Everything posted by tcspeer
It finally goes clunk
tcspeer replied to FSTOUR's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the lower A frame bushing you are speaking of is the ones with the two large bolts that bolt under the car near the door, they will start leaking grease when they go bad and will clunk on turns. You might also check the steering shaft U- joint, they will rattle when they get play in them.
Top Dead Center
tcspeer replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen you line the marks up you are not at T.D.C. and you can turn that right cam pully as much as you want clockwise. Is this not correct?
Top Dead Center
tcspeer replied to msmithmmx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe # 1 is the front left as you face the engine from the front. Use a compression gauge to find when it is up on compression, then when you remove the front covers you will turn the crank just a little to line the marks, this will put the pistons in the center of engine so then you will be able to turn that right cam pully around a complete turn cockwise if you lose your mark. The cam is always right when the mark is lined up. As far as taking the crank pully off I use the big chain wrench from Harbor Freight to hold it while removing the bolt. Then you must wiggle it off and you may need to use a small screwdriver to help but go easy. Make sure you do not use the arrow on the crank spocket for the timing mark, the timing mark will be the line that is on one of the spocket tabs. Also If you do not have a Haynes manuel get you one I done my first timing belt job with only that information.
Haynes or Chilton
tcspeer replied to cannonball's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour lucky our library only have the Haynes and Chilton.
Haynes or Chilton
tcspeer replied to cannonball's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo you know where the best and cheapest place is to get the F.S.M.
Changed timing belt, now overheating-Solved
tcspeer replied to [HTi]Johnson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think your problem is still with the radiator or block not being full, I have trouble getting mine full every time I have had the cooling system apart. If that dont work maybe the new t-stat is bad.
tcspeer replied to [HTi]Johnson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTurn your heater on, if it does not get hot then you may still have air in system. I refill mine the way you did but I also have heater on while doing it.
Amount of time/work involved in pulling auto tranny '98 OBW?
tcspeer replied to mnwolftrack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes there is a few yards that will contact you everytime here also, you will come to know them after using this site a few times and you can just ignore them. But this is how I found my transmission from Landrys, and many other good deals over the past year.
tcspeer replied to mnwolftrack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGive junk yard dog a chance, it is a place you post what you need and it goes out on the web to many yards and the ones that have what you are hunting will get back to you by e-mail with details, You should get back seven or eight offers on a transmission if you post there. Just make sure to check them out with the B.B.B. before buying.
park/emergency/hand brake
tcspeer replied to dolehendrix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemoved for same reason as above, I thought we were taking drums and shoes, but after rereading I see it is rear disc. (Sorry)
tcspeer replied to dolehendrix's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemoved this post after rereading and seeing where you said rear brakes are disc.
tcspeer replied to mnwolftrack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got a transmission for a 97 Legacy wagon from Landry's in NH. for around 300.00 dollars I think it was 275.00 but it has been a while back, and it cost another 125.00 dollars to have it shipped from NH. to TX. by truck freight, and they will line that up for you. I do remember the whole transaction was under 500.00 dollars. Their number is 800-332-4937 and I checked them out with the B.B.B. before ordering and they checked out with no compaints in the last three years. The transmission is still working fine. The job is easy except for the torque converter bolts, they are a bit tough. You will also have to remove exhaust, but some of this is connected with hangers so it is easy. The job took me and one other person around nine hours, but this included replacing one of the wheel bearing also.
calling Nipper
tcspeer replied to montana105's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFind a shop with a impact and pay them to break it loose.
Sorry about the new thread, water pump help
tcspeer replied to artistic_gore's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree with Dickensheets, but only with the air in system, I have never had anypart of the cooling system apart with out having trouble getting it to run cool again, I just let mine idle with radiator cap off and heater on and keep adding coolant as I get room.
temp. control
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am glad you got your disabilty, it is not easy my brother spent a long time getting his and he needed it much sooner then he got it. The Post Office gave me 45 days contentian of pay which ends this Friday, and then I get switched to workers comp. which they say will be 75 percent of pay tax free. I have to go back to Dr. next Tuesday and I think he will put me back on light duty for at least a half day, so that will cut the workers comp. pay in half.
Front Bearing Advice? 96 Leg OB
tcspeer replied to paulivan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo for it. If the bolts or rusted it may be nice to have air and impact. It is very easy to change the spindle and hub out with a used one. I have only been doing my own for a few years, but with the help I got here and the Haynes manuel I found it very easy. The front left axle will be easy to remove after getting the hub off, just knock the little pin out on the engine side of axle, the other side is a little bit harder because of the exhast. Of course it helps is you have another car to drive while you are doing this.
temp. control
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will not be at the office to see who is on the cover of the Opra magazine this month so please let me know who is on it. (just kidding) for those who dont know Opra is on the cover every month.
temp. control
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy wife, does a small Aux. Rt. in the same office as me, so she is now carrying my route, along with being my my nurse, cook, and house cleaner so she is very busy. They are in the process of getting someone on loan from another office to help out. I dont know if I could ever watch Opra, I just dont care for her or Dr. Phil. I have began to like Little House On The Prairie, I never got to see it when it was first on becaused I worked nights. I am also in the process of fighting Best Buy in small claims court, we had an extended warrany on a washer and dryer and after 45 days of trying to get the dryer fixed I gave up and hired someone else to fix it. So I am now trying to get my 149.00 dollars for the warrany returned along with the 72.00 dollars it cost to file it. Win or lose I think this one is worth the fight.
temp. control
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for asking, I am getting better, I have been able to get out of the house and go to Wal Mart, thanks to the little scotter they provide. I still have to use the walker or cruches because the Dr. dont want me to put any weight on it for twelve weeks. So I have around six more weeks to go.
temp. control
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, I should be able to find it.
temp. control
(97 Legacy wagon)The little sliding lever on the dash that controls the temp. is no longer changing anything, it stays hot no matter where it is. Does this lever hook under dash or near floor board. Thanks for any help. Only asking because of broke hip and I cant get down there to see right now.
Dire need of Legacy help? About to give up.
tcspeer replied to BLACKSTONE's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may have part of the muffer collasped on the inside, or the cat. converter, I think I would have that checked at Midas.
97 Outback Suspension Questions Help Please!!!
tcspeer replied to mtnbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you put new struts in the old springs, make sure you mark the orination of the spring to the top hat with paint marker before taking it apart. It does matter and I had to take take mine back out to straighten it. If I remember right I think the two small holes in the top hat face to outside of tire.
Water pump
tcspeer replied to drquasievil's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt most likely is the pump leaking, but I would crawl under the front of car and check the little bypass hose on the thermostat and also the bottom radiator hose and thermostat gasket. One of these may be leaking and blowing over on the cover.
I want to replace rear hub bearings myself..
tcspeer replied to mwatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI done a rear bearing just a few months back, I took the bolts out with no problem, and was able to line them back up by hand no jack was needed. If you want to do your own bearing I would suggest getting the 20 ton press from Harbor Freight and doing the whole thing yourself. I picked mine up on sale for around 200.00 dollars, and it sure beats having to go to the trouble of waiting on someone else to find time to do it.
