tcspeer
Everything posted by tcspeer
It sounds like you have done well. Did you mail your letter certified with a return receipt? Remember if you end up in court you need a paper trail and the court will not question your correspondence if it is certified mail. If not the other party can just say he never tried to settle this with us, we didn't even know he had a problem until we was informed to show up at court.
Another solution which a lot of people here dont care for is Gold Eagle engine stop leak or Barrs, I used Gold Eagle to stop my rear main seal from leaking when it had 100,000 miles on it and it never leaked again, I lost the engine at 288,000 miles because of a idle pully that came apart. Also I never had to change the cam seals after using this. It's to bad so many people are afraid of such a good product. As the seals get old they dry and shrink this product will gently cause them to expand to feel the gap.
I just changed the fuel pump on my 97 Legacy wagon, pull the line off at the filter and then turn engine over if no fuel is coming out then unplug elc. connector at the fuel pump and see if you have current. Check it with a dig. meter it dont need to be 12 volts. If you have current then turn key off while you have the cover off. Have someone else turn key on if you here no noise from pump you need to replace it. If you have no current then the relay is under the center panel under steering wheel at least it is in mine. Fuel pump from O' Reillys cost me about 80.00 dollars, It is more easy to get the whole unit from junk yard and replace it that way. I had to change the wires and the rubber seat with the one from O'Reillys but they do have these needed parts in the box with the pump. Be careful when turning engine over with fuel line off, you may want to add a line long enough to run over the fender to keep it away from the engine.
CV Boot Split
tcspeer replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
After taking the nut off you must remove the bolt completely, I have always been able to pull the ball joint out by hand or with a small bar against the control arm, others have really had tough times getting them out. But I have mine apart more often then most. -
Be sure and note the orination of the top hat with the strut flange when you take them apart, so you can put them back together correct, notice you will have a arrow pointing out on the top hat, mark the orination of this and spring and strut flange with a paint marker before you take it apart. Use a torque wrench to tighten the three small top bolts they will break easy if you over do it.
You can take one of the plactic covers off in the front and see if the belt is broke, but if it is broke the engine will turn over much faster when you crank on it then it will if it is not broke, so you should be able to tell without removing the cover. You might want to take the fuel line off at the filter and see if you are getting fuel. My fuel pump went out last week and it run kind of like what you are saying yours does.
I can answer one question, yes the transmission comes as a complete unit with the front diff. I know because I just bought one a few months back for a 98 Legacy wagon you can look to pay around 400.00 to 900.00 dollars for one and you can find all you need by putting your request with Junk Yard Dog. The only thing tough about changing it was getting to the torqe converter bolts the rest was easy.
I see you dont appear to be interested to much in the ideal of the court, so I will offer you another suggestion, find a wrecking yard and have them replace the engine with a used one. A lot of yards will replace the engine for you and if they dont they ussally work with a shop within a few miles that will. You should be able to have this done for around 2,000.00 dollars at least that is in the ballpark for Texas for most cars. And most will come with some kind of warranty.
