engages for 10-30 seconds with 5-10 second breaks. Within 10 seconds after engaging AC blows real cold until disengagement. After that it's somewhat cold until next cycle. Pipe from the receiver/drier to evaporator is warm, from evaporator to compressor - fairly cold. Any idea on why it cycles on/off so often? Is the system overcharged/undercharged? I guess I'll go to autozone and borrow gauges to measure high/low pressure.
I'm trying to figure out whether I need to replace ebrake cable on my 96 legacy brighton if I take rear hub/brake assemblies from a 95-99 or 90-94 legacy. Most of the stuff I've read on the issue is for conversion done for Impreza, and there people usually change those cables to legacy or impreza RS ones. Not sure if I have to do that as well. Any thoughts? Thanks a lot.
There no car safety inspection in MN. And I think its wrong, cause so many people drive with only one headlight, busted turn signals, bald tires etc... Also too many cars have headlights blinding other drivers. Don't know if they fail people for misaligned headlights in other states, but they certainly should.
I think the right way is to pull the engine. The cheaper way - drop tranny, but requires some extra tools. They say WRX seats are good...As well as 2.5RS. Haven't tried myself. I think they could not have done it then. 800 seems a little steep. I plan to have sep. plate replaced when my clutch dies, and the whole clutch job should be no more than 500. But 800 for that in a stealership does not sound unusual. Got nothing to say on 4.
