Everything posted by tcspeer
is my leg smoken to much??
tcspeer replied to subie94's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the Chev. engine they can be replaced without removing heads, I dont know about Subaru. It seems like it would be harder for oil to leak from the seals on the Subaru being the head is on the side.
Need CV Boot replacement instructions, 2001 Forester
tcspeer replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know this is not what you was asking but I was able to buy a used axle from wrecking yard and replace it with the instructions in the Haynes manuel, used axles are around 75.00 dollars and much better then the rebuild ones from the after market auto stores. If you dont trust a used one you can get the ones from the dealer and they hold up good, I dont know if they are new or rebuild. I would not want to take one apart and regrease it and then reband it sounds like to much work to me.
ABS light on. Nut holding rotor came loose?
tcspeer replied to dlm5774's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree this is the best way to take care of this, I got my last used hub for 35.00 dollars if I remember right and it's very easy to change with the help of the people here and a Haynes manual.
tcspeer replied to dlm5774's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe axle nut does not come off for a brake job, did the people that done the brakes also replace the axle? or did some other shop do that?
tcspeer replied to subie94's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSmoking after starting engine is most likely valve stem seals leaking, at least that was what caused it in my chev.
97 OB AT fluid change
tcspeer replied to tzrider's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think you will be O.K. and yes it is tough to read that stick. Maybe it over flowed at the top of dip stick.
Leaks Gas Inside-outside FIXED
tcspeer replied to Rhubey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave your freind remove the cover over the fuel pump and check and make sure the line that has the clamp that can be tighten is tight, it should be the middle one, the other two should be fine. I agree with other dont drive it like this.
Clunking noise after changing struts
tcspeer replied to dmanaenk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you change the whole thing as a unit, mount, spring and strut? If you did I would guess the strut mount is bad. If not make sure to seat the end of spring in the little slot at bottom, also the two little holes in the top hat must face to the outside. Also did you make sure you torqued that nut on top of the strut with the car on the ground, off of the jack?
Fan Noise - 2000 Forester
tcspeer replied to howards11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont have a Forester but I would think remove elc. plug and then should just be a few bolts holding it in. Unless this is easy to get to I think I would just wait it out most likely it is a leaf that will break up and blow out.
oil drain plug is stripped
tcspeer replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Fumoto is great, I have one on my Subaru.
"Whirring" noise update: VERY bad
tcspeer replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just replaced a transmission a few months back, all you need to do is make sure the #s on the transmission match, it is a # somewhat like a vin #. If it is the same then the ratio and elc. connections will all work fine. I dont remember exacty where the # is but it is on top you dont have to crawl under car to see it.
More things....
tcspeer replied to Danbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHis is a 95 so it is non interference, but it is still not good to let it break.
More things....
tcspeer replied to Danbob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would do the ball joint and then the alignment. Rusty brakes? they will be shiney after a little use.
I went off and did it again! Another Subaru!!
tcspeer replied to 4WDFrenzy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe cars were L.H.D. when I was there but it was still under U.S. control then it has now been turned back to Japan so they may drive on the right now. Actually they are a lot of right hand drive Subaru's here in the U.S. I have two a 98 Legacy wagon and a 97 Legacy wagon between the two they have over 1/2 million miles on them.
tcspeer replied to 4WDFrenzy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI bet she is at Kadina, I know that is not spelled right but I am sure you know where Iam taking about. I use to go there to play chess at their chess club. I was not up on the cars they drove I just remember they were small or they more Subaru's or Toyoto's? Also I remember that they seemed to work on their own cars more then people here in the U.S. does.
Rough Missing Idle NEED HELP Please!
tcspeer replied to wiwrx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have two other suggestions, they may not be worth much but it is what I would check next. I would get a in line plug checker only a few dollars at auto store and see if I had fire coming to each plug. If that checked O.K. I would get a set of noid lights around (20.00 dollars)and test the pigtail connection of the injectors plugs. I had a # 4 misfire and was able to find it with the use of the noid light, mine ended up being the E.C.U. around 500.00 dollars. I still think your problem is most likely connected to that E.G.R. valve, was you able to get the Haynes manual and do the test it called for.
Wheel bearing???
tcspeer replied to Buick350X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the engine and transmission was out I dont think you had enough weight on the bearing to hurt anything.
tcspeer replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dont know if you could do more damage by running it until it quits, maybe someone else will know.
tcspeer replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt leaks from the seals where the axles go into diff. I know because mine leaks bad. But it has 320,000 miles on it so I just keep adding more.
tcspeer replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCookie, sounds like you have been in this situiation yourself. Thats why I dont like any one else changing my oil always afraid they might cross thread it, even through I have cross threaded my share of nuts and bolts but not the oil drain plug yet, I did leave the drain plug out and let the oil pour out on ground one time.
tcspeer replied to wiwrx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, it does work with the E.C.U. and what I read in Haynes, sounded pretty much the same as you described it.
Wheel bearing???
tcspeer replied to Buick350X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy! it's 350.00 dollars for a Mechanic to do this and then you must wait until they can get to it, this is one of the most over rated jobs their is.
tcspeer replied to wiwrx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just checked the E.G.R. valve info. in the Haynes manual, if you can get hold of one it will tell you how to test and clean it, from what I read about it I think it should help you.
possibly picking up '93
tcspeer replied to el dan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLow mileage for a 93, the 2.2 should go 300,000 miles easy.
tcspeer replied to wiwrx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is a good place to start you can take it off and have Auto Zone check it for you, or you can ckeck it with a volt meter the Haynes manual will tell you how, plus if you check it you dont have to take it off. Or maybe you just need a new E.G.R. valve
