Everything posted by ivantruckman
I have a 91 ea82 autovagen , that is spfi , just did a tune up / plugs wires cap rotor / on it 5 k miles ago . running great , yesterday it started idling rough. and the acceleration off idle is sluggish . after 1500 rpm is does ok . it hesitates at the low end . it will do 65 mph no problem . im thinking egr , or mabe idle air circuit ? . the check engine light is on now too .
fuel pump relay ?
ivantruckman replied to ivantruckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
cool green plug , thanks scott -
they are staked in , you can remove some material with a dremel grinder , and rent a c press (ball joint press) from advanced auto and remove them. then you have to hand fit the new u joints in , they cant be too tight ,as to distort the joint going in , but they have to be tight enough to hold them square , the new joints use clips to retain them.
is the fuel pump relay one of the four relays under the dash above the fuse panel ?
annoying fuel pump issue
key on engine off it cycles the pump for a second , it doesn't always do that . when I don't hear the pump cycle, that's when it wont run -
1992 loyal spfi , key on not cranking . the fuel pump intermittently will not run . I just replace the pump with a known good one . but it is used . could it be the pickup coil is dirty ? what else could it be ?
banging on the fuel pump
I LOOKED UP A FUEL PUMF FOR AN 1988 F 150 5.0 LITRE/ 28 BUCKS, LOOKS PRETTY EASY TO RETRO FIT -
Cool tom , Thanks . I have a good used pump from a low mileage total. -
I have a 1991 loyale spfi , I am having to bang on the fuel pump a couple times a day . once it starts im good . im wondering if its a ground problem . what is the most common cause of this .
this clean 1985 4x4 sedan on ebay has a weird air set up , it looks like it has been converted to r134a , but the rotation sensor for the compressor is different , is this a retro fit air kit ? , and do the 1985 gl ,s have a black air box. just wondering how stock this is. or has it been restored ?
1990 loyale sw electrical
ivantruckman replied to soopsoop's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had the same problem , I installed a pushbutton in the dash wired from battery directly to the started solenoid -
1986 with 56 orig miles
JEZEK, I was thinking of a mild custom / restored look . like yellow bumpers -
It has 56.000 k on it , original . I was going to use it as a commuter. very little wear on the steering wheel and the heat controls . -
EA82 stalling at idle
ivantruckman replied to tyeira1987's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check the coolant temp sensor . if it was just idle I would check the idle air solonoid -
Is it hard to convert a ea82t to a ea82, I have an opportunity to get a nice T wag with bad head gaskets . Is it as easy as putting in a ea82 , or is there a different ecu and wiring harness crap ?.
3/4 is for the 4x4 5/8 is 2 wd
Sticking speedometer
ivantruckman replied to NocturneVoyager's topic in Old Gen.: 80's GL/DL/XT/Loyales...
can you small gear lube ? dead giveaway -
A few questions about brakes
ivantruckman replied to abcus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
a brake can lock up mechanically or hydraulically , push the brakes and then if the wheel locks up ,loosen the bleeder screw, if the brake releases itshydraulic , I have had rebuilt calipers that have been bad and the piston seizes . if the brake locks up after the bleeder screw is loose than the caliper pins need to be cleaned and lubed . or the piston is stuck. -
who can run a vin?
ivantruckman replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
1987 GL L4,1.8L SOHC -
1987 gl 4x4 ....Are there any lower control arm bushings out there any more ?. im having problems finding anything .
