Loyale 2.7 Turbo
    239
Everything posted by Loyale 2.7 Turbo
  1. Basically talkin', you only need three (3) wires in order to get a Relay properly working, to Power a Device (Such like Horn, Halogens, etc...) 1► the Positive input shall be placed in two Spades, the Nº 30 (which is the High Power positive imput, directly from battery - To be Transferred to the Device once the Relay is On) and to the Spade Nº 86 (Positive switchin' signal) and those could have power permanently. 2► The Switching (On / Off) Signal, comes from the Ground, sent by a Grounded Switch on the Dashboard (or wherever you might want to put the Ground source, such like a High / Low Beams' stick, Horn button, etc...) It goes to Spade Nº 85 3► The Positive Power Output to Power the Device, (Halogens, Horn, etc...) goes from Spade Nº 87
  2. Yes, I have a couple of Pictorial Diagrams; you can find one of those in my other writeup, named: ~► "How to Wire Dual Electric Fans on a Subaru EA82" This is the Picture: Also I posted another Pictorial Diagram, in my Wife's car Thread: ~► "The KiaStein" This is the Picture: I Hope you'll find those Useful. Kind Regards.
  3. Usually, it becomes loose because the internal clamp breaks... I've solved that issue in other cars by adding an "External" clamp over the broken one, it doesn't look good but is not much noticeable, and works flawlessly. See Photo Here: ~► http://www.ultimatesubaru.org/forum/topic/101718-kia-sephia-sporty/page-8?do=findComment&comment=1120338 Kind Regards.
  4. Also it worth to check the condition of the PCV Valve, lots of stalling and bogging problems I've solved on EA Engined Subarus, were related to Stuck open PCV valves. Kind Regards.
  5. I wonder why Nobody told that a Stuck open PCV Valve could lead to a Boggin' under acceleration too... Have you Checked out the PCV Valve, yet? Kind Regards.
  6. By the Way, seems like Photobucket just resetted their monthly Bandwidth counter back to Zero tonight, I see the images once again Kind Regards.
  7. Buick + Snow... sounds No Good, Be Careful! That tiny Coolant Hose is Easy to Change, Also the PCV System is easy to Fix, maybe this Ideas could Help you: ~► http://www.ultimatesubaru.org/forum/topic/114260-oil-catch-can-in-ea82/page-2 Kind Regards.
  8. http://www.subaruforester.org/vbulletin/f62/subby-virgin-switch-59580/#post659604 My EA82 "BumbleBeast" doesn't have that "Virgin Switch" because it is pretty Old, 1985 ... So, the Lights On / Off Switch is a Knob located at the Left side of the Dashboard, The Wipers / Washers Switch is another knob on the Right Side. And the Top of the Steerin' Column only has the Hazard Switch. Kind Regards.
  9. Now I Understand... Sometimes that kind of stuff Happens... The same happened to me, but with my Wife's car... it was like open Pandora's Box. Kind Regards.
  10. I wonder why the Trick didn't worked for you... Did you tried other proxy? The other option is to Wait few days, 'till Photobucket resets their monthly Bandwidth counter, back to zero. Kind Regards.
  11. It is called "The Virgin Switch" often... By the way, my 1985 "BumbleBeast" does Not have that feature. Kind Regards.
  12. You're Welcome! I'll try to do my Best to send a Payment to Photobucket, but for Now I'm sourcing certain parts from USA to fix my Wife's car... Kind Regards.
  13. If the photos of my Writeup aren't displaying now, we have to wait, 'till Photobucket resets their bandwidth counter back to zero, or use the Trick I posted Here: ~► http://www.ultimatesubaru.org/forum/topic/139920-photobucket-sucks-a-rant-about-picture-hosting-woes/page-2 Kind Regards.
  14. ~► http://www.ultimatesubaru.org/forum/topic/87523-how-to-swap-the-old-roundie-relays-with-standard-bosch-relays/
  15. You can use 27" without Rubbing on a 2" lift. That was my personal choice to stay on 25" due to my Mixed Driving needs, my Subaru "BumbleBeast" works Pretty Hard as Daily Driver in our extremely mountainous Honduras' city Roads, also works as Mountain Adventure Vehicle on Weekends, traveling off road with Family, so 25" Keeps the Mileage and Power closer to Stock, than 27". Kind Regards.
  16. Despite mine is a '85 Wagon, I found that the Best combo for Mixed Driving (in my Case 40% offRoad and 60% Daily Driving) is 2" lift plus 25" tires, and dropping the Crossmember to keep the Axles as close as Stock angle you can. Kind Regards.
  17. Many thanks guys, for your kind will to Help Mr. Mariano. (USMB user: mam147) He contacted me via Private Messages in Spanish since some time ago, asking for help with this project; (He is from Argentina) He could not find a Single Carb EA71 intake in Argentina, and I was searching for one of those Locally... I Decided to Start this thread to Help Him, because I can not find a Used EA71 intake manifold alone; people in Honduras want to sell me the Whole Engine. I don't know what he gonna do with the Dual Carb intake manifold, But he already wrote on this thread some posts above, I hope he'll get back here soon... This is the Photo posted by Pooparu on my FaceBook: I believe that at this point, He must contact you Directly ... maybe he could buy that intake manifold from you. Kind Regards.
  18. Gotta Love the Tailgate Wagon (Split gate model = Very Rare) also about This modified engine: There was a Thread with more Photos of it on the Historic Gen Forums. Awesome Score! Kind Regards.
  19. Despite that I really Like the Idea of a Subaru BRZ Saloon, I dislike the Idea that Toyota could start selling the Impreza WRX under the Toyota Badge, Because I saw Photos of the New (2014) impreza WRX prototype and it really looks to me that it is Based on the BRZ Chassis... http://youtu.be/DMwRHpR_UHU
  20. Look Here: ~► http://www.carthrottle.com/toyotas-done-the-dirty-on-us-gt86-saloon-confirmed/ So sad it is not April 1st, so it must be True... Kind Regards.
  21. I have searched among some Local Junk Yards and they want to sell the Entire EA71 Engine, not only the intake manifold, but I only found one EA71 ... I'll continue searchin' ... but maybe someone here @ USMB could sell one Single-Carb EA71 intake manifold to Mr. Mariano... Kind Regards.
