81 GL turn signals
Yep, Check all the fuses. Thats what I do to find the culprit. Now if it is a fuse, you need to ask you self "Why did it blow?" I would check any of the exposed wiring for the turn signals - to see if theres a slice in it causing it to ground out and blow the fuse. -Tom
My new 1981 brat!!!
Looks A.W.E.S.O.M.E!!! -Tom
A little Wheelin' in my area
Thats very true, know the vehicles limits and your own. Bill, aha theres a bolt. Now I understand it. -Tom
I'm supprized you havn't found a way to make your own stubs out of a better more durible metel, since the OE stubs are made of a Alloy/Steel mix. Maybe go with a heavier grade of steel, also, do they need to be hollow? if not that would solve the problem right there! Also, how many teeth are your stubs - 23 or 25t? -Tom
Oh ok, well thats not nearly as bad (Unless it doesn't budge) All you WA guys have nice little places close to home for messing around (WI has 0) they are all 6 or more hours up north -Tom
Old Subaru's from little Iceland
Wow capital Reykjavik has alot of flat land, looks very cool, and tighty! I don't see anything messy there. That view is just unbeatable. Thanks for showing!
Thats kinda what I figured, that does put a crimper on the day. I still can't figure how you can change a stub right on the trail at Walker - I mean, you have to drain the diff, remove the cover, remove the DOJ off the stub and whatever else all in mud and rain... I suppose I would do it too if I had to (Just looked like a mess at Walker lol) Or am I wrong on how the stub comes out? No need to get real technical if you don't want to, just seems like it'd be a bugger
How did you shear another stub? Must have been hopping it alot? or just to much torque with a stuck wheel? -Tom
Are you gonna replace the gasket or head if needed so you have an extra motor?
Yes, your not far off. You should really come to "Little Norway" in Baraboo, WI. alot of good knowledge to be had there. -Tom
GD, FYI this is a Turf House/Home. They are sometimes built into hills and the like.. Like in Norway. -Tom
I think it would be a awesome place to go anytime of year! Rolling hills, fresh sea air. I would also like to visit Scotland!
Those are some interesting and cool pictures, How did that end with that gray L-series wagon? Looked like a pretty deep slide!!? That rear tire is almost down to the rim. -Tom
Boy oh boy, I must have hit a nerve or something Lol. I just asked a simple question. Don't be naughty, Christmas is next month!! -Tom
I played with my R/C Brat today! -Tom
Disconnecting Front Handbrake
Some up there, some down there, some on the sides. Levers galor! -Tom
Did you get all the brake dust off the fronts? Ooo I want to see the air cleaner! -Tom
Vintage 4WD Stickers!
Can I get one of the "4WD with the black box, EA81 style I guess" And 2 of the "4WD 1800" -Tom
Battery Terminal Corrosion...
TheLoyale replied to heartless's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell all wet-cell batterys leak acid once in a while (Just normal) and if you don't open your hood check/clean things on a ragular basis that does get built up and can also couse corrosion on a terminal. Is your battery maintenance free or can you pop off the covers? Check the levels and see if its running low, then you'll know that is whats causing your corrosion. -Tom
I'd leave the brakes alone and just pop it in 4WD and power slide it around! 4-Wheel Drift is fun as hell. But thats me -Tom
Oh hoho, sorry if I offended you mr. Monster tires That'll look way cool!
nice! 27 or 28ss then?
New MOOG Ball-Joints: One for the road lol -Tom
Bill, looks good. Nice diff! -Tom
Oh yea, but it still looks damn good! Mad Maxish!
