Everything posted by zukiru
86 3door Runabout:FWD<FT4WD, 4 lug<5lug, EA82 carb<EJ22 or ER27 swap, rust removal
I always think of like syphilis or HIV when people use the term STD.
EJ Power Steering rack into EA82 car
Cool . as it stands I have 2 stock xts a 86 dl and a loaded 88 gl the manual steering makes no difference in the 2 for me. I prefer driving the manual steered one and was just kind of wondering. now that I think about it I can see the manual steering wearing on one for long runs. I guess I I'll see how manual steering works out for me when rally x starts.
83 Pickle project planning
I know you said no debates. frankenmotor is high compression. Might be easier/better to supercharge a stock 2.2
What does power steering have to do with ”handling the power”? Just curious. IMO the power doesn't really affect the steering
Alignment problem.
If the part is in good shape, steering angle at install shouldn't matter. the parT is angled. It should self align when tightening the nut. Make sure you got it tight.
So crazy it might just work
not to mention the damage to the damper portion of the struts done by driving around with no air in them. also as you lower a car you should stiffen the springs, (to prevent bottoming out) the exact opposite happens with low air bags
POP! goes the brake line
Yep. But I did inspect them. no cracks yet...
'89 RX: Project Rally
That car is hot and I hate you. That is all.
The Awesome Vehicle Picture Thread
Pretty cool?
Old Subaru rally videos
my soon to be rallyx racer. not that it really counts but maybe when I have pics of dirt flying from the wheel wells... "special stage" mag cover is my desktop now, thanks!
RX questions
like how mine had the thermostat pulled over a bad electric fan. all is good now though!
RX sway bar ??
Yeah. The rears are the same shape. My xtgl bar is on my Xtdl now. Just to see if it would fit. which was a 20MM like the chart says. and boy howdy the car turns even easier now. manual steer plus 20mm rear is a very sporting feel!
yep. history in person(sort of). pretty cool.
RX sway bar ??
oh and who has the skills to edit in my XTDL witht he 13mm bar?
RX sway bar ??
yeah I guess so. I imagine there wasn't an XTDL on hand to measure that day either. can anybody tell me the difference (if any) in shape between a 4wd sway and a 2wd sway?
Parking thread. Share your painful parking situations.
I'll take some of that dirty Audi all up on me.
RX sway bar ??
Wow I measured my rear bar on my XTDL and it was only 13... anybody know what years this chart is for?
EA82 no AC mount pics?
Reverse drill bit Or... helicoil.
need the xt board web address please
http://subaruxt.com/forum/index.php But its acting weird today. Like the formatting got munched.
ea82 Cylinder Head interchangeable?
Cam cases are not part of the head. They are separate entities.
In Need of EA82 Heads
okay so you already did a cleaner. cool. (seafoam is just a good cleaner that can be added to the oil and run through the engine to clean it up) I have read of a few instances where the reseal wasn't enough and the car needed a whole new pump to fix the issue. but that is not common. yes you can get to the pump without pulling the engine. the timing belt drives the pump. have you done timing belts?
yeah it can affect just one head. seriously though run some seafoam first. the next place to look is new gaskets for the oil pump.
before you change the head. first. run a bit of seafoam in the oil. (you can get it at walmart) some dirt could be causing your stuck lifter. (this fixed mine) if that doesn't work reseal the oil pump. if that doesn't work reseal the cam tower. if that doesn't work replace a lifter.
Is there a way to turn full time 4WD to pushbutton?
they are not glaringly stupid questions, but they are answered in the link. if you just disconnect the solenoid without adding a load.... you can put the transmission computer in limp mode. which is not good. is it was a simple as pulling a fuse there wouldn't be a how to thread.
You can measure it with a string.
