Everything posted by woundedbrat
Whats it worth
I just found a 95 legacy on craigslist and was just wondering what you all thought it was worth ,Its a rolled car with 105,000 on the ticker2.2 5spd awd. this would be a swap for my current legacy witch is an auto of the same year Looking to swap the motor and possible the tranny. Will rebuild the old 2.2 for my brat which already has the d/r 5 spd
Guess What
Hmmm... I wonder why we're becoming such a violent country? What do you mean becoming, violence is as much a part of america as apple pie .I am not trying to advocate it but if you think its bad here try living somewhere else lets say isreal. go to the gaza strip for a couple of weeks and you will return with a much deeper appreciation of what we have here.
What Is Sea Foam?
went out and bought some poured about half in the tank the other half I ran through the intake on my legcy. this car has some blow by issues probably bad rings and valve seals at stop lights the car would literally fill with smoke. to the point where I didnt like to drive it. Well today after I did then treatment I noticed one of my tires was low so while I aired it up I let it idle just to see what it would do. When I got in afterwards there was not a hint of smoke or the usual acrid smell of burned oil. +1 for sea foam next I'll use some on my brat.
Ice Racing - 1983 Subaru GL 4WD
How did you end up doing over all ? didyou runin 2wd 4wd what will you be doing different next year ie what did you learn?
What Is Sea Foam?
is your racing season over around here it ended last weekend how did you end up doing did you run in 4wd?
What Is Sea Foam?
so what you put it in the gas or pour it down the intake when running the motor?
Suby doesnt move in any gear......
woundedbrat replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- Suby doesnt move in any gear......
woundedbrat replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsounds like a stripped hub pretty common had a few like that if you can put it in gear while it is running and have some one look to see if the castle nuts are turning, if so thats what it is. good luck! just realized you are talking about a 96 legacy so above info was for older gen cars.- ea81 vented rotors, interchangability
don't know if this will help but my 86 brat is vented. the only other thing I can think of was a 83 wagon 2wd was solid.- going older
Dude do you see the trip odometer that car is,gulp..!! the devils ride. ( its even red)- Other cars/Vehicles we own
86 Brat 5" lift 6lug conversion custom bumper (soon to be ej'd) 87 full sized Bronco retro fitted a 5.4 triton motor and tranny with detroit locker in the rear 95 legacy automatic- Have A Sitdown with Your Subie
I have that same problem with my starter and yeah got to talk to them show them who in charge ,yeah right!- New Pics Of The "rat"
Is the wheel base as long as the wheel width. whats your turn radius ? even w/out a lift that thing will probably go through some ************e good job.- ej-22 WHAT YEAR IS BEST
what years came with roller rockers ? and were the adjustable ones different than others I have a 95 2.2 legacey with the auto tranny would this have roller rockers?. adjustible? ??? BUMP!- trailer hitches
Can't blame you for trying but I can fabricate with the best of them. just wanted some examples on how to mount it so I don't have my trailer passing me on the highway.- trailer hitches
- trailer hitches
want to add a trailer hitch to my 86 brat. I have a stock bumper and I need some ideas on how to mount it so if you could take a picture of how yours is mounted and post it I would be very grateful thanks in advance TT.- Rusty Bolts!
lots of good advice so far one thing that has worked in the past for me is to file down two flat surfaces on any exposed bolt an use a wrench to turn it. If there is no exposed bolt then use a dremel to cut a slot in the bolt and turn it with a screwdriver. the more you mess with it the more it will want to come out drilling filing grinding will tend to heat up the bolt allowing lube to better penetrate. It helps to be more stubborn than the bolt:rolleyes:- What to do with parts car?
If your DEALER doesn't mind just let it sit if he's the kind of dealer Im thinking of its not likely he'll get too motivated any time soon.:cool:- ej-22 WHAT YEAR IS BEST
You can install the 96 adjustable roller rockers on any of the motors...a nice upgrade. Send those cams off to Delta to have a grind put on and these EJ22's really move the car nicely. I believe I had them do the mild "220" on my vanagon and I love it. what years came with roller rockers ? and were the adjustable ones different than others I have a 95 2.2 legacey with the auto tranny would this have roller rockers?. adjustible? ???- Am I Reading This Right???!!!
woundedbrat replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou need to ask nipper that he posted it- Am I Reading This Right???!!!
woundedbrat replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhere does it say the city is the seller. the seller is probably a private party who bought it at auction from the impound.- Am I Reading This Right???!!!
woundedbrat replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhe probably bought it at auction and is selling it at a huge profit to himself.- Am I Reading This Right???!!!
woundedbrat replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnot trying to start an argument but you say impounded I say stolen I don't know if or why he didn't pay the tickets but I do know that taking away somebodies mode of transportation and making it more difficult to go to work is not a sensible solution to any problem.- Good Day in Junkyard! LSD -WHOOT-
congrats you lucky bastard from one jealous monkey - Suby doesnt move in any gear......
