tcspeer
Everything posted by tcspeer
One other thing to check is where the bottom ring of spring sets in the bottom flange, look to see if any part of the last coil of the spring is shiny if so that means it is rubbing or hitting on it. You can put a little grease there and tap the flange a little tighter to the spring. if that dont quite it then use a large screwdriver and pull the flange just a little away from the spot that is rubbing.
I changed all four struts on my Legacy wagon and also changed the two strut mounts on the front. I also have one that is clanking, mine is the front right the one that I put the new strut mount on, I dont have any idea why, so I plan to buy a whole unit from wrecking yard and changing it out and see if it stops. I dont know if this sound was in the car before, as I had just bought it and had not really had it on the places where it clanks now. I think mine is bottoming out from a weak spring.
For the ones that have not found it, go to junkyarddog.com there you can place a request for any part for any car and you will get back replys from yards all around the U.S. with price qoutes in your e-mail. I just ordered a transmission from a yard in N.H. from a place called Landrys for 395.00 dollars with shipping to Tx. included. I found this from junkyarddog.
When I changed my heater core, after I finished the air bag light was on. Thinking I had left one unplugged I started checking they were all plugged in but the lock device was not pushed foward on one of them. After pushing it foward the light went out. Check each yellow connector and make sure that it is locked. You probably will only need to check the ones in the area you worked and the places the other people worked.
I have the old Black Max, a few months back it gave some trouble so I looked at Harbor Freight for a new compressor, then I went from there to Sears and I thought the prices at Sears were just as good and I am sure the quality is better. Luckly I got the old one fixed so I didnt have to replace it yet.
First make sure you have the big vacum line on from the air filter tube to the Idle air control valve, If the marks are lined up you cannot be 180 degrees out. Take the belt off again and line the two cam pulleys with the mark on the cover, then use the little line on the tab of crank spocket and line it with the mark on the oil pump. Make sure you have the broken line of belt with the crank spocket and the straight lines with the cams. Also make sure you have the crankshaft sensor pluged back in. If and when you are sure the timing is right and it dont start then check the compression you may have bent valves.
coil help
tcspeer replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
This may be a stupid question, but if you unpluged the crankshaft postional sensor or you sure you pluged it back in. Its the one right on top of oil pump by the crank spocket. -
coil help
My first thought would be the timing, that is what you worked on. Did you use the mark on the tab of the crank spocket to time or the arrow? I done my first timing job correct only to come back on the second one and use the arrow which is wrong you need to use the line on the tab of spocket. -
I use a 80 ft. lb. torque stick, and it ends up around 78 lbs. when I check it with torque wrench. The correct value I think is a little lower but not much it should be in owners manual. quote=ericem]Hello my friends, time to do the brake pads. Now i have my fancy micrometer torque wrench and would like to torque my wheel nuts to the correct amount now that have one. So what should each nut be torqued to? Thank you!
Lemon Law???
tcspeer replied to RdNkBrt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
After checking it does look like most is covered under State law. -
Lemon Law???
I may be wrong but I thought the lemon law was a Federal law, the dealer should have it posted somewhere in the dealership, if not ask them. I think they are required to provide you with the contact information you need. -
Take the rubber plug out of the back, Then get a large nail and put a 90 bent on the end about 1/4 to 3/8 in. Go straight in with point sticking left when you get it in the slot raise the point straight up. Push straight until you hit the adj. screw then raise the end you are holding just a little and the point will go under the adj. screw then quickly level it back out and push straight you will feel the little adj. arm when you get on it you will fell the spring action, push it away from adj. wheel and hold it back then take a screwdriver and turn the adj. wheel up, this will mean you need to push the screwdriver handle down towards floor or ground. The adj. wheel will be on the side of the slot that is nearest the front of car so have screwdriver there and nail towards the rear of slot. If you cant get it this way you can pull it off with a three jaw puller, all you should ruin is just the little caps on the hold down springs. Then when you have it off figure how to retract the shoes and draw you a digram for the next time.
