Everything posted by porcupine73
1994/1995 Subaru Forester?
porcupine73 replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight on, 98. http://www.cars101.com/forester.html#about Introduced in 1998, it shares wheelbase and dashboard with the Subaru Impreza. Only one engine, the 2.5L is available. Turbo starting in 2004.
tire chains
porcupine73 replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru says use them on the drive wheels only (if it's front wheel drive) or the front wheels only if it's AWD. Your owners manual will tell what type of chains or cables are permitted. Certain models cannot use them because there isn't enough clearance. Usually it says something about SAE S type chains and then don't exceed 19mph or something like that. I think the assumption is you won't be driving for long periods on dry pavement with the chains on. If you can't find your owners manual, register at my.subaru.com and view it for free (if you have a '95 or later I think it is). Or contact Subaru and if they have the manual they will send it free, at least that's what their web site says. Also cars101.com has info about the chains for soobs.
Odometer displays "Ill.5"
porcupine73 replied to Bob K's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi Bob K. I think that is the illumation level setting. I saw another post like this, and the person I think corrected it by rolling the adjuster forward and back a dozen or so times (to clean the potentiometer/rheostat). Maybe if it's right on the cusp of switching from say 4 to 5, then periodically it does so.
Speed Bleeders® Part #s?
porcupine73 replied to Bluestone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got the Russell speed bleeders from summitracing.com for my '96 and '00 and they were different sizes. Darn if I can remember which year took what size. I know for the '00 I removed a bleeder, measured the threads, and ordered by size because the application chart didn't list '00. edit: ok I checked my order history and it was 7MM X 1.0, Russell 639570 The other was 10mm x 1.0 Thread Russell 639560 Hm....now way was it... I'm pretty sure the '00 was the 7MM x 1.0 But if you have the GT you might have different calipers than my '00obw.
Quick question: Where's the Coolant Temp Sensor?
porcupine73 replied to BobSmalls's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, the coolant temp sensor (CTS) for the temp gauge is a different sensor from the engine coolant temp sensor (ECTS). The CTS is located right next to the ECTS though.
Re-post removing rotos on '05 Legacy
porcupine73 replied to SkipII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhehe...right on a 1 is definitely involved! I have noted that the normal hardware store bolts are good for maybe one or two uses in wedging off the rotor or drum. It seems to gall the bolt threads. The drum/rotor I believe is cast iron, which is pretty hard compared to the typical hardware store bolt. Even the bolts from the 'puller' kits bend pretty easily in this job.
Oxygen Sensor Tools
porcupine73 replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX22mm or optionally 7/8" 6pt wrench is your friend on this job. On '00obw though, connector might not fit through the wrench, in which case 22mm or 7/8" flare nut wrench would be helpful.
97 2.5 DOHC - able to assemble heads on motor?
porcupine73 replied to davebugs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAFIAK this is OK. You should however recheck valve clearances after everything is assembled. Yes you can have intake to exhaust valve interference on that engine.....
Replacing DRL Bulb on 2002 Impreza Sport.
porcupine73 replied to mr_mallard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi. It has a separate DRL bulb? Different year/model but on my '00obw the 'DRL' is simply the high beam head light bulb run at reduced power.
porcupine73 replied to SkipII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe rotor/drum tapped hole (on OEM parts anyway) is M8. The pitch is standard; I forget if it is 1.0mm or 1.25mm. I think 1.25mm. Right on with the brake bleed order. It is opposite of many other makes.
Fuel Filter?
porcupine73 replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably; I used a purolator one once. You can compare the 'nominal' filtration level if the data is available; usually it's about 20um.
Sway Bar Links?
porcupine73 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not too difficult. It's only two nuts per endlink. You are supposed to replace the nuts as they are captive/self locking, but many people just reuse them and maybe put some blue loctite on them. You might go for something like whiteline endlinks as they are not much more or maybe even less than new OEM endlinks.
Differential Seal?
porcupine73 replied to legacyak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes Subaru calls for a sealant for the rear diff plugs. Your manual trans drain plug has a copper sealing washer I believe, which is good for at most one use. It is covered in this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=82095
Mountain passes, traction tires, and AWD?
porcupine73 replied to 211's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have an '00obw too. I think the manual says for chains use only SAE S type chains or something or cables, on the front wheels only, and don't drive more than 19mph with them on. There isn't a lot of extra clearance in the wheels wells for chains.
'00 Outback stalling. HELP!!!
porcupine73 replied to nixon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny signs of bad battery or ground connections or anything? '00 Outbacks, at least U.S. ones don't have a MAF (they use the MAP speed density thing). Good point about the LPG stuff, unless it has a piggyback controller it seems sometimes running on lpg causes bad memories in the ECu for switching back to petrol.
Subaru Legacy EJ20
porcupine73 replied to jamesnielson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich cylinder # is not firing? Here's where the ignitor is on my '96 2.2L...not sure if the location is the same for yours..
P0031 troubleshooting 2003 VDC H6
porcupine73 replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHm...I've seen this posted a couple times before for that era soob and I think in those posts it turned out to be the relay/control circuit.
4EAT won't shift out of first - install a switch to make it shift?
porcupine73 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAccording to endwrench, unplugging the trans harnesses puts the trans in failsafe mode. The AWD is engaged as it indicates turning a front wheel by hand with it in neutral will make the rear wheel turn as well. The problem I can see with switches is the TCU controls most of the solenoids with varying duty cycles from 5% to 95% at 50Hz; a switch can't really mimic that (unless you're fast!); maybe that's already been addressed in this thread.
trouble entering remote programming mode.
porcupine73 replied to Mancomb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen you cycle the key from off to on, how many clicks is that? Do the dash warning lights come on when you go to on?
axle change, need a wise man
porcupine73 replied to yohy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTrue any single experience is anecdotal at best but at least it's something! So far the viration thing after replacing axles people sometimes report is the most mysterious soob problem I've seen posted.
Brake Questions????????
porcupine73 replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight on 'pot' is the piston. It also depends how it is laid out. i.e. two pot floating calipers might have both pistons on one side, sitting on sliders so that the caliper can center itself on the rotor when applied. Other fixed caliper styles might have two pistons on one side of the rotor and two on the other side or something like that.
96 Legacy 2.2L Oil Leak PLEASE HELP
porcupine73 replied to stonecloser's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell sounds like you got most of them covered. Does it seem to be leaking between the engine and transaxle? This is what the upgraded oil separator looks like:
porcupine73 replied to yohy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds good! Haven't heard of EMPI before. Would be interested to know if you experience any odd vibrations with these axles?
1996 Outback OBD I or OBD II system?
porcupine73 replied to Duncan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, often areas test of ODBII includes that the CEL/MIL must be illuminated when the test system says to illuminate it.
sensor question
porcupine73 replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI looked into this a while back, thinking to pick up a set as shelf, well cargo area, spares. I forget the results....I think '94 has some different part #'s and the crank sensor was like $300. I did the part # search/comparison at http://www.subarupartsforyou.com
