18
Best stuff to re-attach moldings ???
TheLoyale replied to SubieDaddy80's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just used a self mixing epoxy, applied it to the back of the molding and/or clip if you still have one, works great - still holding and i hit some hard bumps and jarring alot. Just make sure you don't put to much as it will ooz out onto the body, but if you wipe it off quick there will be no damage. -Tom OR! Just do it Red Green style and use Duct tape :-p -
TBS-(exist for subarus?)
TheLoyale replied to hardtail_pride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Interesting read.. -Tom -
Do we need to go over this again? Most of Fram filters use cardboard end caps, which at times break down and enter the oil system clogging bypass holes, lifters, oil passages ect.. Causing internal engine failure. Theres alot of threads on this, do a search sometime -Tom
GD is a good guy, he's given me loads of infomation and knowledge over the years. That is a nice looking machine, oh no! I spotted a Fram, please tell me you now use Wix or Genuine? -Tom
Old Subaru's from little Iceland
TheLoyale replied to KristjanJohann's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thats cool! Always good to see Subaru culture from other countrys -
Congrats! Blinkers once again! -Tom
Just wow, Awesome pictures! Now thats what I like Loads apon loads of pictures all at one time! -Tom -
Sometimes when i make a left turn....
TheLoyale replied to xbeerd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No not really, Ball pops out, gets jammed up in the race, bends/cracks race, race gets jammed, wheel locks up or puts a major drag on it. Seen that twice so far! -
I suppose that would be true, a ball falls out of the race you are gonna here it Lol! -Tom -
Front Wheel bearings arn't bad, I think theres a write up on here somewhere on the USMR. DOJ - Dubble Offset Joint. The inner cut on the axle (Closest to the tranny) -
GD, from what I know and what Miles has said numeras times is that you won't hear a bearing on the older soobs. A Roller bearing (like a '99 Blazer) you would hear. -
Push front a rearward on the wheel and see if you have any play. The wheel bearings on these vehicles are not Roller bearings so I dout what you are hearing is a bearing. You will most likely not hear a worn wheel bearing on these cars. Do you have any play in the axle shaft? Could be a worn DOJ, do you feel anything or just hear it? -Tom -
Dirk, thank you for the history and update on knowledge. I didn't know Iceland had a President, it has to be alot better then our President (I'm not here to start a political fight, but thats the truth so far) I think this thread should be changed to "Interesting facts about Iceland" and still post Subaru pics and also talk about the country -Tom -
I would think that Iceland would have simular Subaru specs and Aftermarket availability as the EDM vehicles as Iceland/Greenland are part or Europe, Correct? Or it it owned by the U.K goverment like AU and NZ? -Tom -
How many miles on your subaru?
TheLoyale replied to dughrt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have 108,000 flat on my '92 EA82 Wagon -Tom -
Bring us back a bumper sticker!! And no, your not the only smoker left. I smoke (2nd hand) Hell New York you can't smoke outside, nor in your own car! Whats with that bullhocky? WI you can smoke were ever (Just not in stores or Doctor offices lol) -Tom -
Another Brat (almost) on the road
TheLoyale replied to Turbone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That engine looks amazing now! I like the black pully and valve covers. I don't know what the hell that pudding was in the oil pan, carb, heads ect.. but good god man!! The body does look good, I like the black pugs! Keep it up Rob! -Tom -
Disco? Nonsense! Being in 3ft of snow with a lifted EA81 is way better then any clubbing action Haha! -
Yep, Check all the fuses. Thats what I do to find the culprit. Now if it is a fuse, you need to ask you self "Why did it blow?" I would check any of the exposed wiring for the turn signals - to see if theres a slice in it causing it to ground out and blow the fuse. -Tom
Looks A.W.E.S.O.M.E!!! -Tom
