Everything posted by The Dude Abides
2014 Roll Call for Lifted Rides!
Still Hanging Around 1988 Subaru DL AKA Guido 27inch BF Mud Terrains on 14inch Peugeot Wheels 2inch Boss Lift ea81 with Weber Conversion Rear Disc Conversion Single Range to Dual Range Conversion
88 spfi trouble
After almost a year of abuse it still runs and drives down the road just perfect. I dont know if ill ever get to the wheel bearings.
'82 Brat: Solid Axle Build *** DONE! :) ***
Thats a good point, and i think youve gone to far to go back now lol. But remember everything your not having to deal with.
Home built gen 3 bumpers
Seriously where did he get those wheel arches and what is the size of those tires.
Removing the lift
So the time has come where i feel that i love my car enough to not kick the s**t out of it anymore. Id like to remove the lift and put street tires back on the pugs. Would 225 60 14s fit the stock wheel height.
'88 GL-4wd hi/lo in Denver(Sloan's Lake) seeks locals to bounce ideas off of.
Thought you had to swap more cuz the hubs wont accept ej cv axels.
front coil spring swap
Id probably sell mine if you were interested.
- 85 GL Hatch 1.8 motor build
https://www.facebook.com/photo.php?v=10200309550448817
- What Have You Done to your Soobie lately? (Please post in here and keep it going)
- Possible Drive Train Swap
Its sad this much work needs to be done to do somewhat simple things. Ill re evaluate.- Possible Drive Train Swap
On a side note, ive switched from ea82 to ea81 so i figured if i went ej id probally be starting from scratch with the wireing anyways. Could i retain the entire impreza harness in the loyale.- Possible Drive Train Swap
I was going to switch over to the 5 lug as well. Since i have the whole car.- Possible Drive Train Swap
So, im toying with the idea of switching my car from 4wd to an AWD drivetrain. I have got my hands on a 99 subaru impreza with the 2.2. I was wondering how much of this can i use on my current 88 subaru dl. I was wanting to swap over the entire thing and i dont remember if anyone has done this before. Ben p.s. i have tried looking it up but havent had much luck.- My '92 Loyale: Safariwagon
The question was would it level out the front more.- 4 lug 14" wheels
Another little problem is 14 inch tires are getting hard to find also.- BOSS 2" EA82 Lift Kits- $100!!!
Just a shot in the dark. Could you put a 1 inch tubeing under the engine mounts to lower the cross member.- BOSS 1" crossmember spacer kit for BOSS 2" suspension lifts
You need 6 to lower the cross member i thought you only needed 2 to lower the engine cross member.- 88 spfi trouble
Its in running and driving form now. Exhaust has been buttoned up, working on getting it in the wheel bearings taken care of.- 1 Prong vs 2 Prong Coolant Temp Sensor
It works though- 1 Prong vs 2 Prong Coolant Temp Sensor
Its an ea82 carb wireing going into ea82 spfi- 1 Prong vs 2 Prong Coolant Temp Sensor
So in theory i should be able to use the 1 spade connector adn just hook that side up to the gauge. And i looked, there isnt another hole, or any other types of wires coming out of that area.- 1 Prong vs 2 Prong Coolant Temp Sensor
So i have a 1988 subaru that recently had a ea81 swap with a weber setup. Everything works fine except the temp gauge. I picked up another coolant temp sensor to see if that might work but its a 1 prong and the one in the manifold is 2 prong. Im not sure the year of the manifold but i think its 85. I have a 87 Factory Service Manual and the manofold in the car for SPFI and Carb are not the one that is on the car. 1. Am i missing another sensor somewhere. The 2 prong is right next to the T-Stat housing. 2. Could i use the 1 prong anyway with the 2 prong connector. 3. I thought the 2 prong was for the computer and there was a 1 prong somewhere that just did the gauge.- EA82 4" Lift Pictures (Suspension)
Yea, i hardly come here anymore man. The sight has really changed, you just dont see as many old school subarus anymore. The 1st generation Outbacks and Imprezas are the new old school subarus. - What Have You Done to your Soobie lately? (Please post in here and keep it going)
