screwbaru2
Everything posted by screwbaru2
Sounds like there's air in the system. Doubtful you blew the HG's doing what you said you did. If there's a philps screw head looking plug on the passenger side of the radiator remove it. Pour coolant into the rad until it comes out the bleeder hole. You may need to repeat it after the engine is warm or you can bring the motor to operating temp to open the t-stat, with the cap loose. And fill it again until the coolant comes out the bleeder hole.
You said a mouthful there nipper! When I finally figured out what the timing marks on the belts where for it became easier. They put the timing aligment "off" about a tooth and a half so when the tension is applied and the slack in the belt is taken up the timing marks line right up. Get em right 1st time everytime since then.
The 1st thing I would do is look into getting a 2.2 for it. I'm not sure where you'd find a short block for it aside from a dealership. The 2.2's are more trouble free and a good used one would be a lot cheaper and less work than a short block. If everything eles is sound on it and its been well maintained $1500 is a good price.
You probably already know this but, if you do splice a new connector on,(which I would do in your case) make sure you solder the wires together. Don't use crimp type connectors those are not good for wiring that goes to a ecu, too great of a chance of the wires coming apart. What a interesting thread. You should get some kinda prize or award for this baby!
I found a driveshaft today. :banana: Waiting for the yard to remove it. Forecast is rain for the next 2 days so I don't think I'll see it until next week. It's in a 96 lego 5spd. so it should fit. They want $40.00 dollars removed. Sounds good to me. Also RI driveshaft says they've done soob shafts in the past and can probably replace the bad u-joint in the original shaft for $70.00 which doesn't sound bad either. I'm thinking I'll do that too and have a spare.
