Everything posted by porcupine73
Why a different Slider pins on the front calipers
porcupine73 replied to Petersubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've wondered too; my guess is it is to help prevent chatter in the pins when stopping. i.e. the prescribed order is the best for smooth braking.
how many volts to the speedometer head?
porcupine73 replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX'99 Legacy speedo heads are known to have this issue.
Changing camshaft support o-rings
What year and model soob do you have? That pic is for the dohc.
Yes that is a good question.......I wouldn't put it past some dealers out there to just sell the closest size o-ring from a harbor freight bulk pack.
Leak behind oil pump wall help
porcupine73 replied to CMohan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes I use just a little of that gasket adhesive stuff to hold the o-ring in the block recess so it doesn't fall out. The first time I did it, the o-ring fell out of the recess but I pulled the oil pump back off to double check something and noticed it phew!. o-ring part # varies sometimes for different years
well I gave my o-rings acai berry for a couple weeks before installing them. just kidding. I can't remember if that is the old o-ring or the new o-ring on there. Does your o-ring size match up?
- Oily spark plug sockets
porcupine73 replied to ott_leg01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX- 1996 Legacy Outback-- AT jolts from 1st to 2nd
porcupine73 replied to healyme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInteresting.....I also have a '96 Legacy Brighton I got in '03 and it has always had a kind of harsh 1-2 shift as well. Here are the links LINK LINK for some reason is prepended usmb.org onto the front of the ones up last post ^^^- Check Engine Light - Flashers
porcupine73 replied to jeffroid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs already mentioned, vacuum leaks. Did you replace or check the air filter or anything just before this problem started?- 1996 Legacy Outback-- AT jolts from 1st to 2nd
porcupine73 replied to healyme's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't seen it posted too much lately, but there used to be some saying that if the line pressure solenoid dropping resistor on that bracket at the RH strut tower burned out, it could cause harder shifting?- Can i install LH camseal off the engine?
I have done it both ways; doesn't seem to make much difference either way. If you do it before, maybe grease the cam a little bit to help the seal slide over it without getting nicked.- Crank pulley bolt off, but pulley stuck..
haha yes the 'special tools'. I have many scraps of wood and stuff that have been turned into special tools so I always write 'NOT SCRAP' with a a sharpie hoping it will stand a chance. This my 1-1/4" brutus tool in action: nope she wouldn't budge: Ah that's more like it:- 2000 impreza rs ( Studdering when accelerating and surges )
porcupine73 replied to 2000impreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe you have a bad connection somewhere along the path.- Crank pulley bolt off, but pulley stuck..
hehe yes that sounds about right. I put a light coat of antisieze on there so next time maybe she won't be so stubborn.- fuel pump issues 1995 Legacy
porcupine73 replied to bfd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe your fuel pump relay is flaky. I think some ECU's from that era but maybe earlier the transistor driving the fuel pump relay got cold solder joints and needed reflowing.- Crank pulley bolt off, but pulley stuck..
First get good penetrating oil on the shaft so it can get in there, you probalby have a little rust in there. It makes it almost impossible to get off then. After that a puller of some sort might help.- Replace water pump but there's a minor leak
porcupine73 replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomeplace such as Ace Hardware. It's just a metric bolt with standard thread pitch in its size, proobably M6 iirc or possibly M8.- So what the heck is Shell (or showa) 6459N wheel bearing grease?
porcupine73 replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's mostly in Japanese...but http://www.oranpage.com/product/196171 Here's some place that has it, looks like Honda used it also. However price is in euros so don't know where they're out of http://www.cmsnl.com/products/greaseshell-6459_52102hn2p00/- So what the heck is Shell (or showa) 6459N wheel bearing grease?
porcupine73 replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh let's see...no suprise it is a grease made in Tokyo by SHOWA SHELL SEKIYU KABUSHIKI KAISHA so might be hard to find around here. Hm that info is from '98 who knows if it's even made anymore.- cylinder compression seems to measure low
porcupine73 replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe soob numbers of like 190psig per cylinder are fully charged battery, cranking engine, and also throttle blocked wide open. Hand turning would almost be more like a cylinder leakdown test.- Crank shaft pulley bolt won't come out
porcupine73 replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I have used impact wrench on axle nuts. But they seem to come off just fine with the long pipe method as well so I use that since soob says wheel bearings can be damaged from the impact wrench.- Strange brake symptoms - 96 Legacy wagon
porcupine73 replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe look into that bolt thing further. Usually the bolt that will snap is the caliper bracket to bearing housing. If it wasn't fixed right the caliper might be on by only one bolt and might be rubbing/banging against the inside of the wheel.- Timing Belt removal cam calibration to marks
porcupine73 replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow was it running before? It is always possible the existing belt is a tooth off somewhere along the line.- Crank shaft pulley bolt won't come out
porcupine73 replied to DavieGravy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYah that's generally what it takes. I go with 3/4" drive breaker bar and socket with a four foot piece of 1-1/4" black iron pipe on it. It usually resists....for a little bit but I keep telling it resistance is futile. That method is also helpful for the axle nuts. - Oily spark plug sockets
