Everything posted by Crawlerdan
Show off your roos Mileage!
not only does she have 405k on her now, but shes feisty enough for a 4200 mile round trip around the west coast and on to the famed rubicon trail! no i didnt do the whole thing, but i did play on the slabs and raise the eyebrows of many jeepers
auto seat belt issues
Crawlerdan replied to Crawlerdan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot an option on this one , we tried . It's fubar
- auto seat belt issues
Crawlerdan replied to Crawlerdan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgreat find man!! the whole auto retract thing failed, complete failure, stuck half open- auto seat belt issues
first gen leg with auto belts, they failed...duh they all do customer wants to know if i can install seatbelts out of a newer legacy in her car, anyone done this? im sure its easy but want some feedback before i spend her money- Show off your roos Mileage!
- 1990 legacy l to legacy rs conversion help!
Crawlerdan replied to 90legl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you want a turbo engine- you will need to modify your xmember for an up pipe, or use a turbo member legacy turbos used the ej22t- it will bolt in fine, your ecu will probably run the turbo, but not safely, you will need a stand alone harness, or swap to a turbo set up you can use your trans and rear diff. but they will live on borrowed time if you boost them hard. shrapnel for the trophy case definitely- motor swap
Crawlerdan replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmake it fit, i just use the one or two holes that line up- Dual range JDM transmission
i could trade you something as well- 4WD Button Relocating..
ya what he said- 4WD Button Relocating..
ive relocated the switch many times, dash, console, steering wheel on a rally car lol if the switch itself is ok, just relocate it- I should know this
Crawlerdan replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell crap its an aux filter. which means you should have had a tow pkg from factory. weird look here-http://parts.subaru.com/a/Subaru_2005_Outback25L-4AT25I/_52093_6022085/AT--TRANSMISSION-CASE-ATF-FILTER/B13-154-09.html- I should know this
Crawlerdan replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno filter, probably cooler lines. the filter is on the drivers side trans case on those years- Guy with EA62
yes a vw trans cam hold that power, they do thousands of times a day, if they are in decent shape the ej22 into a vw is a common swap- 99 OBS, engine swap, delta cams, low rpm missing/hesitation
Crawlerdan replied to blk99obs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi recently had the same symptoms. i discovered that the stock high mileage fuel pump was fine on the stock engine, but the cams allowed more air and fuel (duh) and the pump couldnt keep up at higher rpms. replaced it with a new one and tahdah not sure if that will help, but thats what happened here- 87 gl Level Front Lift s
i have many times, i have an 89 loyale right now with 2 inch spacers in front only, just add to the strut tops, no need to mess with cross members or steering good luck- My collection of Roo's
mmmm tasty old iron there buddy- 29 Years as a Tech in the same location 10-20-1986 - 04-07-2015
well said jeszek. couldnt have said it better. good techs that are honest are few and far between. youll find home soon. if i could afford you youd have a job here brother- New to Soobies - Building an 818R
ya....youll fit right in.we need more info and more pictures . subaru porn appeases the masses haha- Subaru Ambassador?
im having problems ordering goodies using the ambassador bucks? any ideas?- motor swap
Crawlerdan replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno. you will need a 2.2 intake, and find a way to run an egr valve- Subaru Ambassador?
i did yesterday. kinda cool.- Hello from Montana!93 Loyale owner :)
hello from the bitterroot valley. i was in libby thursday welcome aboard! - auto seat belt issues
