Loyale 2.7 Turbo
Everything posted by Loyale 2.7 Turbo
  1. Well, but I like the Idea, `cos when you finish the Job, you`ll have an Almost Brand New Loyale Congratulations. I did put -almost- all my Money in my Loyales too... They worth it I`ll Love to see more pics of it soon! ...
  2. Why this Subie says "Toyota"? Why?
  3. And just for Share Info & Images `bout Racin` Subies, Look at This: For even More Subaru Weirdness, Visit this Thread: http://www.ultimatesubaru.org/forum/showthread.php?t=53434
  4. Well... This is a Race Subaru, but F1, not Rally... Remember the Flat 12?:
  5. Welcome! Bad Alternators can give enough Volts to the System, but without the Strenght needed (I Mean Amperes) so, your car can be Safely Driven by Day, but Battery Gone low when you Drive it by Night, due to Higher Current Consumption from the Lights... I Suggest to Check Alt. for Amperes instead of Volts, and Swap with another good one if you can; maybe from a Junk yard... Bad Alts can be Repaired too... Good Luck!
  6. Some Older Peugeot Rims will work fine in Subies.
  7. We at LatinAmerica Too! Also the 1.3 Loyale ... Those are "Economical" or "E" Class Vehicles.
  8. Can´t be Done a Repair?, Have you Pics?
  9. Its Good Idea!, also it can be on the Main Links, those are located in a small Black Box, near the Battery... Welcome! Good Luck!
  10. Yes! ... Don´t cut it off... but, Why you wanna your Subie to be Lightweighted? Lightweight Vehicles Speeds very much Faster, but are much more Dangerous to keep ´em under Control in Sorpresive Situations...
  11. Look at This Rallyng Loyale:
  12. Look at This Rally OldGen: What do You Think ´bout?
  13. No, Sorry... Maybe I Can Find some... Look at This XT6 Ralling: What do You Think ´bout?
  14. Maybe That´s the Answer... Try to Use less the Secondary...
  15. Rust Highlights? It remembered me that "Rust-eze" Brand on the Movie "Cars"
  16. Well... I Like the Look and the Sticker Too... but the 91Loyale´s is a Good Question.
  17. That was your Post Nº 1 - so, Welcome!
  18. I Used to Drive my White EA82 with -just- a Pair -in the back- of Peugeot Rims with This Shape: But they used "Pass Thru" Bolts, and where Branded: "Cheviot" instead of Peugeot... They work fine in Subies. You can See ´em in this Pic: Then, I Changed the Pattern in Both my Subies, so now They use a More "Standard" Pattern... (I done that due to the Lack of a Complete Set of Four Rims of same Design... After 20 Years of Havin´ the Same Car Drived in our Pathetic Roads, Full of Pot Holes, etc... Some Rims where Fatally Damaged, so I Changed some... Then the Subie looked like some sort of Ugly, usin´ Different shape Rims Front / Rear... That´s Why I Changed Pattern.) And Now, Looks like This : Those are Cheap but Nice Lookin´Rims, and Finally All of ´em are of the Same Shape! Both my Subies got changed the Pattern. Good Luck!
