Everything posted by Partsman
Cruise control retrofit?
Thanks guys! Yeah, I am wanting to do the OEM deal - NAPA stopped selling the aftermarket CC's a long time ago because they were pretty sketchy, so I am leery of getting one, esp. if JC Whitney has anything to do with it! Alldata listed a part number for a kit from Sub to put cruise in at the dealer back in 1988. Man, I hope it doesn't require harness replacement!
PCV valve replacement
What kind of hose did you get at Advanced? A preformed heater hose? If so, it will get eaten up by the petroleum fumes very soon and melt. Go to Subaru or the junkyard and get the right one SOON!
heater fan fixed
You should check and see if the dealer will cover the repair - sounds like recall time to me!
Just curious: Has anyone put cruise into their vehicle that didn't originally come with it? What components are necessary to get from the boneyard?
Snow!!!
You snowboys should see it: Snow in the Willamette valley turned to ice - Subaru wonderland! Just have to watch out for people who can't drive!
Pug daymare
A cold day in the wrecking yard is much better than a warm day at work!
buggy defrost Q
More than likely it's the fan - they wear out after a few decades.
water pump, or no?,83 GL WAGON
If it sounds like the water pump, then it probably is the water pump. Imminent bearing failure won't cause temp readings to go up - just noises. Pump is $35 new, $22 reman at NAPA.
Awesome Loyale test-drive and some serious questions
I don't know - if it was me, I'd like one with better records and less cancer. Check prices in your area - there are plenty of these wagons out there, and they all come standard with the factor!
Best Oil opinions
I use NAPA (Valvoline in a cheaper wrapper) 10W30 in my EA82 - don't like to use the thicker stuff in small engines. You get a little better mileage with the thinner oil, too!
highest mileage?
233K 50K on second engine - first engine was changed by my Dad because it leaked oil - of course, this one leaks oil too:D ! So I have a parts EA82 available.
oil pump seals
Mickey Mouse is NAPA/Victor # B45702 Pump seal is NAPA/CR #7205 For the other O-ring, all I see is the kit mentioned earlier by Flow that has it all - Beck-Arnley #039-6320 - NAPA sells as well. If you want to do the crank and cam seals, the best seals NAPA sells are in the timing cover gasket set NAPA/Victor JV-1028 - it also has the rubber timing cover gaskets, the oil pump seal, and a couple of thin seals I can't identify
Getting off a stripped brake line
Is it a piece of line with inverted flare fittings on each end? You can buy a straight piece of line at NAPA and bend it to match. Or is it something SPECIAL?
Do you think this could be Plug related? Or is it my carb.
Be sure and bring in the OE# off the carb to get the right kit - NAPA lists two kits! Partsman 88 GL wagon 5spd D/R
batteries and chargers
By the way, what is "jacking the SOA battery?" Partsman
Well actually - A fully charged battery has appx. 12.75 volts. A battery at 12 volts is almost fully discharged! Your charger should put out in the range of 14.4 to 14.8 volts to be running most efficiently - not sure about the little 1A chargers, they may run differently. If you cycle your battery between charged and fully discharged very many times, it will go bad prematurely. Vehicle starting batteries are designed to start the vehicle (duh!) and then be recharged back to full by the alternator. This is why guys with Big Arse Stereos eat batteries. Hope this helps! Partsman 88 GL wagon 5spd D/R
super ultimate hp gain ground wire?
It's the "handling" charge that gets you - since the guy charges $90/hr for his time - must be a lawyer or a dealership mekanik! Partsman 88 GL wagon 5spd D/R
pcv location
Like I said, find a parts guy who is willing to actually work to find you the right parts (who DOESN'T think he knows it all) and stick with him! Partsman (who doesn't know s**t, but is willing to look!)
suggestions for new clutch
On the subject of lifetime warranties: Here's the deal. Nobody is going to offer you a lifetime warranty on a clutch against anything you can do to it. If you install it and run it at slipping until it tears all the lining off your parts store will probably laugh in your face. Nor are they going to warranty it against wearing out if you drive normally and need a new one in 100,000 miles (or whatever). Clutches are DESIGNED to wear! The lifetime warranty is against manufacturer defects - like a bad spring, etc. The other way you can get caught, even on a legitimate warranty, is if you don't retain your receipt. KEEP ALL RECEIPTS! NAPA's warranty is 12 months on clutches BTW Partsman 88 Subaru GL wagon 5spd D/R
pcv location
GD - Yeah, the guys that code in "per car" amounts sometimes mess up. If I flip the screen to Beck-Arnley bearings, or if I pull out the bearing paper catalog there is a specific message that it takes two bearings per side; plus I know by having done the job (what an annoying sound when one goes bad!) My best advice is to find a parts person who you trust that is willing to go beyond "that's what my computer tells me, so it must be right." From what I have heard from customers who come in to me cussing about getting the wrong parts down the street, I think NAPA has the best cataloging in the aftermarket. QMan - You mean to tell me that if you put in my NAPA PCV valve into your car that is in good condition, that it will start sucking oil? Do you actually have experience with this? If so, I'll get mine at Subaru too! Partsman 88 GL wagon 5spd SPFI D/R
Headlight Bulbs
Yep, 9004 Partsman 88 GL wagon 5spd SPFI
pcv location
NAPA part# 2-9254 - we sell it for $4.99 here. What's with the hostility towards NAPA? Jeez, as long as you give me the right info, I'll come up with the right part for you at this store! Partsman 88 GL wagon 5sp SPFI
Good Additive for PS?
I like Lucas for noisy pumps (shuts up old Ford pumps immediately) and SMALL seal leaks. Partsman 88 GL wagon SPFI 5sp
pcv location
HEY! Can anybody tell me real quick where the pcv valve is located on an 83 GL 1800 wagon? I looked at this vehicle with my customer and can't see it. Partsman (not MechanicMan)
EA-81 Disto disassembly
"Bushes" means bushings, as in the bushings that keep the shaft tight in the housing. They are soft so they wear out instead of the shaft. He probably has more time than money and isn't afraid of getting a little greasy! Partsman
