Everything posted by tcspeer
ok. time to reseal
tcspeer replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you checked to see if they can be done without removing the heads? I had valve seals replaced on a chev. V-8 without removing the heads.
excessive brake pedal travel when rounding corners and when shifting from drive to re
tcspeer replied to ofairlane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont know what the problem is, but yes the shoes on the rear are the same, Iam also a mail carrier so I get to take them off enough to remember. One test you can do is with the car off pump the brakes and then hold them and start the engine, the pedal should then move towards the floor if it dont it may be a brake booster problem. Also you might want to check the brakes line with some soapy water in a spray bottle as you have some one else pump the brakes.
Defrost Died
tcspeer replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you find out why the heater is not getting hot? I was wondering if maybe the little thing that hooks to the heater box was reconnected. The one that allows the hot water to flow through the unit.
Defrost Died
tcspeer replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThen wait until it gets cool and squeze the two big hoses and see if you can get the trapped air out. If you will search the past posts their is some other suggestions on how to untrap the air. I really think this is your problem.
Defrost Died
tcspeer replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour heater core is not clogged you need to get the air out of the system and make sure it is full of coolant. The heater will not get hot until you get it right. I take the cap off and let it idle and slowly keep adding coolant.
Defrost Died
tcspeer replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas the floor wet inside of your car before you started? Also did the pressure hold when you tested it?
Defrost Died
tcspeer replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour right this is not a fun job, I took my seats out when I done mine I see you left yours in, so you must be much younger then me. One mistake I made going back together with mine was not locking one of the air bag connectors and the air bag light was on. I was able to reach the one I left undone without taking dash back out so make sure you slide the little lock forward on them when you go back together. Also if I do this again I plan on changing the air bag bolts out, where they can be removed and installed with a regular socket. Also you can get a pressure pump for the radiator and hook the heater core back to the hoses and check for the leak. these are neat little tools that can be bought off of the Snap On truck if you cant find one to rent. They look like a football pump with different type of caps for the radiator and they have a gauge so you can pump to the pressure your radiator cap calls for.
Defrost Died
tcspeer replied to kimokalihi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree with nipper, I had this happen to mine about two years ago, I took my dash out and fixed it myself, however if you have the money to have it done you might want to pay someone else, it is not a fun job. It took me around 12 hours but it is only suppose to be a six hour job. If you have a leaking core it will have your carpet wet in a few days.
How to conquer the wheel bearing.
tcspeer replied to tcspeer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXArtistic-gore, i dont know how to link to the other post but this may help you.
Wheel bearing question
tcspeer replied to artistic_gore's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I agree you will need a new bearing after pressing the old one out, most do come apart.
tcspeer replied to artistic_gore's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do my wheel bearing, if you are having trouble getting the bearing housing out make sure you have removed the snap ring. Also if you will type in wheel bearing, I done a post a few months back with step by step details on this topic. Also when you go to push the bearing housing out put your adapter on the heavy metal race to push. The post mentioned above is very good. I used it to help me with my first bearing, also I bought a spindle and hub with a bearing from the wrecking yard and put on my car, and then I used the old one to practice on.
tcspeer replied to artistic_gore's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree with jamal get you one from a wrecking yard, except I would get one from close to home instead of mail order being you need it right now. When you take it off be sure and mark the top bolt of strut flange with a line from edge of bolt to flange and reinstall it to that mark so you will keep the alinement close.
Rack and pinion boots
tcspeer replied to kvaleras's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat seems high, have you checked with Midas or Pep Boys?
96 lagacy L won't idle.
tcspeer replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry John, I didnt mean to repeat what you said, I was typing at the same time, just much slower.
tcspeer replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat Shawn says needs to be checked, the hose is around 1/2 in. in size and is in the middle of the vent tubing that runs from air filter to the black box that sits on back of engine. The hose is on the bottom of this and it runs down to the idle air control valve. If it is connected then take it off at the idle air control valve and spray cleaner in it. I think you need to use carb. cleaner but check the search feature and make sure that is the right thing to use.
90 Legacy won't start. Any ideas?
tcspeer replied to 90sub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds to me like you need to pull the timing belt covers, I think one of your pulleys or idle that pull the timing belt may have came apart. That would decribe the rumbling under the hood and the over heating issue at the same time.
yorque converter price
tcspeer replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn Tx. it's around 500.00 dollars to remove and replace transmission, I dont know about the torque converter price. If you have the equipment it not real tough to remove and replace it with one helper.
hgih speed jerking help!
tcspeer replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe the spark plug wires are breaking down.
Timing Belt / Dealer Issue... Argh
tcspeer replied to pauli's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEasy on the hill-billy, they are some here.
Fuel, spark, no start
Before I got to your post I was wondering why no one had mentioned the choke, sometimes getting someone to move the choke by hand, open and then closed while you are trying to start the engine will do the trick.
Misfire Code
tcspeer replied to aboone1970's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would run some fuel inj. cleaner through it anyway, if that dont make it go away I would replace the plug and wire on the cyl. you know is misfireing, but keep the plug and wire to put back if the problem is still their. You can buy one wire from some small town independent auto store and shops.
replace all wheel bearings & cv boots '96 legacy brighton?
tcspeer replied to porcupine73's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would not change the back wheel bearing, I have 322,000 miles on the bearing in the rear of my Legacy wagon and they are still good, however the front ones have been changed around two or three times. I also would not change the shafts until the boots break. The other things probably need changing.
Tire wear question
tcspeer replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAfter looking at a tire site, it looks like you have the right word with camber. I have always thought it was toe.
Tire wear question
tcspeer replied to outback_97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt looks like the toe is out to me, probably started on the front and once the wear patten got started it just continued to wear. But I dont know if that is the correct term for this problem, its just what I call it.
Clunking noise after changing struts
tcspeer replied to dmanaenk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne other thing to check is where the bottom ring of spring sets in the bottom flange, look to see if any part of the last coil of the spring is shiny if so that means it is rubbing or hitting on it. You can put a little grease there and tap the flange a little tighter to the spring. if that dont quite it then use a large screwdriver and pull the flange just a little away from the spot that is rubbing.
