djmark7
Everything posted by djmark7
  1. I had to replace mine, mine had a 8 inch long rubber line subaru wanted $50 for the hose, I ot a rubber hose at napa for like $2.50 ripoff
  2. https://www.marketsource.com/looks like a sales company i dunno if id let him touch my subie but then again https://www.linkedin.com/jobs/view/market-area-recall-specialist-at-marketsource-inc-1723911007?refId=c2bbef50-3f43-4fbd-bd5f-678739aea369&position=8&pageNum=0&trk=guest_job_search_job-result-card_result-card_full-click
  3. 1st engine blew hg lost oil pressure it ran, made a lot of noise, 171000 on replacement Thank You Bennie
  4. hi akll, i have a 96 legacy just replaced the 2.5 motor cel is on cat code with the old motor was getting 23-25 mpg with same code, the new miotor im getting 16-17 mpg, any suggestions?
  5. Does this help? http://www.cars101.com/subaru/keyless.html#code
  6. 1996 Outback Wagon, AT sometimes when i turn key I cant press the shift button on side of shifter to get it in gear when I press the brake, also no start the release mechanism is not releasing, any ideas? Thnx
  7. Hi All 1996 Legacy Outback Wagon AT 2.5 throwing Neutral Switch Code, I see switches from 32.00 - 200.00 whitch one should I get? or do I need molre info? Thanks
  8. leave door closed unscrew from hinges on bottom 2 screws on each side then release door and 'presto'
  9. dunno if this will help, but...... https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals
  10. survey says...... it was the solenoid, thnx again everyone
  11. I read a clogged EGR would kick it off also? is that true?
  12. OK,I put a 1998 2.5 motor into a 1996 body that had a 2.5 in it, same body style, leg wagon kicked a CEL Map sensor with the original 1996 sensor, also with the one from the 1997 car, the 1997 car had no CEL, the motor was swapped into the '97 car with no CEL I'm puzzled, BTW, same sensor in both cars PLEASE HELP !!!!
  13. does the key turn all the way back to the 'off' position?
  14. will the bolt patterns line up for the tranny?
  15. 1996 Leg outback Wagon Body 2.5, can i put a 1998 2.5 engine in it from a outback? ,will it swap right in? from a wagon also
