Everything posted by porcupine73
my 91 legacy sport sedan wont start.Help
porcupine73 replied to scoobyleg1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHm...okay, well if you tried the jumper wire to the starter solenoid and already tried starter contacts, then it pretty much has to be one or more of the following: (a) new battery is faulty, ( starter + batt bad connection, © starter ground connection bad, (d) some other internal fault in starter i.e. try different starter.
Stuck Axle in Steering Knuckle
porcupine73 replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTypically when they're stuck in there it is because water got in there and rusted the splines into the hub. Assuming of course you've gotten the axle nut off...... If you replace the axle, get a Subaru OEM reman axle or an MWE reman axle. Parts store axles there seem to be a number of posts about issues after using them. Too much torch heat can melt the grease in the wheel bearing and/or melt the seals.
porcupine73 replied to scoobyleg1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh ok...could be the starter contacts then, or a bad + bat or ground connection. The contacts are only a couple dollars, might be able to get them at napa or someplace. There is a good thread on here somewhere with pics of the starter taken apart and the pitted contacts. Didn't look too hard to do.
porcupine73 replied to scoobyleg1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNext thing I'd try (if you didn't already) is the fused jumper wire from battery + to the starter solenoid and see what happens.
porcupine73 replied to scoobyleg1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe try starting it with the selector in 'neutral' then. Also maybe try tapping the starter lightly with a hammer and see if that makes a difference. Sometimes when the contacts just start going bad it intermittently won't start and the hammer tap sometimes will get it going.
porcupine73 replied to scoobyleg1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi scoobyleg1 and Is this an auto trans or manual trans? First thing I would try is using say a 20 amp fused jumper wire from the battery + terminal to the starter solenoid and see if it cranks then. If it cranks then the problem is somewhere upstream. If it does not crank then the starter itself may be having an issue. Is the large ground cable from teh battery that connects to one of the starter bolts reconnected? Battery cables nice and clean and tight after the new battery install? Battery passes load test?
P0183 Fuel temperature sensor A circuit high input
porcupine73 replied to akafriday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure why this would impact mileage. It uses fuel temp to know when to run the integrity test. It basically makes sure you have no leaks in the fuel system, which would allow raw fuel in the atmosphere. In an endwrench article for enhanced evap soobs it says: To test the integrity of the [fuel] system, the system shuts off all access of the tank to the outside atmosphere. [then a bunch of other steps]. The testing of this system is only conducted once per drive cycle and only under very specific conditions: • The fuel tank must contain less than 9.6 gallons of fuel. • The fuel temperature must be less than 113°F. • Engine speed must be over 1500 RPM. • Vehicle speed over 28 MPH. • Throttle position must be mid-range. • Intake manifold vacuum must be equivalent to cruising vacuum. • 455 seconds must have elapsed since engine start.
porcupine73 replied to akafriday's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk good fix and thanks for the update! I can't update my previous post because it's too old, but the ECU uses the fuel temp sensor input to know when it can do the evap fuel system integrity test.
tire studs where and how?
porcupine73 replied to MilesFox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFirst you have to get tires that say 'studdable'. Then you have to find a tire shop that is willing to stud them. Tire installers had doing studs because it is a pain to install all those little things in four tires. It might be illegal to sell studded tires in your area maybe. I got them a couple years ago here in NY; but it's like a $500 fine if you run them outside the alloted dates of November something to March something I think it is. Studded snows main advantage is on ice, that's where they shine. They tend to have longer stopping distances than good snow tires on almost any other condition.
fuel smell coming form defrost blower (1995 legacy)
porcupine73 replied to lsayyah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. I have been noticing an increased number of such posts now that it's getting colder outside. Sometimes it turns out to be one of the several short (1-2" long) rubber fuel lines underneath the intake manifold.
Will Outback/Forester springs&struts work on a '96 Legacy?
porcupine73 replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi Tide13. Not sure if you mean for SuperRu or for me, but for the '96 no I havne't noticed much of any change im mileage. I did, however, notice a lack of power for take off on my '96 with the larger tires installed. Others have said they notice no difference when larger tires are used, but there is a difference. It seemed slightly underpowered before. Now it seems reallllyyyy underpowered!
porcupine73 replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow.....sounds nice to have all those takeoff's from an H6...so I take it the H6 is hottttt t too!
New Pics Of the Imp
porcupine73 replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll I can saw is...wow! The more I see of that style the more I like it. Congrats on the new soob!
porcupine73 replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow SuperRu that is hott! Looks great. Yes I have some 225/60R16 xice on my '96 now, and they do rub sometimes in the turns, but not enough (yet) to make me take them off.
Could A Clogged PCV cause.......
porcupine73 replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmm...I don't think so but I could be wrong. Common causes of soob misfire on that era are (a) non NGK spark plugs, ( non OEM spark plug wires or old spark plug wires, © carbon buildup or other cause of valves not closing complety.
Blus home :)
porcupine73 replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCongrats on getting Blu back nipper! He does look to be in his glory once again.
Sound Off: How many miles on original HG?
porcupine73 replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2000 Outback wagon 2.5L ..... 120,000 miles zero coolant leaks, and counting! Also '96 and '94 Legacy but those have the 2.2L's.
remote keyless entry--blinking parking lites
porcupine73 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck out http://www.cars101.com/subaru/keyless.html or the owners manual should have it in there somewhere too. I think yours is the code alarm.
porcupine73 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure about any 'universal aftermarket' units, but these are always available on ebay.
rear separator plate EJ18/EJ22/EJ25
porcupine73 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. My guess is at least the 2.2 has it as well, since the same part # 11831AA210 is listed for Legacy 1990-2007, Impreza 1993-2005, Outback 1995-2007, and Forester 1998-2007.
porcupine73 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the button was never used before, it might be kind of taped up in the harness under there.
97 Forester or Outback
porcupine73 replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHm....good point! Ok maybe '98 Outback vs. '98 Forester then...hehehe. "The Subaru Forester is an all-wheel-drive car based SUV made by Fuji (Subaru) in Ota, Japan. Introduced in 1998, it shares wheelbase and dashboard with the Subaru Impreza. Only one engine, the 2.5L is available. Turbo starting in 2004."
porcupine73 replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHm...not 100% sure but I think Forester has the (slightly) higher height. However, Forester is based on the smaller Impreza base. Check out http://www.cars101.com for all sorts of soobs spec info.
porcupine73 replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. Not 100% sure. My impression is yes they will fit. The issues with the KYB GR-2's seem to be that sometimes there is no spot on the strut to mount the ABS cable, so a wire tie or simliar fastening method needs to be used. I want to do this on the white '94 too.
porcupine73 replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, project complete! '96 Legacy brighton now has '96 Outback struts, plus '96 Outback scorpion/king springs lift springs, plus 225/60R16 xice tires. Ground clearance is now ~11.5". Ride is pretttyyyy stiff but I love this vehicle!!! The red soob is the '96 legacy with the outback struts and outback lift springs. The white soob is a '94 legacy with the original struts/springs.
