It has Disc in the front (Which is about 70% of the stopping power) the rear Drum still grab for stopping. but yes the E-brake is connected to the rear brakes on the EJ vehicles. EA vehicles had the e-brake on the front brakes.
You've got rear drum on that! That sucks. I've never seen a drum that rusted before, the ones on the Loyale aren't even that rusty! Did your car sit a lot sometime?
24hours of lemons
Desmond Jones knows all about the 24 Hours Of Lemons. He's attended a few times. Sounds fun as hell, its in Joliet right? you could pick up a Legacy here in WI for like $300 that might just need a clutch or a HG.
Maxxis Bighorns:
Does anyone have a picture of these tires on their rig? I'd like to see how much smaller these tires are compared to the Grabber AT2s.
Wheel time
TheLoyale replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook cool!
Wheel time
TheLoyale replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSilver is pretty bright, but might look fine with ur wheels and body color.
Wheel time
TheLoyale replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOMG! same thing here.. Its construction all over Waukesha and Milwaukee.
Wheel time
TheLoyale replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dunno, I repaint my hub and calipers with just cheep semi-gloss black from time to time and it doesn't flake or burn off. Starts to rust after a year of salt.
Wheel time
TheLoyale replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLink!! Linkaroo, click or ticket!
Wheel time
TheLoyale replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, Rustolium "Hammered" gray, its a little brighter then gun metal and it has a cool effect, makes it look hammered.
Wheel time
TheLoyale replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would paint ur calipers maybe hammered gray or something, looks tuff
1987 GL-10 EA82T Runs Rough & Lacks Power
Well we figured it out, Turns out one of the plugs for the Fuel injectors (MPFI) was all corroded and wasn't getting good contact (No.1 Cyl) so that is what was causing the miss-fire. As for the timing, yes I set it to the 3 lines (Middle line) I think there was a misunderstanding that post by Jon. Only issue with the car now is it bucks sometimes during take off, which could just be dirty air passages and a Dirty MAF. Jon, post up how it runs now after you've been driving it all day!
When you took the distributor out did you mark which way the rotor was turned? If not and just put it back you, the timing gear on it will be way off. We might have to pull the Dist tomorrow and then turn the engine to 0-TDC then find out where the timing gear needs to be and then put the dist back in. I think this is your problem. Even though we turned the top of the dist and it showed 20 BTDC with a timing light, if the timing gear on the rotor shaft it off I think that will cause a major issue, as timing won't be true. GD, do you have any input? -Tom
Inner Tie-Rod removal?
TheLoyale replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I at least have enough room to do that. This is why I have to change my inner rod: http://www.ultimatesubaru.org/forum/showpost.php?p=949857&postcount=271
TheLoyale replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOH I've heard/seen of that then, I will give that a try when I do this. Thanks and cheers!
TheLoyale replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlright! Thanks for all the answers! I have never done anything with inner rod ends before so I wasn't sure how they came out. I have heard of the string thing, doesn't that involve chalk string or something. Thanks again! -Tom
TheLoyale replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 to Silicon spray! It helps big time with rubber bits. I've spent many a time dicking around with stuff when all it needed was some spray to slide right on. Just to get this right, that tool slides over the entire inner end (With outer end removed) then you just break the torque and remove. Well if so, then I wouldn't need to drop the header. Only reason I was saying is due to I run an Unequal Length Header on mine, and its all in the way of the steering box if you had to access it from underneath.
TheLoyale replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, I know about keeping track of the turns. but as you said it might still need to be adjusted with a laser anyhow to get it dead on. Oh, so the inner rod screws into the steering box? Ok I see how that tool would work.
TheLoyale replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, yeah the outer rod end and Castle nut comes out just fine (Had it off the hub in the past) Looks like I'm gonna have to drop the UEL header on this EJ22 to get enough room to get to it. Its the driver side tie-rod.
TheLoyale replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere is what came up in HF, Its just a puller set? Thats no big deal we have that stuff. http://www.harborfreight.com/5-piece-front-end-service-tool-set-66686.html Or is it this? http://www.harborfreight.com/inner-tie-rod-removal-set-96558.html
TheLoyale replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlright, I will check out HF. I think the MOOG one comes with everything, yeah? http://www.rockauto.com/catalog/moreinfo.php?pk=202535
How do I remove the inner tie-rod from the Steering box on a '95 Legacy? I slid the boot back enough to see where it joins, but how does it come off? My chilton doesn't show it in detail.
Maxxis Bighorns:
Anyone have a picture of the Bighorns in a 27x14" size? I'd like to see how wide and tall they are. Cheers, -Tom
Wheel time
TheLoyale replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy speed-o on the Loyale is off by 8mph and proud of it!
Wheel time
TheLoyale replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCool - hope you get them soon!
