Everything posted by EVOthis
hey guys, I have a 96' legacy 2.2 with a 5 spd... I did some driving around today and eventually i came up on some traffic everything was fine for about 10 minutes just crawling along than both my battery light and my brake light came on at the exact same time. please if anyone can help or has a similar problem it would be appreciated.
Hey Guys.... I have a 96' Legacy AWD Sedan ej22 with a 5spd.... my ABS light has been on....I pulled 3 flash codes for it....The first two were open sensors which i can look into, but the 3rd code said there was a "VALVE RELAY PROBLEM" code #51...I did a few searches on here and a few other forums and cant seem to find any information on it.....If anyone has anything on this issue it would be very helpful.
My Snow Tires I have on Steelies are a set of Bridgestone Blizzaks and they have proved the be excellant in some pretty serious snowfall. My Other Set I have on ASA 17"s are Kumho Ecstas and when it comes to any wet weather or snow....these tires suck....on dry pavement i think they are great though and have a good treadwear.
the cam sensor is located at the left cylinder head (almost directly below the oil fill tube and behind the timing cover). The crank sensor is right below the alternator and sort of behind the Harmonic Balancer/Crank Pulley. You could test the resistance of both of them with an ohm meter and make sure they are in specs.....also you shouldnt have any spark when either of them fails. both are quite simple to replace...unplug connector and unbolt....I know where i am you can get them from NAPA, but as always any Subaru dealer will work.
Head Gasket?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
well i dumped out my coolant resevoir to clean it......than i filled it again with new fluid....saw the bubbles the first time the car came to operating temperature....and since have checked it like 5 times and didnt see any bubbles at all.....
