Everything posted by ocei77
FSM for first gen Legacy needed (specifically for AC system components)
ocei77 replied to floridarich's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtry here Index of /Auto/Japan/Subaru O.
The dreaded timing belt tensioner bracket!(phase 1 ej22)
ocei77 replied to Leggy5676's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMight. Won't be able to check until I get to my storage unit next week. Will advise. O.
ocei77 replied to Leggy5676's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you referring to the older 2 piece tensioner bracket? O.
97 Legacy Suspension
no, not worth it. Just get some KYB's for your model and call it a day. O.
2000 Legacy/Outback driveshaft for AT - unavailable except for more than $600!?
ocei77 replied to Boringchuck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso check facebook marketplace and any u pull it salvage yard. 1O.
1996 Subaru Legacy with bad rear wheel wobble
ocei77 replied to subyworkshard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your sure your lug nuts are tight , then likely your bearings are shot . To replace the complete hub is not that hard. Just time and jack stands. Go here for fsm:Index of /Auto/Japan/Subaru
resurrecting 1996 Legacy 2.2L - what's this vacuum hose
ocei77 replied to kite's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe hose is the vapor line for the fuel system. Go here for fsm for car: Index of /Auto/Japan/Subaru O.
New headgaskets for JDM engine?
ocei77 replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs others have said,, replace them. Just the EJ22 had composite gaskets. The early EJ25's had single layer gaskets, they later went to MLS types. O.
Clutch replacement
ocei77 replied to joshsmith3662's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've done it both ways but without help or a tranny jack, i'd lift the engine. You have to get it up high and its no fun wrestling that weight. Yes you have to drain the coolant and separate the exhaust (don't forget to disconnect the O2 sensors), but I can do this without help. O.
Bad 2.5 in 2007 Subaru Outback
ocei77 replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsing your heads and intake manifold any 2000 to 2012 will work. Better options would be 06 up. In 05 Subaru went to Drive by Wire . The Radiator and water pump housing leads are in slightly different places, so don't cut those hoses you may need them. Depending on block year, you may need the radiator. You can use an Impreza block, but the oil pan is different. I believe those are the differences. If I think of anything else, I'll chime in. O.
tire size, increase size
ocei77 replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis may help https://www.wheel-size.com/calc/ O.
1994 Legacy GT tailshaft compatibility
ocei77 replied to Raynman1989's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXlook in opposedforces.com look at your car. find the part . Go into it and look at the usage info which will tell you what other models used the same part. Hope this helps. O.
98 Legacy Outback, o2 sensor.
ocei77 replied to Espey16's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you go to live data, just select complete set and scroll down to the O2 sensor in question. You should see the voltage fluctuate. The car has to warm up and the system in closed loop Hitting enter will graph that function. You will see something resembling a square wave. Don't remember the normal values. Listed in the DTC code section of manual. again, no cel sb no worries O.
98 legacy wiper switch
ocei77 replied to Espey16's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcheck the manual from the other post you made. O.
ocei77 replied to Espey16's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif you're not getting a cel, you should be good. If anyone has scanner with a live data function, you can look at the voltage to double check. IIRC the whites are heater wires and black the ground. O.
2001 Forester - Coolant boiling
ocei77 replied to kruteck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBeen a while since I worked on this series, but IIRC thats the air temperature solenoid. Look at the manual here to confirm. http://www.main.experiencetherave.com/subaru_manual_scans/ There is still some air. Make sure the overfill bottle has coolant. Loosen the top radiator hose. If coolants starts coming out, the block is full. If not, add to the top hose then reconnect. Leave the radiator cap off overnight and check level in the morning O.
96 Legacy EJ22 injectors won't fire
ocei77 replied to cj3waker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure the cam sensor is not covered in muck. O.
Heater core swap in 2003 Legacy advice wanted
ocei77 replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoubt it, but just in case, look at the heater core in the service manual. Had to do it once on a 98 Outback. Three hours out and three hours in.
Phase 2 SOHC short block interchange.
ocei77 replied to biggman100's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes that hose. It varies in method of attachment and size in various years.
ocei77 replied to biggman100's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso your 03 crank sensor must stay
ocei77 replied to biggman100's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIIRC up to 2012. Diiferences are 06 heads up have VVT, but you are not using them anyway. Impreza engines will work, but you need to use your old oil pan. Your 03 manifold stays. You will have to work around the PCV valve arrangement as i am sure the manifold to air box is diffent. Surely someone else will chime in. O.
Do 1991 & 1990 Legacy Parts Interchange?
ocei77 replied to Mistydawnlegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAFAIK from 90-94 are mostly the same. Look here: www.main.experiencetherave.com - /subaru_manual_scans/ Osei
best way to drain fuel tank
ocei77 replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan always use a siphon pump or a drill operated pump.
98' Subaru legacy outback, intermittent stalling issue
ocei77 replied to subuwu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen was the timing belt last changed? I assume this a two piece tensioner. Still has tension? Any codes?
2011 Impreza Overheat
ocei77 replied to thesmokinggasket's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre the fans coming on? Are you getting bubbles in the overflow tank? Did you recently do something with the cooling system? If so, did you fill the block first and then the radiator or just the radiator?
